Question about Compaq Presario X1000 Notebook
Can't get the wireless to identify the wireless networks available.
Do you have the right WPA/WEP key? If not, it cannot identify the network selected.
Check the WPA key with an internet radio or another computer to see if it is the right one.
If wrong key, or you cannot recall key, look on Google for ways to find.
good luck
Posted on Dec 11, 2009
How can i install my wireless router to other laptop?
The same as 1st laptop.
1. Locate the wireless-network-connections option
on your computer or wireless device.
2. Select your Belkin Router from the list of available networks. You
can identify your Belkin Router by locating the network name
(SSID) from the card located underneath the foot of your Router.
3. Enter your network password (located on
your network information card).
Oct 06, 2012 | Belkin Connect N150 Wireless N Router
Where is the ssid# located on hp pavillion dv6000
LOL, OK SSID is associated with your wireless router. It identifies your wireless network that you connect to. When you click on View Available Wireless Networks from your computer, the networks that it shows are shown by their SSID.
May 21, 2012 | HP Computers & Internet
What is an ssid mean
SSID Stands for "Service Set Identifier." An SSID is a unique ID that consists of 32 characters and is used for naming wireless networks. When multiple wireless networks overlap in a certain location, SSIDs make sure that data gets sent to the correct destination.
The SSID is different than the name that is assigned to a wireless router. For example, the administrator of a wireless network may set the name of the router, or base station, to "Office." This will be the name that users see when browsing available wireless networks, but the SSID is a different 32 character string that ensures the network name is different from other nearby networks.
Each packet sent over a wireless network includes the SSID, which ensures that the data being sent over the air arrives at the correct location. Without service set identifiers, sending and receiving data in a location with multiple wireless networks would be chaotic and unpredictable to say the least.
Feb 20, 2012 | Nintendo Wii Console
Hi i am using the pc sony vaio i have the problem on wireless adabter it was in desable mode and difficutl to active it ,while i am useing the bottom in front of pc on and off of wirless adabtor but i i on...
In Vista, you can either go to control panel, device manager and right click on it and click "eneble"
or go to control panel > network sharing and set up wireless network connection
or
go to task manager (press and hold ctrl . alt . delete for a couple of seconds), until task manager comes up. Then click on the services tab, scroll down till you see "Plug Play or Plug and Play and make sure it's running. If it's not, right click on it then click "enable"
In XP
Open Network Connections
Right-click Wireless Network Connection, and then click Properties.
On the Wireless Networks tab, do one of the following: •
To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
Computer-to-computer (ad hoc)
To connect to an existing computer-to-computer (ad hoc) network, under Available networks, click the network name, and then click Configure.
If you want to connect to a computer-to-computer (ad hoc) network and both computer-to-computer and access point (infrastructure) networks are within range of your computer, click Advanced, and then click Computer-to-computer (ad hoc) networks only.
To configure a new wireless network connection, click Add, and then do the following: •
If the network connection that you are configuring is to a computer-to-computer (ad hoc) network, select the This is a computer-to-computer (ad hoc) network; wireless access points are not used check box.
To change the order in which connection attempts to preferred networks are made, under Preferred networks, click the wireless network that you want to move to a new position on the list, and then click Move up or Move down.
To change the wireless network connection settings for a network that is listed in Preferred networks, click the wireless network for which you want to change settings, click Properties, and then change the settings as needed.
To remove a wireless network from the list of preferred networks, under Preferred networks, click the wireless network that you want to remove, and then click Remove.
To update the list of available networks that are within range of your computer, click Refresh.
To automatically connect to available networks that do not appear in the Preferred networks list, click Advanced, and then select the Automatically connect to non-preferred networks check box.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
When you enable automatic wireless network configuration, you can connect to an existing wireless network, change wireless network connection settings, configure a new wireless network connection, and specify preferred wireless networks. You will be notified when new wireless networks are available. After you select a wireless network, your wireless network adapter will be automatically configured to match the settings of that network, and a network connection attempt will be made.
To configure settings on the Wireless Networks tab, you must be logged on as an administrator, and you must use a wireless network adapter that supports the Wireless Zero Configuration service. If you are unsure whether your wireless network adapter supports the Wireless Zero Configuration service, contact your network administrator or the wireless network adapter manufacturer. For more information about automatic wireless network configuration, see Related Topics.
If you are using third-party wireless networking software, clear the Use Windows to configure my wireless network settings check box.
If you are unable to connect to an existing wireless network and the name of the network that you want to connect to appears under the Preferred networks list, click the preferred network name, and then click Properties. In Wireless Network Properties, review the settings to ensure that they are correct. If you are unsure whether the settings are correct, contact your network administrator or the wireless network adapter manufacturer.
If the Preferred networks list includes both access point (infrastructure) and computer-to-computer (ad hoc) networks, you cannot move a computer-to-computer network to a position in the list that is higher than the position of an access point network.
To provide enhanced security for 802.11 wireless networks and for wired Ethernet networks, IEEE 802.1x authentication is enabled by default. For more information about how to set up 802.1x authentication.
Hope this helps
Dec 12, 2010 | HP Broadcom NetXtreme Network Adapter
Virgin has installed. D link wireless router (home address) I have 2 laptop xp window vista and pc upstair they detect the vg 50Mb broadband but can not connect ! When I go with my 2 lap top elsewhere I...
1.
2.
3.
• To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
• To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
4.
• To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
Important
• If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 30, 2010 | D-Link DIR-300 Wireless Router
Cant connect to the internet on my lap top
first thing is to identify the wireless settings of the router,you need to identify the wireless name (SSID), channel and the encryption you are getting from the airlink router. Next is to make sure that the wireless computer has enabled wireless signal/ or the wireless is on.
after that, you may connecting wirelessly to the computer, right click wireless connection and go to view available wireless networks, try to connect -input the encryption key from you wireless router or password and hit connect.
Jun 28, 2009 | Airlink AR430W Wireless Router
Connecting copier machine wireless
Configuration using a wireless computer.
  1. If your computer has wireless capability, you will need to change the wireless settings of your computer to Ad-hoc mode so you can directly connect and configure the printer.
  2. Wireless network terms and concepts
    When you configure the wireless network printer, you must ensure that your wireless network printer is
    configured to match the settings of the existing wireless network. This section provides some of the main
    terms and concepts of these settings, which may be helpful when you configure the wireless network printer.
    SSID (Service Set Identifier) and channels
    You need to configure the SSID and a channel to specify the wireless network you want to connect to.
    SSID
    Each wireless network has its own unique network name and it is technically referred to as SSID or ESSID
    (Extended Service Set Identifier). The SSID is a 32-byte or less value and is assigned to the access point.
    The wireless network devices you want to associate to the wireless network should match the access point.
    The access point and wireless network devices regularly send wireless packets (referred to as a beacon)
    which has the SSID information. When your wireless network device receives a beacon, you can identify the
    wireless network that is close enough for the radio waves to reach your device.
    Channels
    Wireless networks use channels. Each wireless channel is on a different frequency. There are up to 14 different channels that can be used when using a wireless network. However, in many countries the number of channels available are restricted. For further information, see Ethernet wireless network on page 165.
    Authentication and encryption Most wireless networks use some kind of security settings. These security settings define the authentication (how the device identifies itself to the network) and encryption (how the data is encrypted as it is sent on the
    network). If you do not correctly specify these options when you are configuring your Brother wireless device, it will not be able to connect to the wireless network. Therefore care must be taken when configuring these options. Please refer to the information below to see which authentication and encryption methods your Brother wireless device supports.
    Authentication methods
    The Brother printer supports the following methods:
    • Open system
    Wireless devices are allowed access the network without any authentication.
    • Shared key
    A secret pre-determined key is shared by all devices that will access the wireless network.
    The Brother printer uses the WEP keys as the pre-determined key.
  3. I will advise you download this network manual and follow the instructions on chapters 3 and 4.
  4. Network Users Manual - English
Apr 15, 2009 | Brother HL-4070CDW Printer
Printing
You need: * A wireless-enabled computer. Many computers made over the last three years are already wireless capable, or they can operate wirelessly with adapters. * A wireless router. This will serve as your Wi-Fi access point, the hub of your network. * Broadband Internet access. While you can use your wireless router without any Internet access at all, or use dial-up, experts agree that there?s real value in accessing online content via DSL or cable and making it available to every computer in your house. The cost of doing so, like with the hardware, has dropped dramatically in the past several years. When you set up your network using the wireless router, you?ll need to identify that network on each of your wireless computers and during the installation process for your Lexmark wireless printers or all-in-one devices. You?ll be asked about your service set identifier (SSID), which is basically the name of your network. Don?t forget to consider the security of your network early in your decision process. * Common security types for networks include WEP, WPA and WPA2, and there is usually also an option for no security. At a minimum, you should look for WPA or WPA2 security and follow the manufacturer?s instructions to encrypt your signal and set your own password. A password isn't mandatory, but if you don't use one, it's far easier for others to access your network, and potentially your computer.
Sep 08, 2007 | Apple MacBook Pro Laptop Computer with...
Compaq Presario X1000 Notebook Logo
94 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
