Question about Plumbing
I have an imersion heater and want to fit a timer on it. Do i need to get an electrician in to do this?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 35 Answers
The imersion heaters that i am familiure with ,plug into an outlet you should be able to find a timer that plugs into the outlet and then the imersion heater plugs into the timer.If not then yes you should consult with a electician.
Posted on Dec 12, 2009
SOURCE:
My little gray box timer has stopped working on my water heater. How long do they normally work for. I installed it April 2016.
* Warning, High voltages present (220-240VAC).
* Call electrician or plumber for service.
*** Following is for information only.***
* Mechanical timers have several parts that do burn out and needs replacement (suggest using an electrician)
* The timer switch will get stuck (welded) and keep the heater on all the time. (usually it will overheat the tank and pop the thermostat high limit switch.)
* This "shorted" condition of the timer will also show up as the water heater will over boil and blow the pressure safety valve located on top of the water heater. The valve may also be connected to a drain line that extends down to the floor drain or exit out the wall to an outside yard or drain.
* The timer also has a clock drive that moves the on/off dial or wheel. This wheel should turn when powered up. Albeit very slow like the minute hand on a watch. You will have to wait at least 30 mins to notice any movement of dial.
* The timer does make a "whirling" clock noise, but the area may be too noisy for you to check.
* The timer motor (if visible) does move when powered. But this may be difficult to observe as it's usually mounted in a box.
* Water time switch Installed (by lady); https://www.youtube.com/watch?v=2tO4grzZ9iU
* Note: if you already have the same brand and model timer replacement then you can just replace the "guts"
* DIY replacement (GE); https://www.youtube.com/watch?v=2Tym7jmNtk8
* Install "little Gray Box"; https://www.youtube.com/watch?v=DmhiN1-DrSY
* Setting up and setting On/Off times; https://www.youtube.com/watch?v=lqNZc5cW_KE
* Customer's trouble shoot timer; https://www.youtube.com/watch?v=P7iOh_Plh2g
* Be safe, call for service.
Aloha, ukeboy57
Jul 23, 2018 | Hardware & Accessories
GE Monogram ZSGS420DMASS new defrost heater, drain pan heater, motherboard and fan fitted. When it goes to defrost cycle it trips out the RCD. Disconnect the two drain heater leads and it goes back on
check the heaters for ground leakage
have an electrician do the checks
moisture will trip rcd units as they work on a ground balance and milliamps will set them off so it could be moisture causing the problem
electricians have the equipment to check and find the cause
Jun 30, 2016 | GE Refrigerators
Can an intermatic pool timer be switched out with an intermatic hot water heater timer both look identical
both are timers and the possible difference is the current rating for the unit
the rating for the heater may be higher so be careful in that aspect
talk with an accredited electrician for exacting advice
Apr 23, 2016 | Intermatic Timer T12404R Pool & Spa...
I need a timer for a 208v water heater
Nope it is only rated for 120 volts
http://www.drillspot.com/products/43780/Intermatic_T1975_Indoor_Multi_Operation_Timer
You would need a Paragon timer that would be rated for 240 volts
kinda sorta like this defrost timer: http://www.ebay.com/itm/Commercial-Defrost-Timer-Paragon-8141-20-S814120-40-AMP-2-HP-208-240-Volts-60-Hz-/300933095423?pt=US_Replacement_Parts&hash=item4611029fff
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 16, 2013 | Dryers
Water heater timer not working or bad wiring?
10/15/2012
Hi Liz.
This is a live answer. And you can add a comment after trying following step, and I will comment back..
Replace battery, and then reset the timer using reset button located to left of display screen.
http://waterheatertimer.org/pdf/eh40-english.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 15, 2012 | Intermatic EH40 - Electronic Water Heater...
Ac and heater dont go on
was quoted in the hundreds to replace the whole heater unit in mine, although when checked by a car electrician instead of a mechanic it turned out to be the transponder! Very small part within the heater system. It takes a car electrician to fit/change it (or a talented enthusiast) but at a tenth of the price of a new heater unit!
May 15, 2012 | 2006 Chevrolet Impala
I have a timer that won't hold the program time set schedule? I have paid an electrician to come out and check to make sure i don't have any shorted out wires?? Electrician didn't find any...
Question posted under 120volt Intermatic Eh10 timer.
I do not have repairs for defective timer.
EH10 has 1 year limited warranty.
Located just below the digital display is compartment for AA battery.
Display is controlled by battery.
Replace battery, press and hold reset button for several seconds to reset timer, and try to program again.
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html#EH10
http://waterheatertimer.org/pdf/eh10-manual.pdf
EH10 and EH40 timers are susceptible to line noise.
If timer is connected to water heater, there is no line noise. And electrician tested for shorting wires.
But when timer is connected to fan, pump, or other type of load, then interference can be a problem.
Intermatic can provide a filter.
http://www.intermatic.com/customer%20service.aspx
Digital timers, digital water heaters, digital washer and dryer, digital water softener, digital treadmill, etc are increasingly common, yet are not protected from surge.
People protect computers and TVs, but forget other costly items.
EH10 can be affected by surge.
Install whole house surge protection:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#surge
Aug 17, 2011 | Intermatic 7 Day Electronic Timer Eh10...
Timer motor does not turn
make sure you purchased nthe correct timer and not a 220 volt timer for water heater use , you could still turn on and off manually but you would need 220 volt to run timer may sound silly but i have seen it several times before , look on the door plate and be sure it is a 120 volt 1 phase tmr motor
Jan 04, 2010 | Intermatic WH40 - Water Heater Time Switch...
Plumbing Logo
64 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
