Question about Whirlpool Duet GHW9150P Front Load Washer
What does "F 20" mean when it is flashing - Whirlpool Duet GHW9150P Front Load Washer
  • 10,515 Answers
This Error Means that Water is Not Detected by the Machine. There could be many Reasons for the same . Read the Below Article that works for most of the people :-
http://www.wikihow.com/Fix-a-Whirlpool-Duet-Washer-F-20-Problem
Unless :-
1. Check Hoses. It should not be clogged or kinked or blocked.
2. Make sure Inlet Valves is Turned ON and Working.
3. Pressure Switch and Hose are in Good Condition and there is no Water Leak.
There could be several other reasons which needs a Professional on Site.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 11, 2009
What does a flashing E on the gauge cluster of 2005 fz6 mean I cant see anything but a flashing E
See user manual or if you;don't have one copy and paste this link; www.manualslib.com/manual/660137/Yamaha-Fz6-Na.html?page=20
Jun 20, 2018 | Yamaha Motorcycles
I need the manaul for this product. I do not know what the the flashing light mean, and I was given this product from another co-worker....but no one knows what the lights mean?
Hello, you can download the manual here: http://www.plantronics.com/us/media/media-resources/literature/user_guides/73156-01_CS55_US_DL.pdf?WT.dl=20 It says that a flashing amber light means charging, a solid amber light means charged, a solid red light means power, a solid green light means talking, and a blinking green light means muted.
May 16, 2011 | Plantronics CS55 Wireless Headset
Unit flashes the number 20
A 20 error code means the high limit switch is being tripped. This is most typically caused when scale develops in the heat exchanger. I'd recommend performing a descale on the heater to resolve the problem. Make sure to follow the instructions that came with your isolator valve kit.
Jul 10, 2010 | Noritz 8.4 Gallon Residential Direct Vent...
When the 1st green light on the battery is flashing, does this mean the battery is no good?
Yes. the battery is still good. some batteries have 5 leds on them. each led represents 20% of the battery life. if all 5 leds flashed, it means that the battery is already degraded... and needs replacement
Jun 22, 2010 | Apple iBook G4 Mac Notebook
Panel is flashing a 20 code and water is ice cold. Unable to reset system from control panel.
I was just told by Noritz America that flashing 20 is hard water issues. Any confirmation on just what this error code means?
Nov 01, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
When powering on the fans spin and yet I get no video. The LED under the PSU (CR9E1) flashes. What is the LED indicating?
This indicates power supply failure. PSU means Power Supply Unit.
Solution?
Replace the power supply.
MAKE SURE it is a compatible one!
What do I mean by that statement? In some years of Dell manufacturing, Dell made their computers "Proprietary".
This means only Dell parts could be used in a Dell computer.
The wires in the 20/24-pin ATX main (Motherboard) power cable, were put in different socket holes, than a standard 20/24-pin main power cable.
Yellow is 12 volts. Orange is 3.3 volts. Red is 5 volts. Black wires are Ground wires.
If an aftermarket power supply made by another manufacturer, were to be used in these type of computers, it will burn out the motherboard! Possibly the ram memory and processor also!
If you buy an aftermarket power supply, instead of a Dell unit, make SURE the colors of the wires are in the same place, as they are in the Dell 20/24-pin main power cable connector!
For more info about that last statement, I suggest you check out this page,
http://www.playtool.com/pages/psuconnectors/connectors.html
Apr 02, 2009 | Dell (E210882) Motherboard
Whirlpool front lead duet sport flashing F-20.
I read one of the stories on the your sight and it addressed the problem I was having. The solution was to push the cancel button which prompted the machine to drain and end. Then I started the machine again to go through the whole wash proccess again. I think low water pressure caused the F-20 error. Thanks for a wonderful web site.
Dec 03, 2008 | Whirlpool Washing Machines
Error code E:62:20 meaning
errorE:62:20 related to lens unit stuckup or gears problum repairable
Apr 14, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
GSD 20 power problem
I'm not sure what you mean by "cannot get the sounder to power up". Are you not getting power to theGSD20, or are you not getting the sounder to display on the screen? I can probably help you with this but I need some more information.
If you are getting power to the GSD 20 sounder, it will have a flashing LED next to the cables that plug into the GSD 20 box. What color is it and what is the flash pattern (how many flashes, and fast or slow?) When you power up the GSD20 does the color or flash pattern change.
I'll watch for your response here.
Feb 23, 2008 | Garmin GPSMAP 3010C GPS Receiver
Whirlpool Duet GHW9150P Front Load Washer Logo
71 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
