Question about Hotpoint Washing Machines
My machine is a first edition but i got no manual can u tell me where the filter is as its not at the front or on the back
  • Hotpoint Master
  • 3,463 Answers
You need to remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the filter inside the hose.
Remove the hose on to the pump, and check for obstruction here and in the pump.
Hope this helps with you problem.
Posted on Dec 11, 2009
Where is the elusive filter located? I thought it was hiding under the flap thing at the bottom but I can't for the life of me work out where it is
If you were to Google "Hot point first edition FEW manual" using Firefox, the results will lead you to "for Hotpoint FEW washer - Laundry Appliances Manuals" at "laundry.manuals online.com>....> Hotpoint Washer".
Download a free copy of the instructions for Installation and Use for Hot Point First Edition Range User Manual.
I have looked through the manual and there is no direct evidence of a filter as such (common to other machines), but there are details of what maintenance should be followed to clean the machine - not too user friendly but may help.
If you do go to the manufacturers website (Hot point is an Indesit company) you will find that previous buyers have asked the same question as you)
Nov 16, 2013 | Hotpoint First Edition FEW12 Front Load...
Where is the filter?
theres no filter as such you have to do whats called a maintance wash tells you in the instrutions just a boil wash to clean filters some hotpoint machines have a filter access point under the kick plate at the front bottom of the machine
May 20, 2010 | Hotpoint First Edition FEW12 Front Load...
Where is the filter located on this washing machine?
At the rear of washer.
Remove lower back panel.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Jan 03, 2010 | Hotpoint First Edition FEW10P Front Load...
My machine won't drain and I can't find the
After having removed back panel, locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump and check for blockage or obstruction here as well.
Hope this helps you.
Jan 02, 2010 | Hotpoint First Edition FEW12 Front Load...
Where is the filter on Hotpoint first edition washing machine ?
Hi.
Some of these models, I believe, had a filter behind the front plynth. If nothing there then you will have to get to the back of the appliance.
Disconnect the power supply and remove the bottom back plate.
You will see a black hose that connects to the bottom of the drum and the other end connected to a drain pump.
With a few towels handy (make sure washing machine is empty!) unscrew the large clip holding the hose to the outer drum. Indide this hose you will find a filter. Remove, clean and refit.
Make sure hose is pushed firmly back on the outer drum and the clip fully tightened.
test with a small amount of water in the drum to make sure there are no leaks.
Hope this helps
Aardvark Repairs
Nov 18, 2009 | Hotpoint First Edition FEW12 Front Load...
How do I clean the filter on my Hotpoint First Edition FEW12? Do I have to take off the whole big black pipe at the back, under the drum? There is no filter at the fron
Yes, remove lower rear cover.
Remove large black hose from bottom of drum.
Clean the filter inside the hose.
Please rate my solution.
Thanks.
Nov 14, 2009 | Hotpoint First Edition FEW12 Front Load...
The OE Message on my LG Tromm WM1814CW
Open the little trap door on bottom front of unit. Unscrew lint filter trap. Drain water first with small tube.
Sep 08, 2017 | LG WM1814CW Front Load Washer
Hotpoint few 12 first edition
Its either behind the kick plate or in the pipe which runs from drum to pump at the drum end.
Dec 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Can't find filter
The filter located under the "narrow" panel at the front of the machine (the lower panel). You should pull the panel out(maybe it will not be easy for first time and you will need to use a screwdriver for it). The filter itself come out by turning to left. Before openning the filter, prepare a bowl and a floor cloth to avoid water's flooding. Good luck !
May 28, 2006 | Hotpoint First Edition FEW12 Front Load...
Cleaning
I am not familiar with this machine's model, but in most of the machines the filter is located under the panel in the bottom of the machine (the panel under the front door). You should pull the panel out and you will find the filter there. Before openning the filter prepare a bowl and a floor cloth to avoid water's flooding. Good luck!
May 06, 2006 | Hotpoint First Edition WMA22 Front Load...
Open Questions:
Washing Machines Logo
37 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
