Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Have a Magnavox model ct270mw8 27 in. 2007 dvd,vcr unit..It will run for a little while then go to shut down and sometimes before it goes to shut down,it will display the menu,then shutdown..Can unplug the unit and it will run for awhile,then start over?any ideas?
  • 834 Answers
The Vcr mech assy needs to be replaced it was a very common problem with this model try partsearch.com if they still have them avail around 70 bucks not an easy job to replace two cables have to be unsoldered and re attached to the new mech assy and the mode switch has to be set in the hole od the cam gear
Posted on Dec 11, 2009
I need code(s) for my DVD Video, Model #: NB093 remote control to program my Philips DVD Player/VCR, Model #: DVP3345V/17. Can you please help me? I would greatly appreciate it. Here is a picture of it.
http://remotecodelist.com/remotes/magnavox/magnavox.htm lists the code for your device as possibly being 1000, 1001, 1002, 1003, 1004, or 1005. Of course, you also have the option of using the remote controller's "Code Search" button. 25300580-iv4burzhkawezvl2jbah1xae-2-0.jpg With Codes:
Turn on the DVD/VCR unit directly. Continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Enter the four-digit code (1000, 1001, 1002, 1003, 1004, or 1005) for the DVD/VCR unit. The remote controller's light should go off. Press the remote controller's power button, & when the DVD/VCR unit turns off, then you will know that the remote controller has been correctly programmed.
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Nov 29, 2014 | Televison & Video
Magnavox ZV450MW8 shuts off within 10 seconds of being turned on
The problem is in the power supply, one or two capacitors fail and sometimes have a slight puff at the top, need to be replaced.
Mar 18, 2012 | Magnavox ZV450MW8 DVD Recorder VCR
ZV427MG9 A It will not record when recording from VCR to DVD type disc.When trying to playback VHS type cassette,It runs for about 5 seconds and then ,it ejects the cassette, then it shut,s down.
Hi well this "Fault" is usually caused by a thing called the "Mode Switch" it goes faulty, quite often, and needs to be replaced...It really isn't a DIY task.
The very best thing to do is contact a local or head office from Magnavox (RCA), and ask them for a referral to an authorised service center. When in touch here and in face to face contact ONLY first ask for a "Quote". Then you can make up your mind as to what to do once appraised of the costings, repair or replace?. I say that as more and more I find customers in my shop electing to replace any faulty units rather than repair, and, in all honesty these days this maybe the best approach?
manual link below..
http://img.almo.com/_Assets/Magnavox/PDF/ZV427MG9-Manual.pdf
Oct 08, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Have a Magnavox DVD/VCR player Model MWD 2206A,
units like DVD's, have the tendency of malfunctioning if not used for quite sometimes.corrrect me if i'm wrong.but like automobiles needs tune-up, right?try power it on for some time, but not using it.if still not call a tech
May 13, 2009 | Philips Magnavox DVD/VCR Dual Player
Recording from a vhs cassette...
This dvd/vcr unit is having a problem with component failure. It is probably in the main power supply section, since the unit shuts down. This can happen in these products due to the qulaity of component use in the product runs. The components usually have 5% to 10% failure rate. Which is usually taken care of by the product warranty. Unfornately this is a common problem with big manufactuers and large production runs. You need to have the unit tested and serviced at a service center. The service center will have all the service information to repair you unit. The Magnavox Customer support telephone is 1-800-605-8453. Tell them the model number of you unit and about the problem with the unit shutting down during use. They will be able to tell how to your unit serviced. I hope this information helps you with your problem.
May 10, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox VCR/DVD recorder model ZV450mw8. VCR plays a tape for 6 seconds then shuts the whole unit down.
You will need a technical person to open the unit. This problem can be as simple as a dirty sensor, or bad tape drive parts, or burned out computer chip.
Feb 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox combo vcr dvd
unfortunately the tape clamp sensor is broken or worn, or could have dust or dirt obstructing it and they don't have parts for these anymore, the tape clamp sensor is like a tiny white plastic sensor only a few millimeters in size with a red eye inside the edge of the tape carriage, and needs possible cleaning, it could be something as simple as dirt inside the mechanism over the sensors, the Tv will power down when the error occurs not much you can do if a clean or high output air blow of the components don't do the trick. sometimes dirt in the circuit can cause it to do that too, ....im surprised it lasted this long actually they were great for the bedroom, i had one ages ago they are available on ebay for about $100 or under now ...Sorry i couldn't be of more help.......you may get away with disconnecting the white feed ribbon cable that powers the tape cartridge and just use it as a DVD and Tv, that should stop the error.
Apr 26, 2017 | Televison & Video
Dvd/vcr
well sounds like one of the players is not in correct spot thus shuts down (kinda timing issue) see if there is anything preventing it from going jiggle or turn upside down see if you hear anything.
Feb 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Magnavox mwd 2206 dvd vcr player....shuts off with eject word across screen.
On a unit I checked with this same symptom, removing the top cover allows the unit to stay on and operate normally. There is some sort of sensor at the left middle of the chassis, which, when unblocked by any opaque object, allows the unit to remain on. A temporary fix (not advisable) would be to replace the top cover with a piece of clear plastic or taut saran wrap (no vent holes needed). It's unclear exactly where/what that sensor is from a cursory test. This is a work in progress on someone else's machine that I lack full access to.
Oct 27, 2007 | Audiovox VE1020 10.2 in. TV/DVD Combo
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Jun 11, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
200 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
