Question about Hotpoint WMA64 Front Load Washer
There is a smell of stale water in my machine and it taints the laundry, I have put a sink unblocker in the waste pipe but it hasnt helped
    Problem Solver:
  • 7 Answers
Run your washer once on a qick cycle with bleach and afterwards and after every load leave the door open. the smell is mildew which is common with all front loaders. if you leave the door open the moisture will dry and your odor problem will go away.
Posted on Dec 11, 2009
Frigidare dishwasher did not spin
  1. Waste Disposal/Sink trap
    • Empty your food waste disposal unit if your dishwasher's hooked up to one. If it's not empty, the old food inside it will back water up into your machine. Check that your sink trap isn't blocked by unscrewing it from the base of your sink if you don't have a food waste disposal unit. Make sure your dishwasher or any other appliances connected to it are not running when you do so.
    Incomplete Cycle
    • You may have opened your dishwasher's door mid-cycle before it's had a chance to drain. Check the progress indicator on your machine's control panel. The structure of this will differ depending on which Frigidaire model you're using, but it should show the point your machine has reached in its cycle. If this is the cause of the problem, close your dishwasher's door and let it finish.
    Drainage Pipe
    • Inspect the drain pipe that runs from your machine to your waste disposal unit or sink. If this is kinked or has been squashed under another appliance or a base unit, the waste water inside your dishwasher will be unable to escape. Check that water can flow through your waste pipe freely.
    Filter
    • Remove the bottom shelf from inside your machine and take out the plate covering the filter area. If you don't rinse your plates before you put them into your washer, food debris could block your filter and stop water from reaching your drainage pipe. You can unblock your filter with your fingers. Turn off your machine's power before you attempt to do so.
Feb 02, 2012 | Dishwashers
My hotpoint wmd962 smells of stagnant water and the clothes come out smelling worse than when they went in?
By the sound of this, the waste pipe is probably connected under your sink. If this is the case then water flows back from the waste pipe and u bend. Just check and ensure your grey waste pipe is raised above the level of the u bend this should stop the problem. Also use a little soda crystals to clean pipes. Hopefully this will resolve your problem.
Aug 13, 2011 | Washing Machines
I have a Bosch Exccel 1400 Express washing machine which has given good service now about 5 years old, Last week I noticed a stale smell as I opened the drum after the washing cycle had finished. I am a...
Hi from retired Englishman in SW France @ 21:25 Wed evening.
Someone else had this sort of problem about a week ago.
I asked him the question 'does the drain pipe go into a sink u-tube?'' because water from clothes does not smell, especially after washing and rinsing. Sink water CAN smell, especially if there is a partial blockage/sludge in its u-tube which would be shared by the washer. BTW I believe this was his problem.
There should be water in a (non-sink) washer waste pipe u-tube blocking any smells from the rest of the waste system. I suggest checking the sink/washer waste set-up first.
Also, have you cleaned the lint tray/filter recently? If not it could be a build up of sludge there.
If you unaware of where it is (on our Bosch front loader) it is behind the front lower panel - but before starting-
REMOVE POWER FROM THE MACHINE AND HAVE A WATER RECEPTACLE AND/OR RAGS TO SOAK UP ANY WATER when the filter cover is removed.
One or other of these should cure your problem I would expect.
If you have trouble removing the filter put a comment on this entry and I will receive notification that you have done and get back to you.
John C
Feb 02, 2011 | Bosch Washing Machines
My sanivite 3 has a washer connected to the bottom inlet and a sink to the top inlet. when water is run from the sink the system will pump the water out, however when the washer is discharging waste the...
A washing machine discharges water water at a very high velocity and high capacity. This is far more waste water than the pump was designed to handle. The washer discharge must be connected to what's called an "indirect waste", that is, it must discharge into a laundry tub or sump, so that the excess can be stored until it can be taken by the pump. The specific code that governs this is in chapter 27 of the International Residential Code.
Also in the manufacturers instructions, they allow the discharge from a washing machine ,through an indirect waste. [sic] "The Sanivite is a drain pump that is ideally suitable for use in a basement apartment or anywhere in the house where additional fixtures are most wanted. It will pump waste water away from a variety of sources such as: a kitchen sink, laundry sink, washing machine ***(indirect connection)***, dishwasher, bar sink, etc."
This pump will never be able to handle the discharge directly and you need to provide a receptor to accommodate a washing machine. Is there any possibility of adding a laundry tub adjacent the washer and Sanivite pump?
Feb 09, 2018 | Saniflo & Saniplus& Macerator Pump
We have a very 'stale' smell that eminates from our washer. It seems as though there is standing water under the tub, too.
Hi just read your posting.You mentioned in your posting that you have water under the bowl,Is this correct?Can you see the water or hear it when you rock the machine?Where is your machine draining to,is in the laundry sink or some where else?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 05, 2010 | Fisher and Paykel Washing Machines
Whenever I start my LG washer, it smells like sewage in my Laundry Room and then the smell goes away? I have tried running my laundry room sink to see if it's a plumbing issue but that doesn't work.
sounds like you need an anti syphon valve to be connected in line with your washing machine waste water outlet
Check that hose discharge from washing Machine loops up above the minimum height as specified by the machine manufacturer and at least to the underside of the work top for an inset sink before connecting into the sink trap.
http://www.wickes.co.uk/invt/420182
Oct 21, 2009 | LG WM2688HWM TROMM SteamWasher
Smell while washing only
Like bad eggs ?
Do you have a U bend in the wastepipe that takes the water away from your machine
If not then any smells from the pipe run can come back up the outlet pipe
Once you have ran the machine it flushes away the old water and the smell goes away
Jun 17, 2009 | LG WM-2277HW Front Load Washer
Washing comes out smelling horrible! Any ideas?
It is not the washer that is causing the prob, more likely to be coming from waste pipe, and or sink if the pipe is connected to the sink waste pipe.
Check and clean filter in washer if it has one, and remove waste pipe from washer and check outlet is not partially clogged up with sediment and other substances.
If pipe goes into sink waste, then pour a sink pipe cleaning fluid of some description down sink waste.
Also make sure you are not doing too many low temp wshes, as this can cause a prob as well
Do a boil wash at least once a month without clothes in but with powder in.
This is called a maintenance wash, and helps keep the inside of washer clean, and free from smells.
Please rate my solution.
Thanks.
May 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
1) laundry smells bad after wash & 2) leaking conditioner
Check that your overflow pipe is higher than the pipe it goes into. As sometimes waste water, as it drains from the sink after washing up etc, will leak into your machine, and stagnate.
Best of luck.
Tim.
Mar 31, 2009 | Washing Machines
Rotton egg smell
The smell is simply residual biological washing powder doing its job and eating away at the mess and muck in the tube (along with the smell of rotting bits of lint and other rubbish. Dragging the garden hose into the house and flushing the pipes out with some clean water under pressure may help. Also, you may find thattitting the machine on its hottest wash, with about 4 dishwasher tablets in it may also help. Dishwasher tablets have detergent and anti-bacterial agents in them that kill the bacteria that is in biological washing powder.
Jan 03, 2009 | LG WM2496H Front Load
Hotpoint WMA64 Front Load Washer Logo
144 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
