Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch aquatech WFP3201- fault FO3 stopped spinning
2 Suggested Answers
SOURCE: F05 Fault code
this will be the motor brushes
Posted on Jul 29, 2009
How do I clear error code F from Bosch Aquatech dishwasher?
unplug from wall for a few minutes and see if that helps
Aug 25, 2018 | Bosch Washing Machines
All wash cycles keep prematurely stopping. I am not getting any error codes.
The programmer itself might be at fault
No cycles complete .... but does the machine stop at the same part of each cycle, i.e. the rinse or the spin. If it does you can
ascribe the fault to a particular component.
If it is stopping at different points it would probably be the programmer.
A technician should be able to definitively diagnose the fault
Jun 22, 2015 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch exxcel washing machine/dryer
Is it waiting to heat up? Try it on a spin cycle and see if it stops. If not, it may be a thermostat fault or heater element not working. Worst case may be timer faulty
May 21, 2012 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch classixx 6 1400 machine stopped working during cycle f21 on display
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
When your turn it back on it should have cleared the error code
Nov 27, 2010 | Bosch Washing Machines
Hi,when starting the machine on normal wash the filling of the machine starts and stops with the machine ending up over filling,when i put program onto spin it goes through the motions but does not...
If it's over filled it won't spin.
The fault is most likely either with the water level sensor or with the filling solenoid. Both are cheap parts but note the caveat of "most likely". If you buy and fit the parts with no improvement you cannot return them, but a Bosch repair agent can try them and remove them if they're not the cause. The worst case is a failed pcb, but repairing your machine will still be cheaper than replacing it. Barring occasional faults, Bosch washing machines last longer than average.
Sep 25, 2010 | Bosch Classixx WFO 2866 Front Load Washer
I have an aquatech watch and don't know how to set it.
Thank you for contactng FixYa.
Setting the Time and Date
  • To set the time and date on your Aquatech watch, begin by pressing the "Mode" button three times to access the time setting screen. Use the "Lap/Reset" button to set the hour on your watch. Use the "Start/Stop" button to advance the numbers to reach the correct hour. When you've set the hour, use the "Lap/Reset" button to set the minutes, using the "Start/Stop" button to advance to the correct minute. Repeat the procedure to set the seconds, month, date and day of the week on your Aquatech watch.
  • Setting an Alarm
  • To set an alarm on your Aquatech watch, begin by pressing the "Mode" button two times to access the alarm setting screen. Use the "Lap/Reset" button to set the hours place, using the "Start/Stop" button to reach the correct hour. Repeat the same procedure to set the minutes for your alarm. When you have finished setting the alarm, activate it by simultaneously holding the "Lap/Reset" and "Start/Stop" buttons until the alarm icon appears. When the alarm sounds, silence it by pressing the "Lap/Reset" button.
  • Deactivating the Hourly Chime
  • Many Aquatech watch models feature an automatic hourly chime. This can be inappropriate and inconvenient in many situations. To deactivate the hourly chime on an Aquatech watch, simply press and hold the "Lap/Reset" and "Mode" buttons simultaneously. After you have correctly deactivated the hourly chime, the hourly chime indicator icon will disappear from the watch's main screen.
  • Best regards. Jewel
    Sep 18, 2010 | Watches
    Bosch Nexxt 100 series washer stops at 1st spin cycle
    take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
    Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
    F05 Fault code
    Jul 07, 2009 | Bosch Axxis WFL 2060 Front Load Washer
    Bosch Axxis WFL 2060 Front Load Washer Logo
    167 people viewed this question
    Top Bosch Washing Machines Experts
    Marvin
    Marvin
    Craig Butler
    Craig Butler
    Carmen Mikulic
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
