Question about Vizio VW42LF 42 in. LCD HDTV
I have a vol37. when powered on i get sound but no picture. the screen is black with white light in the backround. i've tried all inputs same results. please advise thanks
  • qbase409 Dec 11, 2009
    i'm trying to narrow the problem down to which board or area i should be checking. i have taken the back cover completely off. power on no picture only sound back light is on with black screen. all video inputs same results. please advise. thanks
  • qbase409 Dec 19, 2009
    i have replaced the main board ( with all inputs ) , replaced lcd contoller board and lcd inverter. what else could be the problem? please advise. thanks
  • 2,973 Answers
From the description of the problem, it seems that the video IC of the TV has gone.
Open up the rear cover and take a look inside. Look for some bulged or burst capacitors. A capacitor is that round cylindrical thing jutting out of the PCBs. If found just replace the module for ease or replace the capacitor if you are adapt at soldering. De-solder the item and procure ones of exactly the same specifications. And then solder them back. But make a note of which one from where as they are all different.
Posted on Dec 12, 2009
  • Vizio Master
  • 11,800 Answers
Clearly an electronics malfunction - either in the signal processor or the video final module. The tv must be opened and tested to determine what is to be fixed. Call a repairman.
Posted on Dec 11, 2009
  • Azrael SRL Dec 20, 2009
    I suppose you are sure that the boards you put in are new and perfectly functional. In that case the problem is either in the connectors to the lcd panel or the panel itself.
When turned on, screen goes black, but power light stays green
It sounds that the main digital board to this TV is faulty. Contact any service technician.
Jun 26, 2013 | Sanyo LCD-42CA9S VIZON MULTISYSTEM 42" LCD...
Viore Model # LED42VF80 no sound No picture
Check and replace the main power regulator board.
Mar 09, 2013 | Televison & Video
My LTV-32w6 westinghouse powers on & has sound but displays black screen with very faint colored vertical lines. It shows like this for about 1min before it goes into standby mode & the blue power...
Depends on what is causing it...
Vertical bands of faint black are generally caused by filtering capacitors and can be found in the power supply or the 5 volt supply or even the Video processing circuit...it is not an easy task to identify the source of Video hum bars.....we also call them Jailbars.
Another problem seen is faint black lines caused by the TV set being in 4:3 mode all the time....right at the edge of where the picture ends and the black pillars begin, we see a faint black line that never goes away and is normally seen with a full screen....
That is actually image retention, but it's caused by the crystals that create the picture becoming polarized or ionized over a very long period of time....and it's not easy to DE-Polarize them !
But there are some theories out on how to do that....
Certain people suggest running the TV overnight with an ALL-WHITE picture and some suggest an ALL BLACK PICTURE...and some suggest alternating between both !!
Now, a black picture is easy to make, you just deactivate the Video Mute (blue screen) and set it to an unused Video INPUT overnight....
About the only way to make a white screen is to use the USB port for pictures and take a very bright outdoor shot of a piece of white paper that hopefully is out of focus too....That would create an all-white picture that you can plug into your TV set overnight....
Now if you decide to try this, deactivate any displays on your TV set...all you do is press the display button until the Video and/or USB input numbers disappear....
Next day , set it back to normal TV and see if it's gone or if it's REDUCED....try it again if needed, or try the exact opposite if you see NO RESULTS....
Sep 20, 2012 | Westinghouse Televison & Video
Sony Wega Kv-36XBR250 screen blinking
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Sep 02, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Screen turns black with white dots when i turn on my xbox 360
unplug all cords and reconnect them firmly should fix problem
Aug 05, 2009 | Microsoft Xbox 360 Console
No Picture on a Hitachi 42EDT41A
Then it is probably not cold solder joints. You wouldn't think that an lcd TV would need a high voltage transformer but it does. They are very small compared to CRT televisions but they power up the screen. Without it you have no backround light to veiw what is there. There are two neon lamps on either side of the screen but they rarley go bad. My guess is the transformer ot the power supply feeding it.
Jul 25, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Sony KDL-40V2500 Screen is white
Remove the LVDS cable, the one going to the input of the tcon board and see if it goes dark, if it does the Tcon board has failed
Jan 29, 2018 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Gray backround
Does your scanner software give the option to choose different modes...grayscale, color, black & white?? This sounds like it's scanning in grayscale....if you can change it to black & white, the background should remain white.
Jan 24, 2008 | Epson Perfection 1670 Flatbed Scanner
Toshiba 46HM84 DLP Black and white pattern..
contact your dealer for service flashfor this symptom.(light tunnel)
Aug 11, 2007 | Toshiba 46H84 46" Rear Projection...
Vizio VW42LF 42 in. LCD HDTV Logo
63 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
