Question about Whirlpool Dryers
Whirlpool dryer model AWZ8477 wont start, have cleaned filter, emptied tank but cant locate heat exchanger to clean that, lights are all on but won't work
  • 3,230 Answers
Well first of all you can check the Door switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Then you check the Thermal fuse -
There's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Please post comments for more help or information.....
Good Luck!!
Thanks
Posted on Dec 19, 2009
Why is warning lights on on my AZC6470 Whirlpool condenser dryer when i have cleaned heat exchanger/filter and emptied water container
Not trying to be a smartass but what does the manual say about the warning lights as in what do they refer to.
Oct 09, 2014 | Whirlpool Dryers
DEHUMIDIFER WONT START
empty the tank, and clean the dust off of the condenser in the front or clean the filter. if it still won't turn on, may have a bad sensor or a siezed compressor.
May 09, 2012 | Midea Dehumidifiers
Hello I have a Beko CRS 68 W condenser dryer (18 months old). I have cleaned out filter and Big unit at bottom ( Which I think is the Heater Exchange unit ) as instructed - However when we put a fresh load...
Clean the exhaust line connected to the rear of the dryer.
Run a load of laundry with the rear duct removed completely and see if the light comes on.
Mar 10, 2011 | Dryers
My whirlpool awz7303 is not get hot so there for my clothes are not drying. i have checked the filter, water container and the heat exchange they are all clean and empty but the filter indicator light is...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 19, 2010 | Whirlpool AWZ7303 Electric Dryer
Problem with whirlpool condenser dryer,light on to say empty water bottle but after doing all that and cleaning it out it still wont reset. HELP PLEASE!
Empty the bottle and then unplugg the dryer. Plugg the dryer back in and see if the empty light goes off.
Apr 04, 2010 | Dryers
The empty water wanrning light will not go out. I
there is a float switch at the pump that has become stuck, and when this happens, the "empty water" light will stay on and the machine will operate but with no heat. just locate the floating switch and give it a light tap back into its place, this will solve your problem.
should you have any problems you can email me at appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 02, 2010 | Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Maintenance lights won't go away
elaine hopefully this will help. advance your selector dial to the 6 o'clock position, press start 3x. advance your selector dial to 7 o'clock position, press start 3x. turn the unit off then on. try using it as normal.
Apr 24, 2017 | Whirlpool Dryers
Dryers Logo
97 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
