Question about As Seen On TV Sewing Genie Mechanical Sewing Machine
New Sewing Genie doesn't sew
I just got a Sewing Genie for some small projects and was unaware of the issues others have had threading the bobbin. I am assuming that is probably why I can't get the thing to sew a stitch. The needle just runs through the cloth and nothing happens. The only instructions I received are in French. I have also read online that the instructions for threading the bobbin aren't accurate anyway. Can someone please tell me how the thread the bobbin correctly so I might be able to use it?
  • 4 more comments
  • LynneSW Jan 20, 2008
    Winding the bobbin isn't the problem - getting the machine to sew anything is. The needle just runs through the cloth and doesn't sew at all. It may be a whole other issue besides getting the bobbin to thread. I am just at a loss.
  • Anonymous Feb 27, 2008
    I can't figure mine out either and don't have the instruction manual. Definitely need some help!
  • Anonymous May 26, 2008
    I have the same problem. The needle just run through the cloth and can't pick up the thread from the bobbin. As the expert pointed out the problem is "timing is off". Then how do you fix that kind of problem?
  • nomadicval Oct 07, 2008
    Mine was working fine. I paid attention when taking the bobbins out as to how it was threaded but when I replaced it, following the directions, its not sewing correctly.
  • dee1986 Nov 14, 2008
    i have the same issue as these other users - i was so happy to get it when i first received the gift, but after trying to thread it myself, even with all polyester thread, it will not work.
  • beverlee1978 Dec 22, 2008
    i tried using my machine right out of the box ~ after one or two lines of stiches, it quit working! i havent used it since and now it just collects dust. what a waste of money.
    -Bev
  • 397 Answers
They are not accurate, but also this machine is not the greatest with all types of thread, try using rayon or polyester thread when trying to wind a bobbin (cotton thread on these machines are typically sometimes hard) let me know and if this does not work ill send over what I have as far as directions
Posted on Jan 20, 2008
  • Custom Exchange
    Custom Exchange Jan 20, 2008
    then the timing is off, thats the problem
6ya staff
SOURCE:
How do I adjust tension on a Janome 1600p-qc for machine quilting?
Adjust the tension the same way as sewing regular projects. You want the top and bobbin threads to meet in the middle of the quilt sandwich. When quilting, I use a lighter weight thread so I have a separate bobbin case whose tension has been tightened specifically for quilting. For other sewing projects using a standard thread weight, I use a bobbin case that is factory set and then adjust the top thread tension for each project.
Aug 04, 2017 | Janome Sewing Machines
I have a singer prelude sewing machine - the thread started binding from the bobbin up - there were about 50 threads pierced through my test patch.
what you describe is thread bunching and is typical of the needle thread tension being too loose
adjust that right up, run a test sew and go from there
Aug 07, 2016 | Singer Sewing Machines
Sewing Machine is unthreading itself.
I don't know the answer to your question but I have a thought - someone recently asked why her sewing machine motor was running backwards.
I wonder has your machine motor suddenly started running backwards and if so would that cause your problem?
Jun 22, 2016 | Sewing Machines
Consew 206rb1 stopped sewing
Have you tried a new needle? Needles should be changed out before each project and if a large project, several times during the project.
May 16, 2014 | Sewing Machines
Toyota quiltmaster
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread the top.
Be sure that your top thread follows the correct thread path.
Set the top tension to the midway point.
Re-test your machine.
Tension is a tug-of-war between the top and bobbin threads. Correct tension is when both threads meet in the middle of the fabric. If the bobbin thread is laying on the underside of the fabric, the top tension needs to be increased so it will pull the bobbin thread up into the fabric. If the top thread is pulling the bobbin thread up to the top of the fabric, then the top tension needs to be loosened.
TIPS:
FWIW, thread tension is not static. Tension will need to be adjusted probably every time you start a new project. Test it on a piece of scrap fabric from the project and adjust it BEFORE beginning the project. Remember to change the needle often--probably every time a new project is started or every 8 hours of sewing time. Be sure to use the correct type and size needle based on the fabric & thread you are sewing. Also, AVOID old or bargain bin thread!
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Learn the Ins and Outs of Troubleshooting Sewing Machine Tension
All About Needles SCHMETZ Needles
Nov 24, 2017 | Sewing Machines
HOW DO YOU CHANGE FROM ONE COLOUR BOBBIN TO THE PREFILLED NEXT COLOUR BOBBIN
hold thread end w/3" length and put the it in the bobbin case and make sure its unwinding clockwise..Feed thread thru the higher left metal notch and pull to lower left notch and make sure the thread stays behind the spring slot and leave about 4"tail...put bobbin in its place lining up the white dots close the case and turn the wheel to drive down needle holding the needle on the machine base losely and draw the bobbin thread up
Mar 22, 2013 | As Seen On TV Sewing Genie Mechanical...
I cant remember how to fill the bobbin with thread :(
Insert the empty bobbin case onto the bobbin winder in the sewing machine.
Step 2 Set the spool of thread onto the thread peg. Use the same thread you want to use on your material to obtain the best finished stitch.
Step 3 Follow the arrows or guides to take the thread from the spool to the empty bobbin.
Step 4 Start the thread around the bobbin in a clockwise direction.
Step 5 Push the small lever against the bobbin spool to hold it in place. This disengages the needle so it won't go up and down while winding the bobbin.
Step 6 Press the foot or knee pedal to start the winding process. Stop when you have enough thread on the bobbin for your project.
Step 7
Cut the thread between the thread spool and the bobbin. Insert the bobbin into the bobbin case so you can begin sewing.
Open to clarifications.
rate this.
Jan 10, 2010 | Janome Jem Silver 662 Mechanical Sewing...
Replacement bobbin for sewing genie
They are all the same . And its ok buy one and try it out.
Oct 07, 2008 | As Seen On TV Sewing Genie Mechanical...
Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Jul 29, 2008 | Singer Inspiration 4210 Mechanical Sewing...
As Seen On TV Sewing Genie Mechanical Sewing Machine Logo
729 people viewed this question
Top As Seen On TV Sewing Machines Experts
Harjeet Singh
Clive
Clive
R.A. Ellis
R.A. Ellis
Are you an As Seen On TV Sewing Machine Expert? Answer questions, earn points and help others
