Question about Canon FAX-JX200
New cartridge in. coming up ink levels unknown
  • 159 Answers
If it still prints, ignore the ink level indicator. If it won't print, then you need to get a new cartridge.
Posted on Dec 21, 2009
My cannon mp210 is flashing E 1 6 what does that mean and how can i resolve it
E16 means that the Ink Level is unknown, if you refilled it somewhere it would cause this error to come up. The only way to make this go away is to disable the Ink Level Detection by holding Stop/Reset for button for about 9 seconds. It should now work properly but it will be unable to tell you the remaining ink level. The only way to get it to tell you this information would be to replace the ink cartridges.
Mar 28, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Problem code 6E1 canonpx250 printer
Hi
Error code E16 indicates that remaining ink is unknown.
It is common problem in refilling the cartridge. To fix this problem you need to deactivate ink level detection function. Follow this procedure: press and hold STOP/RESET button for about 9 seconds or more then release it. Now E16 has disappeared and the printer should work properly. As consequence, ink volume in panel become UNKNOWN. No problem. It will be back to normal condition when you replace the cartridge with new one. good luck !
Jan 10, 2011 | Canon Office Equipment & Supplies
The cartridges are new and after every print request an error message comes up that says "The Tri-color print cartridge has been previously used" then teh main message says "The ink level indicator and low...
run the nozzle setup to clean and identify your new cartridges inserted on your printer.
Go to your printer maintenance to open the Nozzle Clean ICONS, good luck!
Jul 22, 2009 | HP DeskJet 9800 InkJet Printer
COL INK VOLUME UNKNOWN MESSAGE
Something that worked for me, I opened the Conon MX310. took out both cartridges, and for 10 seconds I held the Reset. put the cartridges back in, closed the lid, and again, for another 10 seconds held the reset. SLOW seconds. this reset, ink levels recognised,, and it's working as it should be.
Regards
Shane (AKA Reef_Lex)
Jan 03, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon ip1600
Dear hoppygink,
Canon pixma ip1200 series (ip1200,1600,2200) identify the first new cartridge installed in the printer and detects ink level properly unless you put another used cartridge or you its own cartridge to another printer. Once you do this, ink level of the cartridge become unknown. So, never exchange its own cartridge with another ip1600 printer. This will be back to normal condition when you replace with new fresh one catridge that never used before. This weakness has been improved by canon in pixma ip1300 series (ip1300 & 1700) anyway.
To prevent this problem occurs, you need to back up EEPROM data of the printer by using EEPROM restore tools before perform cartridge exchange. I will discuss this in Canon Inkjet Forum in the next coming chance. Please send me your email to: ijxpert@gmail.com so I can notice you immediately after posting the topic.
Regards,
Dec 12, 2008 | Canon PIXMA iP1600 Printer
Hi, my canon pixma mp210 shows error 61 or 16 after refilling black ink... ? thanks!
Dear cappina,
Error code E16 indicates that remaining ink is unknown. It is common problem in refilling the cartridge. To fix this problem you need to deactivate ink level detection function. Follow this procedure: press and hold STOP/RESET button for about 9 seconds or more then release it. Now E16 has disappeared and the printer should work properly. As consequence, ink volume in panel become UNKNOWN. No problem. It will be back to normal condition when you replace the cartridge with new one.
Regards,
Source:
Canon Inkjet Forum
Dec 11, 2008 | Office Equipment & Supplies
Canon pixma mp210 printer - replaced ink cartridges with compatible ones - printer working fine except when printing both ink lamps come on solidly, not blinking, and status says there is no ink in...
Dear merryan,
This printer uses FINE cartridge which has memory chip inside that store ink level data. Once the cartridge is EMPTY we cannot restore this data to be FULL even though we physically refill ink until FULL. So the printer keep displays NO INK warning.
Similar with using compatible cartridge, NO INK warning still remain because ink level data has been recorded as empty. Why?. Here is the explanation. As far as I know no third party compatible cartridge produced this printer since canon protect it with the chip. Compatible cartridge that sold in the market is refurbish cartridge which repacked with another brand.
To fix this problem we need to deactivate ink level detection function by holding down STOP/RESET button for about 9 seconds or more for each cartridge. The consequence of this is ink level become UNKNOWN.
Hope this will be helpful to you
Regards,
Xanda
Nov 08, 2008 | Office Equipment & Supplies
Printer Toolbox Not Recognizing New Black Ink
The Deskjet 6940 will only show ink level for original HP cartrdgies. Refilled or reman cartridges will show as empty or unknown in the toolbox. This is not an issue with the driver, the cartrdige itself has information that it has been previously used and this is not resettable. You can continue to print with a cartrdige that has unknown ink levels, you will just not get low ink warnings.
Regards,
Bob Headrick, Micosoft MVP Printing/Imaging
Apr 24, 2008 | HP Deskjet 6940 InkJet Printer
Ink problems col vol unknown and wont print
Regards
Jul 27, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon FAX-JX200 Logo
175 people viewed this question
old marine
old marine
