Question about Boston Acoustics BA265 Computer Speakers
I need a power pack and all I know that it is a 12v system and that's all Help
  • 26 Answers
Buy a universal power suply that should work
Posted on Dec 11, 2009
Need AC power cord for task force model 202754 tire inflator
This a battery jump pack that is used to jump start a car. Some units have an ac adapter built in so you can charge the battery in the jump start pack. My unit has a spot to connect the ac adapter to the jump pack so you can charge the battery in the jump pack. My ac adapter has been lost. I know I have to buy a new ac adapter so I can charge my jump pack, what I do not know is if the input (from the ac adapter) is 120v 60 hz
I understand that the DC output needs to dc12v. I do not understand the milliamps. The battery in the jump box is 12v 10 ah ( what ever that is). I just want a new ac adapter to charge the jump pack with that is not going to damage anything.
Oct 19, 2017 | AC Cars & Trucks
I need a replacement Power pack 12V-3A 36W. Can you please tell me where I could get one from?
Cherryl, You could try local stores that sell computers and electronics, Walmart, the source, staples etc. Check the attached links,for power pack/charger, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Premium 4 8 1 7mm Replacement Power Supply Cord Laptop Battery Charger...
Genuine Asus LCD Monitor 12V 3A 36W Ac Adapter Charger ADP 36EH
Laptop AC Adapter 12V 3A 36W 1 7 4 8mm
Amazon ca power supply 12v 3a
Apr 28, 2016 | Computers & Internet
Ml200rt timer does not work
More information is needed.
What is not working? The electrical outlet, the transformer, the rotating clock, or the bulbs?
Open following troubleshoot walk-through for checking each problem, plus power pack tips, trippers and warranty links.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Oct 02, 2011 | Intermatic 200W Power Pack With 12v...
MY 1999 SUBARU LEGACY B4 has the power light flashing on the dash board every time the engine is running, i have tried checking for mechanical problems through a computer but it shows me that nothing is...
You should rule out a failing alternation tri-diode pack first
When one or more failed diode(s) on the tri-diode fail AC ripple voltage will leak to the 12V DC circuit.
When small amount of AC ripple leak out to 12V DC circuit sensitive electronic like ECU,alarm system will not work well.
The easiest method is go to a good auto parts stator and ask for a in car alternator test.
Make sure they has a Midtronic or similar unit that can check the diode pack.
Sep 10, 2011 | 1998 Subaru Legacy
Would like to purchase AC Wall Adapter for : Power on Board 450amp VECO12P0B
Call Schmacher at 1-800-524-3880 and they can set you up with a replacement. Don't be shocked at the shipped total cost. You just might want to
Your power pack will tell you what voltage wall charger you need. Where you plug one in, it will show 12v, 17v...etc. Yours is probably 12v. On the right side of the connection hole, if you see a + sign, your pack requires positive polarity when you attach an adapter. You can find universal power adapters with an adjustable output and various tips that is sure to work well with your pack. All tips will have a + sign on one side and a - on the opposite side. Just make sure you put the correct side of the tip (- or +, depending on what's on the right side of charging hole on your pack) on the same side of the wall adapter's wire connector end that has the word TIP on it or some other demarkation.
I wish you the best of luck.
Sep 07, 2011 | JUMP START SYSTEM
My kids were playing the Wii & the power went out. Now I cant get it to come back on. Any ideas?
hi the only real thing you can try yourself is resetting the power pack, to do this you need to unplug it from the mains and also unplug it from the wii, leave both ends unplugged for at least 5 minutes, doing this activates the reset procedure inside the power pack, then plug it back in and give it a try.
if it still dont work then the chances are you need to replace the power pack, the chance is the power pack got fried and not the wii as the wii only needs 12volts from the power pack so this shouldnt cause any harm as the power pack reduces the power down to 12v so if it wont work try replacing the power pack or try using a friends power pack just to test it with.
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Dec 05, 2010 | Nintendo Wii Console
Power pack creates 'hummmm' in wireless headphones.
I don't think the 12V power pack is the problem. Generally there would be a regulator on the plug pack input to the transmitter (as power packs are notoriously bad at voltage regulation).
My guess is it an 'earth leak' between the TV and the transmitter via the audio lead. Does the powerpack have a earth pin. If so, are you able to plug it into an non-earthed power outlet.
If this isn't possible try removing the ground connection from the audio lead.
It could also be a bad audio lead.
Is the TV mono and the transmitter stereo or visa versa? You may need a mono to stereo lead.
Hopefully something in here will help.
Mar 17, 2009 | Electronics - Others
Power pack creates 'hummmm' in headphones.
GKLHKJHKLHKLHKLHKLHKJLHKL
please rate this solution?? hahaha lol here you go
Mar 17, 2009 | 1996 kawasaki ZZR 1100
1800FP green LED is on, screen is black
power pack has issues could be a chip on the power pack or some capacitors on the power pack. the power pack supplies power to the inverter.
Feb 20, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted...
i have the same probleme . I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted to know which is the correct product to buy please
Sep 08, 2008 | Iomega (33090) 250 GB Hard Drive
Boston Acoustics BA265 Computer Speakers Logo
89 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
