Question about Gigabyte K8N-SLI (GAK8NSLI) Motherboard
BSOD when i try to use 4gb ram. what is the problem? (bios F10D)
  • 5 more comments
  • skdenes Dec 11, 2009
    I have win7 x64 and i use 4gb DDR400memory ( 2x2Gb pair).
    When i allow the motherboard to use the whole memory the windows start to freeze .
    I have read a lot of post with the same proble same chipset(nforce 4) but different motherboard . Their problem was solved when they used the lastest bios, but as you can see this solution is not good for me
    I 've bought this ram about 2year ago,so yes i tried some 64bit system:D
    Sorry i have 4x1 Geil ,DualChanel not 2x2 :D..
    I always format before the installation and i have already tried to switch.:(
  • Adnan Bhatti
    Adnan Bhatti May 11, 2010
    If after installation of RAM, you have formatted the C drive and installed a genuine version of Win7, you should not encounter any BSOD. I suggest you re-install Win7 after completely formatting your C: drive (after backup of course). If this hasn't solved your problem, try switching the RAM in slots.
  • Adnan Bhatti
    Did you reinstall Windows from scratch after upgrading the RAM? If you have not, I'm positive that it will help.
  • Adnan Bhatti
    What OS are you using (or intend to use);32-bit or 64-bit? What type of RAM are you trying to install? This motherboard supports Dual Channel DDR400 memory.
  • 37 Answers
4 gb ram only support in 64bit windows.
Posted on Dec 12, 2009
I upgraded my memory to corsair 4gb 1600 ddr3 ram on my samsung rc410 laptop. BIOS is showing the 4gb but windows is not booting up, it is showing blue screen. i have tried in another dell laptop but it...
i would take out all ram , then just put in the 4gig
there is 2 slots for ram
if that is the same then windows may have crashed , try getting into safemode by pressing f8 after bios
Oct 30, 2013 | CORSAIR 4GB - PC12800 RAM, DDR3, 1600MHz,...
Installed 4GB upgrade in optiplex 330 still only 2GB memmory
Your BIOS should automatically detect your new RAM when your computer starts, try starting your computer after removing your old RAM module, if it starts, you need to update your BIOS to use 4GB. If it doesn't start, you either have a faulty RAM module or a faulty connector on your motherboard. Insert the new RAM module into the slot the old RAM module was in, if your computer still refuses to start, you have a faulty RAM module which should be returned, if it does start, it's the connector on the motherboard, and only replacing the entire board will fix the problem. However, it's worth noting that your motherboard will only support RAM modules of 2GB or less, the above was written with the assumption you're adding an additional 2GB module to your Dell computer.
Dec 24, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
Blue sceen ASUS 3 Motherboard - M4A88TD-M EVO
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Tracey Laidler.
Yes you are quite correct BSOD or Blue Screen Of Death is normally due to a memory fault. However drivers are as big a culprit, especially seeing as though you have changed memory modules and processor.
Install all the drivers for this mainboard.
Also enter the BIOS/CMOS by tapping the Delete key during first powering on the computer.
Once in the BIOS/CMOS select the option to load defaults.
Check if that works.
If not then take it a step further by clearing the BIOS/CMOS by removing the silver button cell from the mainboard for 10seconds before reinstalling it in the correct orientation.
Take care!
Dec 15, 2011 | ASUS 3 Motherboard - M4A88T-V EVO/USB
Installing XP = BSOD
Hello
Without the actual info from the BSOD, we have to provide general troubleshooting tips.
Since Windows is not yet loaded, it cannot be a driver or software issue - so we need to look at the hardware.
Typically, a faulty or unrecognized RAM stick and / or an unusual BIOS setting can cause this issue.
Go into the BIOS and reset the BIOS to factory defaults, remove all CPU overclocking.
Remove all RAM and try booting with only 1 stick installed.
If this does not work, try and give the error message from the BSOD and we can look into it for you.
May 01, 2010 | ASUS P5RD1-VM Motherboard
Hi there. I have an HP a6500f. Came pre-loaded with 4GB RAM. Worked fine for a year then started freezing/restarting/BSOD randomly. Ran memory diagnostics and got a BIOME-1 error with both sticks, but...
Try manually setting the ram timings in bios but....
i would think its a motherboard issue too by the sounds of it. find one that has a similar specification and fit it, I will suggest one if you need me to, just give me a list of the hardware you have installed on this current machine
Jan 14, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
Dell Lat d620 duo: ran a full system scan yesterday as I normally do for maintenance and got the BSOD. Message: page fault in nonpaged area. Tried all options to reboot, always eventually gets to BSOD and...
Take out the memory and replace with the old one.
If you have a 32 bit Windows and have more that 4GB RAM then you need to upgrade to 64 BIT.
This is the RAM you need:
Standard Memory : 256MB (Removable) Maximum Memory : 2GB Total Memory Slots : 2 Memory Type : DDR2 533MHz (PC2-4200) 200-PIN SODIMM Notes :
http://orcamemory.com/asp/prodtype.asp?prodtype=11759&ft=m
Jan 06, 2010 | Dell Latitude D620 Notebook
New system hangs at p.o.s.t
I would first clear the cmos. Then try to get back into the bios and check the ram voltage setting. My Asrock board AOD790GX128M had me use the #3,4 memory slots, the #1,2 gave me the bsod. You may want to try that also. I hope this helps you.
Aug 13, 2009 | Asrock 4CoreDual-SATA2 Motherboard
Im not sure how much ram to use with my motherboard.
Your board can support 4Gb of RAM.
CLICK HERE for the SPEC sheet.
HERE is the memory support list, there is only 1 type of KINGSTON 2GB stick that is listed as compatible.
Make sure you have the latest BIOS as there are some known issues with this board and certain 4GB RAM configs as well as fixes for 1TB HDD space errors.
Always a good idea to make sure you have the latest XP service pack. In general, XP only recognises 3Gb RAM but mine runs fine with 4 in it.
When you crash, is there any Blue Screen of Death (BSoD) or any other output to your monitor or does it just shut down with no warning or error code or anything? If this is happening then you may be getting a CPU OVERTEMP condition.
Have you recently upgraded other components as well as your RAM?
Mar 26, 2009 | Intel Motherboard
A8N32 BSOD PROBLEM
I had a similar problem with this board after putting in a new sata drive I got Bsod as windows xp started loading.
There is some kind of conflict with SP3, Sata and usb.
The solution for me was to boot while having a 4GB usb drive pugged in. It starts up fine now. If I remove the usb drive it bsod´s again.
Dec 14, 2008 | ASUS A8N32-SLI Deluxe Motherboard
Eversham laptop voyager
Flashing the bios is a very bad idea if your are having bsod. If it crashes during the flash then the bios chip wont work anymore.
Also flashing bios wont fix the bsod problem.
Could you give more detail about how the bsod happen?
Download memtest and run that from bootble disk to check if the ram is functioning properly.
Dec 31, 2007 | Evesham Voyager 5800 Notebook
Gigabyte K8N-SLI (GAK8NSLI) Motherboard Logo
89 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Computer Links
steyr1
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
