I have a Magnavox 46" projection TV model PTV-370-AH01 The picture is so light, I can barely see it, I've tried to adjust it with little sucess Is there anything else I can do?
  • Vze6msi9 Dec 11, 2009
    Ok Rylee, could you email me more information, on how to replace part and where, I can buy new ones
    Yes, just tell email me how to change parts and where to purchase new ones
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and check power resistor for leakage, if values are not exact replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Dec 11, 2009
Based on the model number can you confirm the screen size ? Model #PR3446 A106. I believe this would be a 34" screen, would that be correct? It was damaged in a fire and I need to figure replacement...
Hi.
This is actually a Magnavox tv, but Philips-Magnavox is all one company so it's ok.
The tv is a Magnavox model # PTV515-AH01
This is a 46" projection tv.
This model is no longer made, as it is older technology, but I am sure that there is something of equal size and quality available for you to get.
I would probably get something like a Panasonic Viero tv.
They have excellent picture quality, multiple inputs, hdmi jacks, and have a good warranty as well.
They usually run around $450-$550 U.S., so they are a great value.
I hope this helps you out on your decision today, good luck to you, and have a good day !
May 24, 2011 | Philips Televison & Video
Magnavox rear proj (model# 8p6044 c102) pic is cloudy/green tint
Yes the coolant gets crud buildup in it over time which will cause the color and clarity to get very poor with obects that will glow around certain bright ojects. You can get the Phillips CRT coolant replacement kit from www.tvrepairworld.com which has the CRT coolant for all 3 CRTs and also includes the Cd with instructions on how to do the replacement.
Mar 27, 2010 | Televison & Video
Phillips magnavox 50" projection TV shows a light picture
it sounds like the tv is going out. you might call a repairman before it does so you dont lose the tv.
Jan 27, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Power light comes on and goes right off
Take a look at the blue round capacitors. They stand on end and about the size of a dime and 1/8" thick. They should be by the highvoltage transformer. That's the plastic box with a spark-plug wire sticking out the top. The circuit board should have numbers printed by the parts. Look for c811 or C8** . The C means capacitor and the 800 numbers means the circuit it's in. This is a horizontal output capacitor your looking for. You will see it burnt. Might not be blue...could be yellow or orange. But you should know what kind of capacitor to look for by the description I gave. This seemed to be a problem with these sets....or atleast one problem of MANY. If it's not that, then you need big time service. I wouldn't waste your money on a Magnavox. They just don't hold-up to repairs very well. If you find the burnt part, let me know what the location is...C8**....and I'll tell you what the value is. You won't beable to read it if it's burnt. Now atleast you know what your looking at. Sometimes if you have someone turn the set on while you look at the board in a dark room, it will spark. Hope that helps. Good-luck.
Dec 22, 2008 | Philips Magnavox 51MP392H Rear Projection...
Color lights show thru screen
check for loose wires and check that all the connectors are tight.
Jan 09, 2008 | Philips Magnavox 51MP392H Rear Projection...
MAGNAVOX 50 INCH REAR PROJECTION Hor. Output Tran Keep Going Out
Try checking some of the tunning and coupling capacitors around the horizontal section as well for some crystalized solder joints in that area.
Jan 06, 2008 | Philips Magnavox 51MP392H Rear Projection...
Remote Control for Magnavox Big Screen TV (PTV 705-AH01)
sgtdar, list the model & chassis number (located on back of tv), if set is old the universals won`t work because as more newer sets come out they delete the older ones because the chip in the remote will only hold so many codes, BMW Rider
Dec 12, 2007 | Televison & Video
Adjusting colors on a magnavox 46" projection TV
Replace the CRT fluid. It grows algea in the blue and green only. 9.99 from MCM electronics.
Oct 19, 2007 | Philips 46PP9302 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
