I have a Magnavox, Projection TV, Model PTV-370-AH01 46", the picture is so light, I can barely see it I've tried to do, All i could to adjust it, but I still can barely see it, is there anything, I can do?
  • Vze6msi9 Dec 11, 2009
    Yes, Thank You
  • 19,396 Answers
If you cannot fix the problem using settings then there may be a fault.
Try leaving the TV with power cord disconnected for ten minutes, this will reset the set to factory.
If the picture is very dim, then there may be a collapsed mirror in the light tunnel.
If the picture settings stay too bright or too dark, no matter what you do with settings, then there is a fault in the Black/White kine bias regulation circuit, located on main board.
Ensure that the problem is not related to cables or connected devices.
You may need to contact a technician. In that case I suggest calling the number listed on the owners manual.
Regards.
Posted on Dec 11, 2009
I have a TV 48" PTV W/RemoteModel 6P4830W TV repair said that it
The problem is not in the bulb but in the display coolant... http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits...The step by step procedures and illustrations are included in the kit.
Sep 25, 2009 | Philips Magnavox 9P6034C 60" Rear...
We have a Magnavox Model 55P8288A Projection tv and it is showing a cloudy and light picture.. Try to adjust color and it won't adjust...It shows a foggy picture...
Replace the CRT coolant. You can get the phillips CRT coolant replacement kit at the following link. The kit contains the coolant and the CD with instructions.
Sep 22, 2009 | Televison & Video
Magnavox PTV910. The picture is good but color is bad
the coolant in the blue and green crts has congealed which is causing the red tube to become dominate. The coolant can be changed at home. You can get the phillips coolant replacement kit at the following link which contains the coolant and the CD with instructions.
http://www.tvrepairworld.com/
Jul 15, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have a VS-526r,VE-526r television and the blue bulb appears larger than the other colors. Any suggestions?
is uot of focus try to adjust or need blue tube replaced ptv is old model tubes no longer available
Jun 12, 2009 | Televison & Video
I have a Slim-View LXI TV Model # PTV 515 AHO1 Has no Picture
while i dont have a true answer, I can tell you its a magnavox tv sold by sears produced back in 93. Ours just started doing this last week. I couldnt find any help online so we replaced it with a new led flat panel. WOW what a difference, the LXI was great for the past 17 years but the new tvs are better. We put the LXI in the garage because we couldnt throw it away. That tv was like a family member, if i figure out how to fix it i will post the how to.
Feb 24, 2009 | JVC Televison & Video
Phillips magnavox 50" projection TV shows a light picture
it sounds like the tv is going out. you might call a repairman before it does so you dont lose the tv.
Jan 27, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Color lights show thru screen
check for loose wires and check that all the connectors are tight.
Jan 09, 2008 | Philips Magnavox 51MP392H Rear Projection...
Adjusting colors on a magnavox 46" projection TV
Replace the CRT fluid. It grows algea in the blue and green only. 9.99 from MCM electronics.
Oct 19, 2007 | Philips 46PP9302 46" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
