Question about Genius MousePen 8x6 (MOUSEPEN8X6)
My pen has irregular motion...its as if it pops over certain sections
  • 2,237 Answers
It needs to be recalibrated. after that if it has the same issue on the same spots, you have a damaged pen or tablet.
Posted on Dec 11, 2009
SOURCE:
What are common problems that cause the tranny to shift harshly when engaging or shifting into rev. On a 95 one ton dually 2 wd automatic with a 454 big block
What most people see as a harsh transmission shift when transitioning from forward gears to reverse gear is really just the drive train taking up the slack in the connections. You need to realize that over time the universal joints in the drive shaft, as well as the pinion and ring gears in the rear differential will experience wear. When you are going forward the drive shaft is turning one direction, the u-joints and differential gears are all taking stress one one particular side. When you shift to reverse, everything reverses. So, the first thing to happen is the front u-joint changes direction. There will be a small amount of slack in the joint from wear. This slack will cause an irregular motion while it is taken up. This irregular motion is propagated to the rear u-joint, which must do the same. It will induce additional irregular motion, which is passed to the pinion and ring gears in the rear differential. In a new car/truck, you won't hardly notice this since all the wear surfaces are new and at factory tolerances. Give the vehicle 60-100K miles or more of hard wear and the result of this shifting to reverse can be a relatively loud clunking noise that can shake the vehicle. Replacement of u-joints can alleviate some of the issue, but the rear end wear can only be addressed with replacement. But as we say.....if it ain't really broke, why fix it?
Mar 07, 2015 | Cars & Trucks
Tv comes up every night with a pop up saying the tv will go off in 60 seconds looked at the settings sleep & power save are off
Is there anything in front of the tv? Some of the new tv's have motion sensors in them that will turn the tv off if it does not sense motion for a certain amount of time.
Jan 25, 2013 | Samsung Hl-r4266w 42-inch Widescreen Hdtv...
I HAVE A MOTION COMPUTING LE 1700 TABLET AND THE PEN WONT WORK AFTER I FORMATTED IT. WHAT SHOULD I DO?
you need to install the Wacom driver available from their site- if it's still available- I have a copy of their drivers if it is not on motion's site.
Mar 12, 2012 | Motion Computing LE Tablets & eReaders
My Wacom Bamboo Pen only works when I have Bamboo Dock open, as soon as it is minimalized, the Pen stops working. Very annoying because i use it for my design work in Illustrator CS5. The Touch-part seems...
Go to the Control Panel, click on the Hardware and Sound link, click on the Bamboo link. Make sure you are on the "Pen" tab. Look on the bottom right for the "Tracking" section. Make sure the "Pen Mode" is selected. Click on the "Details" button, make sure "Portions" is not selected in any of the sections.
If you can't fix it in this section, then your best bet is to re-install.
May 03, 2011 | Wacom (EP130EPE) Digital Pen
Would the crankshaft sensor make my van run bad at a certain speed?
If the crank sensor was bad your vehicle wouldn't start if it was going bad you would have an intermittent starting problem. I would suggest the basics like checking your ignition system (spark plugs, wires, coils etc) and your fuel delivery sytem (fuel pressure at rail, fuel filter etc) If you can describe what the vehicle is doing whether it be a vibration, irregular idle, misfiring, sputtering etc and at what speed or rpm and if it is only while the vehicle is in motion or if it occurs at idle as well, those would be helpful in assessing your situation too.
Mar 03, 2011 | 2004 Ford Freestar
I have just got a 'new' (never used) Motion Computing LE 1600. The pen won't calibrate (way off). The USB mouse works just fine. I have tried calibrating several times. I have installed the latest...
Please check page 22 in the bellow article for how to caliberate the pen.
http://www.motioncomputing.com/resources/UserGuide_LE1600.pdf
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Oct 02, 2010 | Motion Computing MOTION LE1600 Notebook
Pen does not work
There is two sections of the pen. *I have the same tablet from what you described.* Twist and pull gently apart the two sides of the pen. It will open, and the battery pops out.
Aug 17, 2009 | Genius MousePen 8x6 (MOUSEPEN8X6)
How to take apart Intuos pen
Ok, after my wife washed mine in my jeans, i really desperate and decided that I had nothing to lose. I searched all over the web for ways to do this and nothing!!!! So today I grew a pair and tried something and low and behold... so anyway.
*!*!*!* Remove the rubber grip and button first (untwist tip cap and remove threaded section, slip fingernail under top edge of button and pop it straight up and off, slide rubber grip off towards point *just in case*) Grasp your pen in both hands with the tip facing to the left left hand should be grasped covering  the tip and ONLY the section that has the recessed barrel with the raised button ridge. Right hand should be grasped just off of the first diameter reduction from the right (ie. where the just before the pen gets thinner) and covering the eraser (unless you have really small hands) CAREFULLY but firmly pull the two halves of the pen apart from each other !**!*!DO NOT TWIST THE PEN!!!! the pen should come apart without a problem and now you have access to the inner goodness of the Wacom Intuos Pen
Note: when putting the pen back together, be gentle and place the board in the eraser side first, if it doesn't push the eraser tip up, twist it slowly till it slides all the way in (be sure to try to leave a tiny space for eraser play.) Twist the pen (board and eraser cap end) until you can see the two receptors for the buttons, slide the tip end cap on and press firmly until the caps seat together and the holes line up for the switch. slip the rubber cover back on, twist on the threaded tip and clip the button back on, that should do it, Hope this helps!
Malice
Jan 18, 2009 | Wacom (EP130EPE) Digital Pen
I have a HP Professional Deskjet 1220C. It starts off printing full colour images ok but about a quarter of the way through it starts printing in red. Please help me.
Try the following below if it continues to print in red half way through then either your ink carts have expired or something is wrong with them if you are using coral draw to print images there is know problems with that I have listed the solution to that as well. please tell the results of the test page as well please. and also I have included a few other tests please run through these. The sample page can be used as a quick check of the image quality from the black and color print cartridges. Unlike most printing, this page prints from the bottom of the page to the top for user viewing during printing.
  1. Turn the printer off and then turn it on again by pressing the POWER button.
  2. Press and hold down the RESUME button and release it when the Power light starts to blink.
The sample page can also be printed from the Toolbox (provided the Toolbox is installed) to verify that the printer is connected to the computer properly and that the printer and printer software are working properly.
  1. Double-click the Toolbox icon on the Desktop or run it from the HP Deskjet 1220C Printer program group.
  2. Select the Printer Services tab and click Print a Test Page
Printing the diagnostic page The information displayed on the diagnostic page includes the printer model, serial number, service ID (born-on date), firmware revision, total page count and last error code (see Figure 2). If an error code (hex) number is displayed, it represents the last error that occurred regardless of whether the problem that caused the error has been fixed and the printer is presently operational. To print a diagnostic page see the following:
  1. Turn the power on.
  2. Press and hold down the POWER button.
  3. While holding down the POWER button, press the RESUME button four times.
  4. Release the POWER button.
Running the pen recovery diagnostic test If printouts have incomplete text or graphics that are not corrected by cleaning the print cartridges, use the pen recovery diagnostic test. The pen recovery diagnostic test is a three-level cleaning procedure that attempts to clear blocked print cartridge nozzles. The tests can be run either from the Toolbox under Printer Services or by pressing the button sequences below. The Level 1 print cartridge cleaning is a light cleaning mode. Use this level first to clear blocked nozzles.
  3. While holding down the POWER button, press the CANCEL button twice.
After running the Level 1 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 2 pen recovery. The Level 2 cleaning is an intermediate cleaning mode to be used if the Level 1 mode does not recover the nozzles.
  3. While holding down the POWER button, press the CANCEL button twice and the RESUME button once.
After running the Level 2 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 3 pen recovery. The Level 3 cleaning is the most intensive cleaning mode that takes about two minutes to complete. Use this level as a last resort in recovering clogged nozzles. This routine uses a considerable amount of ink.
  3. While holding down the POWER button, press the CANCEL button twice and the RESUME button twice.
After running the Level 3 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If irregular gaps still appear in the printout, replace the cartridge. NOTE: Do not use the pen recovery tests unnecessarily or the life of the print cartridge will be shortened. Printing the nozzle pattern test This test prints a pattern to determine which nozzles, if any, are clogged or not firing and can be used to verify a successful cleaning routine (see Figure 3). Look for irregular spaces or gaps in the test pattern; these indicate faulty nozzles.
  3. While holding down the POWER button, press the CANCEL button eight times and the RESUME button four times.
Printing the calibration page This test provides calibration of the print cartridges. Calibration includes print cartridge alignment and optimizing the turn-on energy for the installed color print cartridge.
  3. While holding down the POWER button, press the RESUME button three times.
Eight green checks, one on each line of the printout, signify that the calibration was successful. ----------------------------------------------------- Printing the infinite H test This test prints continuous pages of the letter H and is useful for troubleshooting paper feed problems or other intermittent problems that are difficult to replicate.
  1. Turn the printer on.
  3. While holding down the POWER button, press the RESUME button eight times.
  5. Press and release the POWER button to terminate the test.
Aug 14, 2008 | Office Equipment & Supplies
Genius MousePen 8x6 (MOUSEPEN8X6) Logo
538 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Alun Cox
lorenzo carolus
Level 1 Expert
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
