Question about Breville Coffee Makers & Espresso Machines
Hello,today i bought a breville bar italia and it doesn't froth up or make the milk 'textured'.the pressure knob comes up and the temperature of the milk is 60-i have a thermometre,i used pura lite milk,then longlife full crm milk(both from the fridge) and neither of those worked very well.can you help me at all please or have i got a dud machine?? thanks, suzy
I didn't realise there was a froth enhancer on the steam wand, so when we put that on, it worked.
Posted on Dec 12, 2009
Problem with frothing unit. I bought my Die-Cast
It probably has a line clogged. It could be from backed up milk, but also could be the water you're using. Those things are finicky about have filtered water, especially because when the water heats up it can deposit calcium etc. onto the inner water lines. Only use store bought filtered water.
Oct 28, 2013 | Breville BES830XL Die-Cast Programmable...
How do I operate this Gaggia Fantastico II Espresso machine?
http://kitchen.manualsonline.com/manuals/mfg/gaggia/gaggia_espresso_maker_product_list.html
Sep 06, 2012 | Coffee Makers & Espresso Machines
Milk won't froth
have you tried pumping loads of water through the frothing device. it worked for mine.
Jan 17, 2010 | Breville ESP8XL Espresso Machine
Low pressure on milk frother on breville coffee machine
First,I'm NOT a Breville tech, but this is a very common problem with steam boilers. Your valve seal(s) are worn and needs replacement. Any leaking water or steaming from various places other than the steam tip is causing your tank to lose pressure. The heater needs to stay on longer just to keep everything up to pressure and properly heated. You probably noticed that your shots may not have the creme or very thin and watery. Milk steaming takes a long time or not enough steam to complete a froth, especially on a Latte. Your machine needs servicing. Contact your vendor or MFR for service.
** loose steam wands will fall off and be re-assembled without the ball seal or washer. Look around the machine for a round disk made of hard rubber or nylon plastic. Take apart the wand and reassemble with the washer or get a new washer and tighten,.
** other places were you can loose steam pressure is the Anti-siphon valve, Safety valve, and various pipe fittings to the steam boiler. Look for steaming plumes from unexpected areas of the machine.
** Scale that has built up to the point of causing valve problems are usually too much for DE-scaling to work properly. Usually done as a preventive maintenance rather an alternate to repair. Like a blood clot, if you remove it while still in an active system. Where does this clog end up? This debris needs to be physically removed from the pipes, valves, and/or tank. Heavy scaling is a sign of an old machine that will need a lot of servicing to bring it up to MFR specifications.
** Final; The steam wand(s) are the most used (and abused) parts of the machine. Constant cleaning is a required task that needs very diligent baristas to keep it fully functional. I've found that best operators use the following method to keep the steam wand in top condition; Remove milk froth pitcher completely from wand, Send a short blast of steam to clear milk residue from tip. Take a damp towel to grab wand an pull downward to wipe off any remaining milk residue. Leave the wand in a pitcher of cool water to soak during long break periods to help break up any dried milk. Let soak over nite when not in use. Have your operators notify you of any 'loosey-goosey" wands. Tighten them properly but make sure all the parts and washers are there. Check your manual or just ask your technician to show you the next time.
*Have a safe New year! Aloha! ukeboy57
Dec 24, 2017 | Breville Coffee Makers & Espresso Machines
Too much water coming out of steam wand
I worked at StarBucks, what we did was put water into a contaner and steam the water, a lot of the time why the steamer doesn'..t work as well is because it is clogged. Another way to do it is to just run your steamer, also go to a coffee store and buy expresso machine cleaner. It could just need a good cleaning.
Apr 16, 2009 | Breville ESP8XL Espresso Machine
Frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Sep 12, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Frothing of Milk
I simply use a needle on mine. I don't believe the upper section gets blocked unless you have hard water. Then you will have to go with a descaler solution.
Jun 27, 2008 | Breville Die Cast 800ESXL Espresso Machine
Pavoni, no steam from steam wand
i havent heard of this issue , it could posibly be the bent steam wand , but the nozle is made to be that way, because the pavoni eurpicola doesnt produce enough steam pressure , it enables you to create better froth
Oct 25, 2007 | La Pavoni PC-16 Espresso Machine
Gaggia Coffee
Hello, I have been experienceing the same problem since I bought this thing. I used to have the classic Gaggia until it died after 15 years. however, when I went to this one it just didn't function the same.I was having water leaks come from the group assy so I replaced the group valve assy which I saw a diffrence and it functioned properly for a few days, then It was acting up again. No steam to froth and water bypassing the group assy... I then removed the valve assy again and saw it was somewhat clogged of mineral deposits.I cleaned it and after a few days once again it wasn't frothing as it should. Yesterday I completely tore this thing apart but couldn't figure out how to remove the steam valve assy. Does anyone have any ideas?? I removed the 2 screws and it won't move. OH BEFORE I FORGET!!! It was working fine the other day and while I was in the middle of frothing, it suddenly went to half pressure.... ANY IDEAS?? Thank you in advance....
Apr 09, 2007 | Gaggia Coffee In White, White MDF...
Coffee Makers & Espresso Machines Logo
171 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
