Question about Whirlpool Calypso GVW9959K Top Load Washer
Calypso Washer is not washing clothes or spinning; getting LF error message. Water is going into the machine but no washing action.
  • 230 Answers
Hi There
I'm Sending you the fault codes. Hope this helps you and get you in the right direction.
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
My washer will not drain. At first it was giving the normal error messages like LF, so we had the drain piped to see if it was clogged. Now the washer fills up and does not drain. I have a Whirlpool...
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 27, 2010 | Whirlpool Washing Machines
WHAT IS THE PROBLEM WHEN YOU GET THE LF ON THE
LF Long Fill
Oct 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso fails to remove excess water from washed clothings
There are two separate motors, one for the tub and one for the pump. They are both controlled by the motor controller board. Since you say the water drains, the pump appears to be working but since you say the clothes are wet, the spin probably didn't happen. I would suspect the drive motor or the wiring for that motor. There are procedures on the web for testing the wiring and motor windings. Good luck. There is also a pdf diagnostics/test document available. http://www.affordableappliance.com/Download%20Folder/Calypso%20Washer%20Service%20Manual.pdf
Good Luck!
Aug 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Getting code LF won't wash stays on same amount of time
Try unplugging the washer for 10 min. This will reboot the circuit board. Sometime you can get small power surges from the electric company and these will confuse the electronics in the curcuit board. Unplugging and resetting the system wil sometimes work.
Apr 29, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Where is the filter located on a kenmore elite calypso washer
reomovethe 3 screws across teh lower acess panel, youll see the filter clean out right behind there , be warned before unscrewing get a plastic bag, or a few towells you will getwet!!!!!!
Mar 17, 2009 | Kenmore Washing Machines
Ld and ob error codes
hello.........
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
Sep 07, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
LF code appears and washer does not spin out
This is where to find the manual. When you get to it, it tells you that LF is for long fill which means it is taking longer than ten minutes to fill with water so it shuts off and displays the error code.
Bottom Line : Check your water pressure.
Aug 01, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
335 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
