Question about General Electric Microwave Oven
My GE JES1656 will not work. Check the fuses and
My GE JES1656 will not work. Check the fuses and nothing blown on the panel. Tried other appliances in the same outlet and they work. Microwave oven is about a year old...any fixes??
    New Friend:
I replaced humidity sensor to no avail. its on the left side under frame cover. no solution yet. my oven comes up w/this F4 error on the dual control panel .
Posted on Mar 15, 2013
Probably the "oven temp/flame sensor" if you make microwave popcorn and the vents on the left hand side are restricted. Gets pretty hot. This part cannot be reset and has to be replaced.
Posted on Apr 13, 2010
SOURCE:
GE MICROWAVE MODEL JVM1750DM1WW NO POWER AT ALL. HAVE ALREADY CHECKED THE OUTLET AND CHECKED THE BREAKER. ABSOLUTELY NOTHING WORKING.
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. replace fuse and microwave should begin working.
Feb 09, 2011 | Microwave Ovens
GE JVM1850CH06 MICROWAVE
the panel display is fried. you'll need to remove and replace it...this the sort of thing you enjoy doing?
May 23, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Profile Spacemaker XL 1800
Yes the main fuse has blown for several different reasons. If you have no electrical know how, or experience using a multimeter you really should have a pro take a look at it. It could be anything from a bad capacitor, a bad High Voltage diode, a bad door switch or maybe even a bad magnetron or a control panel. Not really a job for a novice to attempt, as the main AC fuse will not blow for no reason. Good Luck
Sep 17, 2007 | GE JE1540 Microwave Oven
I have no power for my GE profile microwave. The model # is PEM31SM3SS. The outlet is good.
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 24, 2011 | GE Microwave Ovens
My frigidaire GLMV169 manufactured in 2005 and purchased in 2006 stopped working. There is no power. The clock, buttons - everything. Tried changing the outlet and flipping fuse switch and still...
Hello there:
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Nov 19, 2010 | Frigidaire GLMV169 Microwave Oven
Machine will not turn on
from online Microwave Repair Manual: Totally dead oven (no lights, no clock, no display, no fan, no heat...)First, check power to the outlet using a lamp or radio you know works. The fuse or circuit breaker at your service panel may have blown/tripped due to an overload or fault in the microwave oven or some other appliance. You may just have too many appliances plugged into this circuit - microwave ovens are high current appliances and should be on a dedicated circuit if possible. If you attempt to run a heating appliance like a toaster or fryer at the same time, you *will* blow the fuse or trip the circuit breaker. A refrigerator should never be plugged into the same circuit for this reason as well - you really don't want it to be without power because of your popcorn!
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
Oct 21, 2010 | Microwave Ovens
Start button doesn't work for all microwave functions--as well as timer--fuse is ok
Possible causes:
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).
Dec 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile spacemaker 2.0 microwave and it just quit working on me. Sounded like a fuse popped?? I verified that the electrical outlet was working. Is there a fuse to replace inside the microwave?
Hello. You have isolated the problem.
Jun 23, 2009 | GE Profile Spacemaker Over-the-Range...
Ge spacemaker jvm1533 is dead wont turn on
check the circuit breaker first it may be the fuse is blown The fuse may be located behind the grille following the power cord on the rside of the unit.
it may be a bad thermal fuse or oven thermostat.
Dec 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
General Electric Microwave Oven Logo
346 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
