Question about Canon PIXMA MX700 All-In-One InkJet Printer
I get an error code 5100. Printe does not start to
I get an error code 5100. Printer does not start to print. I have checked the printer head and cleaned it. Only on print catridge is low and flashing.
    Problem Solver:
  • 8 Answers
Hello Gurmi,
It may be that you need to clean your timing strip. (Download the manual from the usa canon website to learn more about the timing strip.)
Also, if cleaning the timing strip does not help, you may need to lubricate your purge cap. The purge cap is the white sliding mechanism that the printhead parks against when not in use.
1. Get yourself some white grease.
2. Remove the right printer panel to gain access to the purge mechanism.
3. Do not get any grease on the wipers or the black caps!
4. Moisten JUST the purge cap with the white grease.
Let me know if this solves the problem! Thanks - ambssdor
Posted on Dec 29, 2009
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
I can't print my documents. My Printers model is Canon IP2700 and it says there that the error code is 5100. How can I fix the problem? we need the print immediately. Is there any solution we can fix it?
Usually, error code 5100 means some kind of obstruction in the print path, maybe something that had fallen inside the printer, the gears being jammed by something that got loose inside the printer, or ink on the clear plastic encoder/timing strip (a plastic strip about 1/4" in width that you can see running from side to side and connects to the print head).
Clean the plastic strip with alcohol , check if there is nothing blocking the head carriage set (sometimes kids play and hide toys, pens, coins, inside printers, VCRs or any other devices that have "doors"...).
Hope this info may help you!
Mar 12, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Canon MX328
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
error 5100 :
1. clean **** strip film
2. clean **** strip film sensor (back of head carriage)(use contact cleaner)
3. fix purge unit
Apr 24, 2010 | Office Equipment & Supplies
Check printer 5100 error message.
error code 5100 means print head temperature rise error. In other word the print head is overheated. First,turn off your printer for some minutes (it recommended to take about 30 secs or more) and let it's cooled down. Turn on again. If the problem still persist,try to check whether the print head is good or not by comparing with another print head. Be carefully,sometimes this problem is caused by short circuitry inside the print head.
Jan 03, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
Error message 5100 on Canon i560 printer
Hi You can Try
Same old errors
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Oct 27, 2008 | Canon BubbleJet i560 InkJet Printer
Error code 5100
Hi You can Try
Canons faults
Error Code 5100
Solution 1:
Solution 2:
Mar 02, 2008 | Canon PIXMA iP4000R InkJet Printer
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Error 5100 - what does this mean?
Hi Luza, A 5100 error is a carriage problem. That means it could be the code strip, carriage assembly or logic board. First make sure nothing is keeping the print head from moving all the way across the printer. If the smallest thing blocks the head from going all the way across it will generate this error. You'll want to look hard for ANY obstructions anywhere. Throughly check the gears and rollers for obstructions too. Second the code strip (or timing strip) is the 1/4 inch plastic strip that runs across the printer and through the head carriage. It's got supports on both sides. If becomes dislodged it will generate this error. (it's got a tesnsion spring on one end) I have a feeling that is your problem. That somehow when you replaced the cartridges you may have dislodged the code strip. That might account for not being able to correctly align the print head too. Make sure it's straight, level and secure. Also make sure it's not dirty. Grease or dirt on the code strip can generate a 5100 error. You can clean it with a damp cloth (water) but be careful if your going to remove it from it's anchors. You can try cleaning the steele bar that the carriage runs across as well, but you'll have to lube it back up with a cloth dampened with some 3 in 1 oil or a light machine oil. If none of that works and your ABSOLUTLY SURE there is nothing in there blocking the printer then it must be either the carriage assembly or logic board. If either is the problem you're going to need service on the unit or a new printer. I hope this helps. Please let me know how you make out, Dude
Nov 15, 2006 | Canon Pixma iP6600D InkJet Photo Printer
Canon PIXMA MX700 All-In-One InkJet Printer Logo
208 people viewed this question
old marine
old marine
