Question about Lexmark X5150 All-In-One InkJet Printer
Error de cartucho Error 50C. - Lexmark X5150 All-In-One InkJet Printer
tom19511
  • 1601 Answers
SOURCE: Error message 50c on printer
  1. Make sure the printer is turned on.
  2. Lift the printer's front cover.
note.gif NOTE: The ink cartridge should be in the up/loading position unless the printer is busy.
  1. Squeeze the tabs on the cartridge lids and lift the cartridge lids up. The cartridge pops up when the lid is fully lifted.
  2. Remove the cartridges.
  3. Check and make sure that all of the protective tape has been removed from the contacts on the ink cartridge.
  4. Replace the cartridges.
  5. Snap the lids closed.
  6. Close the printer's front cover.
  7. When prompted on the printer's LCD to choose New or Old, choose Old.
  8. Press the Select button.
This was from Dell's website
Posted on Nov 13, 2007
SOURCE: my Lexmark is X6100 Series - Cartridge Error 50C consult user guide
The cartridge has a short in it and needs to be exchanged for a non-defective one.
Posted on Feb 02, 2008
Avwrexit
  • 47 Answers
SOURCE: error code 50c
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.If this does not resolve the issue then try the next steps.
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Posted on May 29, 2008
  • 53 Answers
SOURCE: tengo una impresora lexmark Z2320 recargue los
Lexmark no es compatible con los cartuchos rellenados.
Posted on May 18, 2009
SOURCE: dell a940 error code 50c
From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
good luck
have a nice day
Posted on Jul 08, 2009
Hp officejet j3600 error del cartucho
Saludos
Mi nombre es Jose, es un placer intentar ayudarle para ello le recomiendo que limpies los conectores y mires bien cual es el cartucho que tiene problemas, de todas maneras puedes mirar este post.
Como solucionar error en cartucho impresoras hp
Oct 31, 2012 | Office Equipment & Supplies
Mi impresora canon mp280 me sale el error b200 que puedo hacer..la tinta ya no corre
pruebalo con uno de los cartuchos afuera. si es que ves que tiene alguna reaccion diferente a lo que con los dos cartuchos tienes que cambiar ese cartucho que sacaste. yo tenia el mismo problema, lo cambie el cartucho de colores que era el que estaba mal y luego lo resetee y todo ok. mientras no lo cambias ese cartucho el reseteo no funciona.
Feb 24, 2012 | Office Equipment & Supplies
En mi impresora lexmark marca error 1203 ya limpie los contactos de cobre y sigue mismo error
Podría ser debido a un cartucho defectuoso. Trate de insertar un cartucho de diferentes conocidos de trabajo para determinarsi el otro está defectuosa.
Jul 28, 2011 | Lexmark X5470 All-In-One InkJet Printer
Tengo un multifuncional x2600 y me marca error atasco de papel, ojala me puedan ayudar...ya cambie los cartuchos ya trate de sacar una impresion y no me permite hacer nada..
Quite las hojas de papel desde el alimentador. Trate de abrir la tapa de la impresora y retire ambos cartuchos. Mientras que la cubierta está abierta, compruebe si hay obstrucciones en la ruta del carro del cartucho. Compruebe si hay conexiones sueltas. Si todo está bien en el área del cartucho, cierre la tapa. Desenchufe y vuelva a conectar la impresora a la fuente de energía para restablecerla. Cuando la impresora se enciende, vuelva a insertar un cartucho en primer lugar. Cierre la tapa y comprobar que no existen errores. Si no, abra la tapa de la impresora de nuevo y vuelva a insertar el cartucho de otros. Vuelva a colocar el cartucho lo que está causando el error que aparezca. Usted también puede tratar de insertar un cartucho de diferentes conocidos trabajando para determinar si el otro es culpable.
Nota: Esto se traduce con translate.google.com.
May 20, 2011 | Lexmark X2600 InkJet Printer
En mi imprsora lexmark me sale error 1203 cual es la solucion a mi problema gracias
El error 1203 son un asunto que ocurre o cuando un cartucho es malo o la Ranura de cartucho de impresora es mala...
1 - intenta de limpiar los contactos de cobre de la ambas ranura de carritos y carrito en la impresora y tratar otra vez.. O 2 - cuando error aparece,
cierre el poder de impresoras lejos; espere un minuto y g?relo atr?s en copia de prensa.
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Feb 25, 2011 | Lexmark X4270 All-In-One InkJet Printer
LA MÁQUINA INDICA ERROR E000805-001
1) Desconecta el poder de la impresora. 2) Quita el ladrillo/bloque negro del poder por detr?s de la m?quina. (Puede ser un malvado peque?o de sacarlo la primera vez usted lo quita.
3) Abre la cima de la impresora/multi unidad de funci?n.
4) tira Suavemente la cinta para centrar el portador de cartucho de impresora.
5) Abre o el lado de izquierda o derecha y quita el cartucho. (Depende de cu?l lado el error ocurre en, negro a la izquierda, el color a la derecha)
6) Verifica que toda la tira pl?stica que cubri? los nuevos contactos en el cartucho tiene de hecho fue quitada.
7) Toallita tanto los contactos de cartucho como impresora con una seco, hilas libertan tela.
8) Enjuga el fondo del cartucho con una h?medo, hilas libertan tela para verificar que la tinta fluye y los vistazos corrigen.
9) se Asegura de que no hay agua que queda en el cartucho.
10) Reinserta el cartucho en el portador y se asegura de que es profundizado y es insertado completamente al trasero de la ranura de portador.
11) Reinserta el ladrillo/bloque del poder.
12) Conecta de nuevo el cable de energ?a el?ctrica de impresora.
13) el Poder en la impresora y el error debe ser resuelto.
14) Corre la alineaci?n de impresi?n e impresi?n o copia varias p?ginas para asegurar el problema ha sido resuelto.
Dec 19, 2010 | Office Equipment & Supplies
Tenemos una t160 y en el visor da el siguiente error "32 cartucho no soportado" pero tampoco se puede acceder al menu propio del equipo.¿Cuales serían los pasos a seguir para...
reviza que que sea el cartucho correcto
trata de quitar todos los cartuchos y encenderl a impresora sin los cartruchos instalados
instala los cartuchos de nuevo
si no funciona prueba los mismos pasos pero al encender de nuevo la impresora deja precionado el boton de encendido por 30 sec o mas para hacerle un RESET al sistema
SALUDOS!!!!!
Aug 11, 2010 | Lexmark Optra T610 Laser Printer
System unavailable in xerox pro 255 :(
esto lo puede dar el cartucho de copia mal insertado q produce arcos de la fuente de alta y la desconecta dando error 9060, tal vez el corotron roto del cartucho de copia.... otro padrenuestro
Oct 08, 2009 | Xerox WorkCentre M-24 Color Copier
TENGO UNA HP 4355 Y ME MARCA UN ERRO EN CART.
Para empezar, quite el enchufe de la corrente como unos diez minutos
Si sigue tenendo el problema quite los cartuchos y los vuelva a poner.
Si todavia tiene el error limpie con algodon y alcohol la superficie del contacto de metal donde se pone el cartridge.
Si sigue non funcionando el cartridge puede ser defectuoso, intente cambiarlo, posibilmente con uno original.
Sep 06, 2008 | HP Officejet 4215 All-in-One Color Photo...
Lexmark X5150 All-In-One InkJet Printer Logo
372 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
