Question about Motorola Mobility RAZR V3xx Cellular Phone
V3xx reset button
My phone will not come on at all the batt is fully charge i checked it on another phone the key pad will lite up few a second and vib. but that is all it will do. help me
  • dave t Apr 18, 2013
    i have a razr v3xx somebody put a subsidy code on anybody nos how to remove it
Sir,
the problem of your phone is the software...
it needs to reprogram...
just go to your near cellphone shop
Posted on Jan 22, 2008
When I turn my cubot phone on, it comes on , but thAts it, won't do anything, and hasn't been damaged at all. What do I do?
Try phone reset
Power off the phone, hold the volume down key and press down the power button simultaneously for about 15 seconds. The phone will power up and shows an exclamatory mark. Then release the button. Press the volume down key, it will display the menu. Choose the menu by press the volume down key. Choose "wipe data/factory reset", press power key to enter in, then choose "delete all user data", press power key to confirm. Wait until it indicates "data wipe complete". Then choose "wipe cache partition", confirm with power key. Wait for a few seconds, the screen will shows "cache wipe complete". And at the last, choose "reboot system now", confirm with power key, then the phone will reboot.
Mar 14, 2015 | CUBOT Cell Phones
My keypad worked just fine but the battery died and I replaced it. All the lights on the key pad work but I can't seem to reprogram it. I press the learn button enter the code press and hold enter the...
Sometimes theres a tiny reset button hidden in the batt area. Are you positive that the new batt is fully charged silly Question but Iv\'e gotten burned on special size batts its like the sit on shelf and no body cycles their stock...Im assuming the manual is nowhere to be found? Almost is like I had a remote to a blue ray that was acting crazy turns out one of the buttons was being pushed constantly and not letting any other logic take its place have you ever changed batt before? what happens if you putt old batt back in? What does it take on your end to "reprogram" it? this odd of results may require a phone call or a downloaded manual from the internet. How did you know to enter the learn mode? is there a users manual but not a trouble shooting manual? Ive heard that powering it up and entering the model # directly after auto prog\'s logic also some times holding 1 and enter or 1,0, and power// or 1and power. hope at minimum I gave you a few options (damn this digital world!!! ) good luck friend let us know outcome...S
Jul 29, 2014 | Sears Craftsman LiftMaster Chamberlain...
Phone not getting switched on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 03, 2012 | Apple iPhone 3G
How do I get the (maint req) light out?
turn ignition off
press and hold the select/reset button
turn the key to on position II
hold at least 10 second
Mar 12, 2010 | 2003 Honda Pilot
I can not get any button in key pad to work like it is frozen
You should have just done a master reset, the best thing is to just go to motorola.com and check your warranty. The only other thing I could suggest is find someone that can reinstall the firmware on the phone.
Sorry,I can not explain it to you how to hack this phone,it is not like the old v3. But someone that knows could do it. Worst case is its not under warranty and you have to see which option is better, pay moto
for repair,(Ask cost) or grab a new one, or a real cheap phone until
you can renew contract. Do not upgrade, you are getting robbed,wait till contract ends.
Mar 17, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Nokia 7373
Try a reset:
How to reformat your phone,
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
* is at the bottom left of the key pad.
3 is the number 3 on the key pad.
Send is the green button on the key pad.
Jan 03, 2009 | Nokia 7373 Cellular Phone
KEYPAD???
Usually this means that you need to take it to a repair shop to have the keypad replaced but truthfuly it would be cheaper just to get a new phone. Hope this helps =)
Feb 24, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola RAZR V3xx not powered on
you need to charge a phone over night for the battery to fully charge and have a memory
try plugging in as charging and turn phone on by holding the red button down for a few seconds on the right hand side
Oct 11, 2007 | Motorola Mobility RAZR V3
Won't turn on after assembly
dear first check the the power volts are comming in ur on of key. if not comming check key pad strips. mostly it prob from key pad may be it is not good connected to board or damage during assembling. first unplug it and then re connect
Mar 23, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3xx Cellular Phone Logo
543 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
