Question about Samsung HLP4663W 46" Rear Projection HDTV
Wont start When i try to start the TV is get a flashing lamp message with a sound I think is the fan, then I get a decending whistle which seems to tune the fan off then it all repeats. If i hold the power button down i get the lamp, timer Temp thressome but it won't actually turn off. I had a new lamp sent and installed it. No change. I live a long days trip to the nearest service provider. Any ideas?
    Genius:
  • 1,139 Answers
Hello cordovan,
It sounds like you may have a Power supply problem since the set will not turn on at all and the only power present is form monitoring functions which use a separate power supply any way. Now to trouble shoot this problem you will need these basic tools:
a Multimeter (to measure DC and AC voltages)
a Schematic Diagram (To locate Test Points and voltages levels)
This should cover what is needed.
First unplug the TV and check the fuses using the ohmmeter setting on the multimeter. Then locate the power supply section which feeds from the main power rectifier plug the set in and turn it on, measure the DC voltage off of the bridge rectifier. Then locate the voltages from the various regulators to determine if these are active. if not check the FET used to activate the switching transformer, as with the other instructions measure the voltages and determine if the FET is being switched on and off by the driver oscillator. If this is not occurring then it can be assumed that a power supply problem might be an issue. I would then unplug the set attempt to take resistance measurements to make sure that there were no low resistance events (shorts) on the various stages of the TV.
This should reveal if the power supply board is bad, if it is take the board find out its part number and order it, I would not attempt to effect repairs on the circuit because more damage might be inflected on the TV set by doing so.
Now if this is something you rather not do, I would then suggest that you take the TV to the shop for repairs.
I hope this helps,
Thank you,
Shuttle83
Posted on Jan 20, 2008
Infocus projector makes a whistling sound then shuts off
The whistling is nothing but noise. You need to open the projector to confirm the source of noise. It can either be mechanical or electronic. Possibility of mechanical noise sources are colour wheel (a 4 colour wheel near the lamp), blower fans & exhaust fans. All these are rotating things. If any one of them is jammed, then so as to try to rotate at full speed creates noise. To reduce mechanical noise it is necessary to service them. Dust is one of the main reason. For electronic noise check SMPS (Switched Mode Power Supply) & lamp ballast (electronic choke).The electronic noise is a high frequency noise generated by such devices. Are you using the projector in dusty envionment?
Nov 24, 2011 | InFocus Office Equipment & Supplies
Tv makes whistling noise and wont come lamp temp lights flash after 4 tries it comes on
Hi;
if there's flashing whistling and has burning smelll. it has a high voltage leak from inverter boards and to the wires going to ccfl backlight bulb an maybe some loose solder inside.
You have to call for a repair technician or bring it to repair shop,
it can damage the Inverter driver circuit if you force to operate your TV.
and make the cost of repair much more expensive.
thanks.....
Sep 03, 2011 | Televison & Video
I have a sony 55"
3 times red standby light flashing indicates that lamp cover (first thing that you removed from tv to replace lamp) is not fixed properly on tv, make sure lamp cover is attached correctly with tv to solve this issue.
3 times blinking is not problem of fan or anything else, it is related to lamp cover that engages safety micro switch inside to turn On tv.
Thanks.
Jan 27, 2011 | Sony KDS55A2000 55" HDTV
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
Sony bravia KDF-E50A12U rear projecion tv wont turn on
Hi it sounds like it could be an issue with board that powers the lamp ,it's called the ballast.When you put a new lamp in the ballast has to provide more power ,when it starts to go weak it will not light up.Sometimes you can put your old lamp in and will work fine.Try partstore.com they might have it right there.Hvae a blessed one!
Mar 02, 2010 | Televison & Video
Samsung HL-P5063W DLP No. 1 fan problem
Defective Lamp,maybe and Ballast Board may well be the problem it is what turns Lamp on Look on line Encompass Parts Dist 1-800-638-3328 Ballast Board also has small fan mounted in front of it!
Nov 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
STATUS LIGHT YELLOW, LAMP LIGHT GREEN: TV TURNS OFF.
have you checked the air filter located on the side of the unit? Also can you hear the fan start as soon as you plug the set in?
Apr 09, 2008 | Mitsubishi WD-52631 52" Projection HDTV
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
PT-45LC12 wont power up
You have a bad lamp. The "clicking" sound you hear is the ballast (lamp power supply) attempting to start the lamp. The warning on Panasonics that comes up on screen does so when the life expectancy of the lamp is approaching. Otherwise your "clicking" sound and the red light on front are saying bad lamp. When you replace the lamp remeber to follow the instruction that Panasinc provides with the new lamp on restetting the lamp timer. This is usually done with the volume down on the TV and the PIP button on the remote.
Feb 26, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Samsung HLP4663W 46" Rear Projection HDTV Logo
59 people viewed this question
Jerry Greenberg
Jerry Greenberg
