Question about Goodman Heating & Cooling
I have to play with thermostat to get my heating system on
I have a 2 year old natural gas, forced air heatinig system. My thermostat is set at 68 and the room temp is only 62. When I woke up thin morning I took the thermostat (honeywell digital) off of the wall and when I put it back on the wall the heating unit automatically turned on. This has happened several times where I had to either reset the thermostat or the system. Can someone tell me what the problem could be?
  • 1,420 Answers
You did not make it clear if the thermostat is a programmable unit or not. I am wondering if the thermostat is not set on the correct heat anticipation setting. A heat anticipater is a small heater that helps the thermostat turn off before it over shoots the desired temperature setting. If the thermostat is set for a 5 degree setting, it will turn off at 63 degrees if set at 68. If the anticipater was set at 1 or 2 degrees, it will shut off the heater at 66 or 67. Newer thermostats will only allow the thermostat to cycle 6 times per hour so if you never reach the desired temp, you have to wait 10 minutes before it will allow a call for heat. Check the installation instructions to see if there is a setting where you can get the anticipator temperature closer to your set temp. Good luck.
Posted on Dec 11, 2009
Pro 4000 thermostat is set on heat 73 but inside temp is 64 how do I fix? It's only about 2 weeks old.
If you switch to cooling mode and run that test, it may help pin down the problem with thermostat. However, the cooling wiring is independent of the heating system for most of the wires. Checking if the fan runs in the fan-only setting will check if that message gets to the HVAC system from the thermostat. (This only applies for forced air systems.)
There are two possible sources of the problem. The problem could be at the thermostat. Sometimes one (or more) of the conductor wires came loose from their terminals. Alternatively, one of those wires has broken. Pull the thermostat off the wall plate by pulling up at the bottom. Make sure that all of the wires are secured fully (either by the screw or push-connection). If any wire is damaged, cut off the broken section and strip a bit of insulation. Then secure the wire. (Use the labels to make sure that they are at the correct terminal.)
The alternative is a problem at the furnace. Check for power first. A tripped circuit breaker is not unknown. After that, the could be a problem with the control system, the ignitor (for gas or oil heat sources), a blockage at the exhaust or air intake (for high efficiency heating systems) or the blower motor (for forced air systems). Some heating systems have LEDs that indicate an error condition. Look to see if there is any blinking lights. Use your furnace manual to check what those codes may mean.
Clear around the exhaust outlet and air intake if you have any debris or snow/ice near there. Make sure to take safety precautions for a roof/chimney exhaust. Look at your furnace manual to see if there is a test option.
For my current HVAC system, you can test with a jumper wire. A few months ago, the heat didn't come on and that test proved that the blower motor didn't spin up. (The system has an interlock that stopped trying to provide heat when the motor doesn't spin properly.) A new motor was installed and the problem was solved.
I hope this helps. Please add a comment with more information about the heating system that you have and any error codes if you need extra assistance.
(I have a gas-fired electric ignition furnace. Without the blower, the furnace would overheat so it locks the gas valve and ignitor.)
Feb 12, 2017 | Heating & Cooling
I want to connect my heating system with my generator. It's a forced hot air system natural gas by York.
yes, you need to have at least 120volts and make sure your generater can power at least 3000 watts min not peak.
if you have an extension cord and must find the supply to the furnace
then splice the cord to the supply
then plug it in and there you go.
Nov 02, 2012 | Heating & Cooling
I have a two wire thermostat system. I switched the thermostat from a mercury one to the Honeywell CT3200 with dip switches set for my electric forced air furnace that is 31 years old. The white wire is...
If you look closely at the installation manual page 6&7 it tells you settings to use for your type of system. If I'm not mistaken you will need to back out screw "b" 360°. Hope this helps!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 17, 2017 | Honeywell CT3200 5-2 Day Electronic...
The thermostat is set to heat at a temp of 68 degrees. However,the thermometers temp read 71 and the blower was running and passing cool air. I tried setting the thermometers temp to 72. The furnace...
The burners are not igniting and the timer turned on the blower thinking the burners were already lit by then. You have a burner/ignition problem. Either the ignighter or themocouple is bad
Dec 31, 2017 | Goodman GMS90703BXA Heater
Payne AC not working. 1. Thermostat set 68 to AC w/fan on. 2. Breakers and switch near heater are on. 3. Outside unit has 220v but is not running. 4. Fan in heater/Ac unit is not running 5. ...
Dan is this a new system, or has some work on the system (to include the thermostat) been done recently?
Sounds like the thermostat may be wired wrong. From what you describe, the igniter element is coming on, as though you are calling for heating. Do you allow the ignitor to keep going and see if the gas fires off, or are you seeing this and shutting down the system immediately?
If you had the t-stat changed recently, or this is a new system, contact the installing contractor. It may be under warranty.
Sep 03, 2010 | Carrier Heating & Cooling
Only have two wires on old thermostat,where do i hook them up on a rth2310 thermostat
More information would help but I believe that you are trying to hook up a programmable thermostat to your old heating system which is what? Oil forced air, heat pump, gas? Give me more info and I think that I can help you.
hardrocko
Feb 07, 2010 | Honeywell Electronic Programmable...
Forced Hot Air Heating system doesn't maintain thermostat setting
It sounds like you may have issues with the furnace. A qualified professional can go over the system and the house to let you know if the system and unit are properly sized. The poor performance of a furnace can be a sign of carbon buildup in the furnace.
Good luck, hope this helps.
Matt
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
Thermostat temperatures not reaching preset Energy Star settings
Well with a boiler system like you have it will cost you more money to heat your house that way than if you leave it like it is. With a boiler system it takes a lot longer to heat an area than with a furnace. The best thing you can do is find a happy medium and leave it there at all times. If you read the paper work on your new thermostats they have a set procedure which tells the thermostat if you have forced air or boiler system. Do you have baseboard or in-floor heat how many zones do you have.
Jan 07, 2009 | Honeywell Electronic Programmable...
We have an InterTherm heating system. The bedroom thermostat will not shut down when it reaches tempreature. This system is about 30 years old. Do you believe the problem is the thermostat or at the...
you have a bad thermostat,there must be a 3-5 degree difference between set point temp and actual room temp,is this a boiler or forced air furnace
Nov 16, 2008 | Intertherm Heating & Cooling
Thermostat wont turn on heater Robert Shaw 9600 prog.
I have a thermostat 9600 Robertshaw and I have to use the trip switch to start my furnace. Then it reaches the temperature and sometimes it will kick in by itself but majority of the time I have to trip it. I have changed the batteries cleaned the thermostat,and reset it. Is it time for a new thermostat and can I replace it myself. Thanks
Nov 06, 2008 | Heating & Cooling
Heating & Cooling Logo
467 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
vance jones
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
