Question about Nokia N95 Cellular Phone
Battery won't charge after replacing flex cable n95 8gb
Hi, just changed over the flex cable on my n95 8gb. Everything worked perfectly normal except I noticed the battery wouldn't charge. Also I noticed the phone was getting hot. Could you please help me solve the problem. Thanks Alex
  • 22 Answers
Re-check the connections between the flex cable and board. Your problem may be a cause of a shorted pins... Good Luck... ^_^
Posted on Dec 12, 2009
Iphone won't charge if on
Hello My Dear::::::\
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 12, 2013 | Apple iPhone 3GS Black (16 GB)
LCD DISPLAY SCROLLS Sony Handycam DCR-SR62
Had the same.after stopped showing anything and the rest was working perfectly. Changed the flex wire connecting camcorder and it's like new. got from the repair shop and did it by miself. Good luck
Meggita
Aug 04, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Computer works on AC adapter but battery does not charge
hi,there might be the issue with dc in cable(cable from jack to m/b) or the inverter board.
May 29, 2009 | IBM ThinkPad T42 Notebook
Razr v3 flex cable connected but screen is still black
You can buy a new phone.....but I had the same exact problem with my motorola v3 phone. Every now and then both screens would work for a while and then turn completely black or sometimes white. Most of the time black. The keypads would light, I could make and receive phone calls, but I couldn't see anything on either screen. I moved all my contacts to the sim card and I got a new phone thru an upgrade with my company. But I was still determined to get the V3 to work again! I brought the phone to a few cell phone repairs shops and I was told that the connectors from the flex cable inside the phone sometimes get loose. Make sure they are tightly plugged in. If that doesn't help then the flex cable needs to be replaced. Some of these repair shops wanted up to $65.00 to replace the flex cable! I could replace the phone for much less than $65.00! So I decided to go to ebay and type in Motorola V3 Flex cable......hundreds of places came up that sell this flex cable. I found a place in my area and ordered one. It cost me $5.00 and I got it within 2 days! I looked online on how to install the flex cable and everything from how to disassemble the phone to installing the new flex cable and reassembling the phone was right there! I followed the instructions and I installed the new flex cable and the phone is as good as new!!! Both screens are working and I didn't loose any pictures or contacts from the phone!
All it cost me was $5.00 and about an hour of time! It even came with free shipping! Go to google and type in Motorola v3 black screen and look thru the solutions. Some of them will explain how to disassembe the phone and replace the flex cable with detailed pictures! You can buy the torque screw drivers at Home Depot or on ebay! Good Luck!
Jul 15, 2008 | Motorola Mobility RAZR V3
Hi k750i,phone works perfect but won,t hold a charge for long,even with new batteries. thank you
Before you change the battery:
  1. Charge the battery fully
  2. Discharge the battery fully
  3. Repeat steps 1 and 2
If the battery does not reset itself and start lasting longer then you do need to replace it.
If that does not work the phone will require repair of the leads from the charger to the battery or the battery to the phone
Jun 26, 2008 | Ericsson Cell Phones
Phone displays is not working.
hi
most common problem is lost contact in you flex connector or defective flex connector. try opening your phone and check the connection.
if everything if fine, then your LCD must be defective. have it replace and im sure your prob is solved.
Oct 15, 2007 | Motorola Mobility RAZR V3
My screen will turn on, but will not proceed.
hi
it seems you have a prob in the keypad flex. have it replaced and your prob is solved.
Oct 12, 2007 | Motorola Mobility RAZR V3
Navigation keys do not work
dear freand you have to change the flex cable on your phone.this is not an easy job and you haved to take to a technician.
Apr 02, 2007 | Motorola Mobility RAZR V3
Nokia N95 Cellular Phone Logo
326 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
