Question about Sony Ericsson K850i Mobile Phone
My phones screen has gone completly blank the battery is fully charged what could the problem be?
My golf buddy platinum screen is blank. Battery fully charged,screen only comes on when the charger is plugged in.
Could be a defective battery falsely indicating it is completely charged.
Nov 10, 2016 | GPS
HTC blank screen
Hello, have you tried turning off the phone, take battery out for 30 seconds then put the battery back in, then turn it back on?
Apr 24, 2015 | HTC Cell Phones
My phones are going blank on screen after I dial out or while dialing.
While the screen goes blank, does it drop the call? Are the handsets fully charged, or are they on the charging dock whenever they are not in use?
The batteries may need to be replaced. Bad batteries can in some cases cause the phone features to not fully work. They are located in the back, bottom of the handset.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mike_005777b2fc6bfc30
Nov 21, 2014 | Uniden DECT15803 3 handsets and Chargers -...
Why has my acer a3 screen gone blank ?
The program of your unit is wiped out. reprogramming is the solution.
Jul 27, 2014 | Acer Iconia A3 10.1 Tablet - 16GB
While switched on the phone screen has gone black/blank. Battery is fully charged. Nothing is working.
may be the display of the phone is damaged or the power cable to display is slipped. Contact your nearest service provider to get the things fixed
Dec 29, 2010 | Nokia Cell Phones
It wont power on & has a red flashing light
2 things, first bad battery, sometimes bad battery works for few minutes then your phone just dies on you, it says its fully charged but it aint. That red light flashing only means that your phone has LOW BATTERY. 2nd your phone software has problem. If you have another ericsson that uses the same battery you can check it the battery is ok, its the only way you can find out if the battery is good. If the battery is doing ok with another cellphone then your cellphone software has problem.
Jan 05, 2010 | Sony Ericsson K850i Mobile Phone
No power to screen even with a fully charged
Blank screen. Is there any instance that the phone was dropped or exposed to any form of liquid? If not I think there might be a problem with the phone's lcd that needs to be replaced.
Jun 28, 2009 | Samsung SGH-t629 Cellular Phone
LG VX8700 won't stay charged...
I had the same problem with mine... I found that you must let the battery completely drain out; I was continuously jumping to charge my phone when it was down to one bar, and realized that upon doing this, the battery never fully retains its charge for as long as it will if you let it die out (blank screen; completely off).
I did this twice, and have not had a problem since.
Hope that helps!
Christina
Nov 25, 2008 | LG VX-8700 Cellular Phone
Blank or White screen on new Motorola Krzr k1 cell phone
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
Sep 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Sony Ericsson K850i  Mobile Phone Logo
53 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
