Question about Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L)
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is my keyboard is good).. ive tried to buy a new cmos cell battery but its still i have that problem,,, so i tried to UPDATE my BIOS..... when i boot it in floppy its says......... award bootblock bios v1.0 copyright (c)2000 award sorftware, inc. BIOS ROM CHECKSUM ERROR detecting floopy drive A media ..... drive media is 1.2 mb DISKBOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER DISKBOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER DISKBOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER my bootdisk and my floopy drive is good coz ive tried it to another pc and it works.. anyone can help me.....
    Problem Solver:
  • 16 Answers
Your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Posted on Dec 11, 2009
Getting message "Disk Boot Failure Insert system disk and press enter" using window xp platform and have MCA fee antivirus software
this happens either the boot sequence have changed or your hard drive is not recognised by the BIOS
Jan 26, 2013 | Computers & Internet
About disk boot failure
Hi!
Disk boot failure means that your BIOS can't find the master boot record of your computer which resides in the hard disk or a floppy disk.
This indication means that your hard disk drive is not detected by your BIOS or their is no operating system installed with it.
Have a nice day!
Jun 02, 2010 | Foxconn WinFast K7S741MG Motherboard for...
MOTHERBOARD PROBLEM HELP....THIS IS MY 3RD POST ABOUT THE
You have a corrupted bios file or files. This is what the checksum means. You need to download the correct bios onto a floppy disk. That floppy disk needs to formatted as a system / startup disk BEFORE you copy the bios files to it. Then put the floppy into your floppy drive, turn the pc on and try to get into the bios screens. If the keyboard error is preventing this, go to the mainboard manufacturers website and check the correct manual for the board looking for the procedure to recover from a bios failure. If this board if no older then 5 yrs, it should have this feature. Follow the recovery procedure to rewrite your bios. When that is fixed, undertake the bios update procedure. ONLY do this if you fully understand and accept the risks otherwise, take it to your local professional. If your board does not have the recovery feature, replace it !!unless you are able to replace the CMOS chip with one which has the correct bios burnt onto it. As most modern boards have CMOS chips glued and soldered to the board, this may not be an option..If the bios chip is socketed, contact your local computer shop, or the boards manufacturer to request a replacement. Your issues all arise from your bios issues so fix that and all should be well..
Dec 12, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Bios rom checksum error.. system halted
This error comes when there is low cmos voltage so motherboard flash memory forgot the bios settings.
For that open cpu and then pull cmos cell from mother board buy new cmos cell and replaced it.
Then when you power up the computer press F1 or F2 or "del" key to enter in bios and set time and date and boot option in bios then save settings.
Then it works again if it not works then you need to update firmware for your bios .
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 07, 2009 | Foxconn K7S741MG-6L Motherboard
BIOS CHECKSUM ERROR
Normally a bios checksum error is caused by a dead cmos battery. In a laptop that can be a pain - some are specialty batteries, some soldered directly to the motherboard, etc.
Start the laptop and enter the bois, there usually will be something to tell you what key to press, most of the time it is f2 or f10. Once in the bios set the date, time and boot order, then save and exit the bios. If it boots ok then try to determine what type of battery and it's location on the laptop to replace it.
If you let me know the make and model of laptop I will try to help determine that info and also where you can get the battery. That will more than likely be from eBay....
Hope this helps
May 02, 2009 | DFI CB61 Motherboard
Disk boot failure
Your boot sector is corrupted you need to install windows again from a bootable windows cd...
Feb 28, 2009 | Intel D845GVSR Motherboard
BIOS ROM checksum error
have you a hard disk in the pc ?
somehow your hard disk has stopped booting (virus , bad hard disk boot sectors)
you may have to reinstall the OS
hope this helps
Jan 05, 2009 | Intel D101GGC Motherboard
Please help
Try pressing F2 / Del key during startup. That should bring the bios setup. Now Restore that defaults & install OS on your HDD. If you are not using Floppy drive, disable the onboard floppy controller from BIOS.
Jun 20, 2008 | ASUS P4SP-MX Motherboard
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Logo
949 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
