Question about Sony Cybershot S650 Digital Camera
Camera is on until we try to take a picture or video then it automatically shuts off. Just replaced battery because original battery would not charge. Can review pictures in memory just cannot take a picture or video.Cybershot dsc-t1
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 11, 2009
Camera turns off when taking picture
Try changing the battery brand and see if this helps..I seem to have the same issue with my camera with certain battery brands..Solved my problem by switching brands..
Jun 21, 2008 | Fuji FinePix A345 Digital Camera
My camera, even with fully charged battery, the lens does not close all the way when you turn power off. And , often must shut on and off to take pictures. Also, sometimes shuts down when taking...
edkhim:
It sounds like your battery has reached the end of its usable life. You have done very well to get several years worth of use out of the original battery, but it's time to buy a replacement battery and recycle the old one.
From page 9 of the user manual for this camera (click here for user manual), this camera uses a model DMW-BCE10PP lithium ion rechargeable battery.
Luckily, this model of battery is currently on-sale at Amazon.com for $19.77 as of 2:45AM Feb 17, 2011! (click here for link)
Disclaimer: Please note that I have done my best to try to provide the correct information about the type of battery that you need and with the troubleshooting of your issue; however, there is still a chance that that I have not correctly diagnosed the issue and that the battery I suggested above may fix the issue or even may not work with your camera. Please double-check my diagnosis before purchasing anything!
Thank you for using FixYa
Feb 17, 2011 | Panasonic Lumix DMC-FS3 Digital Camera
Battery exhausted warning
Hello justplainles:
Do the others show the same problem?
Try this: RESET ALL in the menu or setup menu.
If that does not work, make sure that the in the menu (if it is there) you set the battery type to rechargeable not alkaline .
You may try alkaline batteries, if it does the same, the camera may need repair.
Some cameras will not set the battery type automatically.
Aug 25, 2008 | GE A730 Digital Camera
Camer won't turn on.
I had the same problem and realised the camera is sensitive to the type of batteries you use.  I had put in non rechargable batteries.  Some brands seem to work and some don't, but rechargables are best, particularly the original sony batteries .  Try changing the batteries.
Oct 26, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
My camera turns off .
Oct 18, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Camera will playback but wont take pictures
I found that the e550 eats batteries very quickly if the memory card is full (or nearly so).  I have installed a 512MB XD card.
Sep 29, 2007 | Fuji FinePix E550 Digital Camera
Cyber-Shot DSC-S500
We had similiar problems with ours until we started making sure the camera was kept warm when it was shut off. For some reason, it and the batteries don't like the cold...we were able to extend the battery life if we kept it covered when we weren't using it.
May 10, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Beep
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Sony Cybershot S650 Digital Camera Logo
76 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
