Question about Panasonic Microwave Ovens
Our Panasonic Inverter Steam Plus (model NN CS596S has just stopped working for no apparent reason. (It only 14 months old and we are still paying for it.) The plus/outlet works fine with another appliance. We were simply heating some water in the oven when it blue a fuse -- for not apparent reason. We reset the fuse and tried it again. It blew a fuse again. We have no idea where to find someone to serve this appliance here in Geneva Switzerland. (We are on government service here and we bought the item here.)
josh1856
  • 105 Answers
SOURCE: RCA Microwave stopped working
it probably just died they do that sometimes. you could take it back to the store you bought it, contact RCA or just throw it out and replace it with another.
Posted on Jan 26, 2008
SOURCE: Panasonic Microwave inverter oven model,
10 Amp fuse blown inside oven.
Posted on Apr 19, 2008
SOURCE: Panasonic NN-CS596S Convection Combi Steam Oven
Thanks for this. Thats exactly what I did. It didn't work at first, however, I think it was my impatience! After selecting the Microwave, you MUST wait until you are told via the screen to input the time. It now works fine. Thanks again. Just needed perseverance! Mike
Posted on Aug 18, 2008
hi i have the panasonic combi and on the microwave it will work for a few seconds and then stop and on the screen it shows h98 please help
Posted on Sep 13, 2008
SOURCE: Buttons work hardly on my Miele M625EG
I have the same problem with my M625EG-ed from about the same period. My repairman said that it would be at least 300 € for a new unit. I opened it myself and cleaned the keypad with alcohol or aceton. It's not working perfect afterwards but it is better.
There's a fuse you have to take out when opening. Otherwise you can have problems with electricity (be carefull). The fuse I had, broke down and I had to buy a new one for 20 eurocents. Also watch out with the parts where the door closes. I had some problems with that too and now (after a few months), I had to buy a new connector part on the door (its the part of the door that closes the door and gives connection for the lights). This costed 12-13 € but I'm trying to install it now.
Andy Mahieu, Jabbeke Belgium
Posted on Oct 14, 2008
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Jul 03, 2017 | Panasonic Microwave Ovens
MY PANOSONIC INVERTER SHUTS DOWN AFTER 14 SECONDS MODEL # NNCD989S
Check again.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
Order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
Jun 29, 2011 | Panasonic NN-H275SF Microwave Oven
6 year old Panasonic 1250W High Power Inverter Microwave Oven (Model NN-S954WF) Manufactured May 2004 has completely died. Wondering what might be the problem and is it fixable or should we just get a...
These early inverter microwaves blew their high current power transistors quite regularly. These high current power transistors are quite expensive to replace, and if one blows, there is a likelyhood of others blowing. As the microwave is over 13 years old, I'd suggest getting a new one. Inverter technology in microwaves is now a mature technology, resulting in reasonable prices and much improved reliability.
Nov 12, 2017 | Panasonic NN-S954WF Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
If you do indeed have a problem, Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 16, 2008 | Panasonic NN-SN657S Microwave Oven
Microwave stops after 14 seconds.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 22, 2008 | Panasonic NN-S961 Microwave Oven
NN-T990SA Panasonic Microwave Stopped Heating
This model uses an inverter to produce high voltage instead of a convential transformer system. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Some manufacturers do not encourage or assist technicians to repair microwave inverters. Most offer the inverter as a whole assembly. But sometimes that is actually cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized repair shops and ask then specifically about inverter repair and inverter replacement costs for your model number.
Dec 21, 2006 | Panasonic NN-T990SA Microwave Oven
Microwave shutsdown after 24 seconds, does not heat up
Classic symptom of a defective inverter. It it's under warranty, you're probably in luck. If not, expect repair costs of about $120-150. If you can find a servider who will repair the inverter instead of just replacing it, you can save some money. If you or a friend can replace it yourself, you'll really save, assuming you follow safe procedures. You can find my file "safety.txt" via a Yahoo search. It is part # A606Y5X00AP for model NN-T993S and runs $62.83 plus shipping. The inverter can be gotten from Panasonic at http://www.pasc.panasonic.com/epartr
Sep 01, 2006 | Panasonic NN-T993SF Microwave Oven
Microwave Ovens Logo
493 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
