Question about Nokia 3110 Cellular Phone
My nokiA3110C NOT STARTED AND WHEN STARTED ONLY SEE LOGO BLINCK 3 TIMES AND THEN SWITCHED OFF BUT NOT CONNECTED PC WITH USB
My 3110c is not powering on, when i press the power button, power supply machine shows some ampere load but phone is not powering on. please give me solution.
Posted on Feb 18, 2010
  • Nokia Expert
  • 2,973 Answers
The battery could be absolutely dead. try using it connected to the charger. If that does not work then try updating the firmware. Use the Nokia PCSuite to update the firmware but keep the battery charger connected throughout. just in case.
Posted on Dec 11, 2009
Yeah so about 3 weeks ago, my Dell D600 which is running XP Professional SP3, 2gb ram, an internal bluetooth, and using a usb wireless adapter, started to freeze at completly spontanious times. Everything...
Hi Chad,
It sounds like it could be 1 of 2 issues either the memory or your hard drive may be failing.
Please do the following:
Turn on the computer. When the DELL logo appears, press immediately. If you wait too long and the Microsoft Windows logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again.
When the boot device list appears, highlight Diagnostics and press .
Please choose the express test and post the results.
Sep 15, 2010 | Dell Latitude D600 Notebook
Hello my nokia 3110 mobile got hang and switched
my nokia 3110 mobile got hang and switched off automatically. to restore factory setting i put the code 12345 or 00000 but i shows code error. i think there is virus in my mobile. now i dont know the exact code to format my mobile. pls send me the procedure to format my my and give me the right code to format it. follwing is the information of nokia3110c: Email Id :- yogeshkumar5555@gmail.com
Aug 07, 2010 | Nokia 3110 Cellular Phone
I have a IOMEGA Screenplay Pro HD 1 TB drive. It was all working fine on TV and PC. But suddenly after I used it with my PC for transferring files, I switched it off and then connected it to the TV. Now...
have u tried the tv sys button on the remote ? reperat a few times as it cyclels thru the formats. or the source button. first disconnect the usb
-will power
Nov 13, 2009 | Iomega ScreenPlay Pro MP3 Player
During installtion error shows that xp logo not passed,stop installation.When installed anyway icon occurred &intallation is completed.After restart *228 is called to activate,after programming of 2.15...
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and DEVICES (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updatig the drivers from the KOSS site
Sep 13, 2009 | Koss USB Dongle Wireless Adapter
Phone switches off after screen flashes 3 times
FLASH ur phone with hwk dongle it will be ok
Aug 19, 2009 | Nokia Lands Phones
My Garmin forerunner 305 recently got immersed in
I have read in some other posts about the unit only working while being plugged into a USB port. My guess is that the battery is in fact shot and the unit will only run off the USB port while plugged in. Submersing in water is not a good idea. On the back of the unit there are some small holes for the speaker. These speakers corrode from sweat and eventually quit.
Jun 05, 2009 | Garmin Forerunner 305 GPS Receiver
In USB mode the player shows pioneer logo but unable to get menu
To resolve the problem I unplugged the DVD player from the power source. I then re connected the DVD player to the power and switched it back on. I was then able to get the menu back on the TV Screen. All working OK again
Mar 27, 2009 | Televison & Video
Monitor malfunction
Hi!
You might also try to connect another monitor, to check if has the same behavior. In this case the problem is generated at graphics card or from loosen cable connections.
Jan 06, 2009 | LG Flatron L1715S 17" LCD Monitor
Frozen MP3 player - MPIO HD300
Try to reformat using your USB 2.O, with The Super-Reboot MP3 Software, may take up to 24/48 Hours to Reformat
Jan 18, 2008 | Mpio HD-300 MP3 Player
Nokia 3110 Cellular Phone Logo
197 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
