Question about Haier HWD1000
Which compartments are for detergent, (and prewash), and which for softener? And why does the manual say 'add softener after laundry is softened?
  • 57 Answers
Of the three chambers, the only one designed to take liquid is the softener. This will have some sort of syphon in it. The other two are prewash (smaller) and main wash (larger). Regarding the instructions, this unit is made in China and is probably translated incorrectly (I'm not being funny on this one)
Posted on Dec 11, 2009
  • Ikaris Dec 03, 2010
    When you are facing the front of the machine, The first compartment on your left is soap, middle is fabric softener and right is prewash.
    Soap is the largest compartment. Fabric softener has a little plastic mushroom shaped piece sticking up from the bottom.
  • Vee Ru Feb 19, 2013
    Is the compartment tray removable for cleaning?
Hi. I have a 2nd hand WD8016C LG but dont know which compartment is pre wash, wash + fabric softener. Also, bubbles form at the window and stay at the end Thankyou
First compartment on right side of drawer is prewash, next to it on the left is wash, second compartment on right is softener. Bubbles because you are using far too much detergent. Only use 2 tablespoons max for normal fairly large wash load, even less for smaller loads. Front loaders use little water, so need much less detergent. Also, highly suggest you not use softener, leaves residue in washer that soon turns to mildew and bad odors. Use white vinegar in its place. Helps remove detergent residue from clothes, keeps tub smelling good, and is very inexpensive. Liquid detergent is also an issue--it too leaves residue behind. Powdered detergent works much better and also is cheaper(counterintuitive you would think liquid dissolves better, but it doesn't).
Dec 16, 2016 | LG Washing Machines
Laundry detergent & fabric softener go into the washer at the same time immediately when started, the fabric softener should only be released when rinse cycle begins, how do I fix this?
without knowing what your machine is I would suggest that you start your load with only detergent in it the after it has filled and is agitating add the fabric softener-you may have to pause the cycle to do this-hope this helped-cheers Denny
Oct 21, 2013 | Washing Machines
I would like to know what laundry detergent and softner to use in my front load, and the right amount to use. I buy the H E products and some of them are really sudsy in the wash sink and I have this awful...
You should use HE detergent following the directions for that detergent. You can add liquid fabric softener. Make sure to fill the appropriate compartment to the Min line if you are doing a small load.
I've never used a washer that drained into a sink (always had a stand pipe). However, I suspect that the gummy residue is the excess softener that was removed in the rinse cycle. Try rinsing the sink with hot water after a laundry. This is part of the procedure to clean the inserts and detergent/bleach/fabric softener drawer when you get a build up in the drawer. In the future, use less fabric softener in the washer. Alternately, skip the fabric softener in the washer but use a dryer fabric softener.
The manuals for most Frigidaire appliances are available from http://www.frigidaire.com/manuals .
The direct link for the manual (in English) for the is: http://manuals.frigidaire.com/prodinfo_pdf/Webster/134609000een.pdf .
I hope this helps.
Jun 05, 2011 | Frigidaire ATF6000ES Front Load Washer
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Nov 13, 2009 | Maytag Washing Machines
Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Feb 22, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Adding detergent/softener/bleach
U cud, but not recommended as it cud lead to oversuddsing, causing all sorts of prob's.
Stick to recommended doses.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Excess water remains in detergent/softener compartments
the best thing that you can do is to pull the dispenser out and clean it. the softener works on a siphoning action and if it is a little clogged then it will not work properly
Dec 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Completely dumb question
Hi, we have a hotpoint aquarius - the "fan" compartment on the left is for fabric conditioner, the blue thing is to save you measuring it out in the bottle cap. Number I is for prewash detergent (only if you're doing a prewash) and number II is the main detergent compartment, the one you would usually use. Hope this helps?
Jen
Jan 17, 2008 | Hotpoint Aquarius WD640 Front Load...
Which compartment is for the laundary soap
According to my information the dispenser drawer has four separate compartments for adding laundry products to the wash load. These compartments are:
1. Prewash Detergent Compartment
2. Main Wash Detergent Compartment
3. Bleach Compartment
4. Fabric Softener Compartment
Laundry products are diluted and dispensed automatically
at the proper time during the wash cycle. The separator in the Prewash and Main Wash Detergent Compartment can be moved to accommodate either liquid or powdered detergents.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Haier HWD1000 Logo
390 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
