Question about Sony Playstation 3 (PS3) Console
I won't start - after hitting the power button, it
I won't start - after hitting the power button, the power light goes green, then blue, then yellow, beeps twice and contiues to blink red. The book says that it may be too hot but it's been off for 6 hours. Thanks.
    Problem Solver:
  • 10 Answers
Your hard drive may be fried
Posted on Dec 11, 2009
2000 KIA SPORTAGE STEREO WIRING DIAGRAM
You can use the attached diagram for assistance, but here goes:
1. Blue/Yellow (Pin 1) - Illumination (+12V) (when headlights on)
2. Black/Yellow (Pin 1) - Main Power (+12V)
3. Light Green/Black (Pin 2) - Memory Power (+12v)
4. Black (Pin 11) - Ground
5. Blue/Red (Pin 9) - Left Front Spkr Return (-)
6. Green (Pin 19) - Left Front Spkr Signal (+)
7. Brown (Pin 10) - Right Front Spkr Return (-)
8. Light Green/Yellow (Pin 20) - Right Front Spkr Signal (+)
9. Blue/Orange (Pin 7) - Left Rear Spkr Return (-)
10. Green/Yellow (Pin 17) - Left Rear Spkr Signal (+)
11. Green/Red (Pin 8) - Right Rear Spkr Return (-)
(Note here that the wire color at the rear speaker is
Green/Blue - not sure if this is a misprint (see diagram))
12. Yellow (Pin 18) - Right Rear Spkr Signal (+)
Nov 10, 2013 | Vehicle Parts & Accessories
Playstation 3 cut off mid play and won't come back on have steady red light!When you hit the power it goes green blue yellow then flashing red!
Call Sony. They will fix it for you, no problem. They will ship you a "Coffin" to send the PS3 back, and if it can not be fixed, they will replace it with a refurbished one.
Jun 18, 2011 | Sony Playstation 3 (PS3) Console
I need a steering column wiring diagram for a 1979 cj5. On the column side of the plug that goes to the steering column there are 8 wires. White, Black, Yellow, Green, Purple, Brown, Light Blue, and Dark...
Black horn ground
lt.blue left front turn
blue right front turn
brown hazard power
purple turn signal power
yellow left rear turn
green right rear turn
white brake light input
Feb 12, 2010 | 1983 Jeep CJ5
My PS3 will not power on, when it is pluged in the light is red, then when I hit the power button the fan kicks on the light turns green the blue light comes on and then with in 3sec blue light goes off...
YLOD...you got a big problem Yellow light of death...could be a cracked bga under the PS3 Cell or RSX processor, to fix you will need to reflow to fix this bga crack that´s causing this YLOD..reflow is a kind of resolder technique...you will have to use a smd air resoldering station...try to check your hdd..try to change it with another one...restore your ps3 system...tell me more details and I will support you...if your ps3 is still in warranty ask for recall...
Sep 14, 2009 | Sony Playstation 3 (PS3) Console
I hav a 95 berrta and im tying to put a head unit
Hello chrisuftring,
Here's a link to the wiring color code for the '95 Chevy Beretta.
You'll need to match the function of each wire from your head unit and the color code for that would be in your manual. Most aftermarket units are somewhat standard as far as power, accessory, ground, and speaker connections are concerned. But the wiring colors may be different for such leads as remote, power antenna, illumination, dimmer, and muting.
An Alpine head unit has the following wiring colors:
Blue - Power Antenna
Blue/White - Remote
Pink/Black - Audio Interrupt (muting)
Orange - Illumination
Red- Switched 12V+
Yellow - Constant 12V+
Black - Ground
Gray - RF Speaker (+)
Gray/Black - RF Speaker (-)
White - LF Speaker (+)
White/Black LF Speaker (-)
Violet - RR Speaker (+)
Violet/Black RR Speaker (-)
Green - LR Speaker (+)
Green/Black - LR Speaker (-)
With this head unit, you would wire Yellow to Orange, Red to Yellow, Black to Black, Orange to Gray, Blue to Pink, Gray to Light Green, Gray/Black to Dark Green, White to Tan, White/Black to Gray, Violet to Dark Blue, Violet/Black to Light Blue, Green to Brown, and Green/Black to Yellow.
Note that there are 2 "yellow" wires in your vehicle color code. You'll have to test them to determine which one is the accessory wire and which one goes to the left rear speaker. Using a 12V "test light" is the simplest. Connect one side of the light to ground. With the ignition ON probe the yellow wires. One of them should light the tester, the other one won't. Verify that the light goes out when the ignition is OFF and your have separated the redundant "yellows". The one that lit the tester is your 12V+ switched wire and the other one goes to the left rear speaker.
Hope this helps.
Sep 11, 2009 | Dual Car Audio & Video
Wii Console will not turn off. After pressing the Power off button the console light goes from green to yellow (not red.) After about 5-10 minutes the blue light will start to cycle on and off and the game...
try turning it off on the console and not with the controller. turning it off with controller turns it yellow. press and hold the power button on console for 5 seconds it should turn red.
Jun 30, 2009 | Nintendo Wii Console
Wii standby light
To be precise, you can turn this option off from the Wii System settings -> Wii Connect 24 -> standby connection -> off
When this setting is swiched to off, your console shuts down entirely and there is a RED light on the power button. There will be no need to turn off the console pressing the power button.
Jun 10, 2008 | Nintendo Wii Console
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Sony Playstation 3 (PS3) Console Logo
171 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
