Question about Sony VAIO VGP-BMS33/B
My mouse connect to the laptop however the scroll are not functioning.please advise.
    Guru:
  • 81 Answers
Check the mouse with any other laptop/desktop, if the scroll is working there. If its working then try a different USB port to connect the mouse and install any softwares which came with the mouse.
If its not working with other PCs also, then you need to get a new mouse or claim the warranty if your mouse is in warranty.
Regards,
Shrey
Posted on Dec 11, 2009
Samsung laptop my left click on the touchpad not working can you advise please
Does it work on an external mouse?
If yes, its a bad connection inside laptop - ribbon connector from touchpad to motherboard.
If no, the left click is not set to any function in laptop Control Panel. Try to reset it.
May 02, 2017 | Samsung Computers & Internet
How do I disable touchpad scroll bar
Go to Control Panel > Mouse. Open the Mouse Properties window, select the Device Settings tab then Settings, and locate "Virtual Scrolling" on the left menu. Uncheck "Enable Vertical Scrolling." Apply and get back. You would be done!
Jun 19, 2013 | Computers & Internet
Vertically and horizontally finger scrolling on my vaio laptopnw series is not working any more or maybe i have deactivated it,i had a touch pad icon on my toolbar hiden icons before ,but not anymore.how...
Hi sheki_68,
If you have disabled the Scrolling Feature of the Touchpad, you will need to re-enable for the function to work correctly. You can enable the Touchpad Setting from the Control Panel, Mouse Options.
  1. Click the Start button and then click Control Panel .
  2. In the Control Panel window, click Hardware and Sound .
  3. In the Hardware and Sound window, click Mouse .
  4. In the Mouse Properties window, click the Function tab.
  5. To enable the Scroll function, click to check the box next to Use Scroll Function.
  6. Click the OK button and then close the Hardware and Sound window.
This should re-enable the Scrolling Feature of the Touchpad. If the Function is not available in the Mouse Properties window, you may need to re-install the Touchpad Driver in the Computer to fix it.
Good Luck!
Hope this helps.
Please post back if you require further assistance.
Thanks for using FixYa.
Oct 20, 2010 | Sony VAIO NW270FS Series 155" Notebook PC
Cant get the font to change on a web page that I somehow made smaller
Hello
OK, all you need to do is to hold down the "Ctrl" button on your keyboard. While you hold down the key, you need to scroll with your mouse button, If you have an external mouse plugged in, you just need to scroll with the middle mouse button. If you use the mouse pad on the laptop, the left side on the pad is usually the scroll function.
So...Just to be clear. Open your web browser. Hold down the "Ctrl" key on scroll up or down with your scroll function.
Hope this can be of help. Also, please do not hesitate to let me know if you need any further assistance.
Kind regards
Andrea
Sep 19, 2010 | Samsung N310-13GO Netbook
Scroll pad not working on hp laptop mouse still works though
Need to enable Scroll function on the notebook.
Scrolling function is not working:
  1. The scroll function may stop working if the scrolling feature is disabled in Mouse Properties. To enable the scroll function, follow the steps below.
  1. Click Start , Control Panel . Select Classic View from the left side of the Control Panel window.
  1. Double-click Mouse in Control Panel, and then select the Device Settings tab in the Mouse Properties window.
  1. Click Settings , Virtual Scrolling . Select the boxes labeled Enable vertical scrolling and Enable horizontal scrolling .
  1. Click OK to save and exit the Mouse Properties window.
  1. After changing these settings, the scroll function on the touchpad will be enabled.
Jul 24, 2010 | HP Pavilion dv5000t Notebook
How do i turn off the scroll function on the mouse pad ? (compaq presario m2000)
Dear friend don't worry its so easy thing. You have functional in in your keyboard. Its called "Fn"
Press FN+F12 Key for turn off/on scroll function .
Thanks & waiting for your reply.
Feb 05, 2010 | Compaq Presario M2000 Notebook
IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
Jun 02, 2009 | IBM Optical Travel Mouse 2224P0480
Quickplay touchpad above keyboard
The following illustration and table describe the computer TouchPad.
(6)
TouchPad on/off button Enables/disables the TouchPad.
Component Description
(1)
TouchPad light Blue: TouchPad is enabled.
Amber: TouchPad is disabled.
(2) TouchPad* Moves the pointer and selects or activates items on the screen.
(3) Left TouchPad button* Functions like the left button on an external mouse.
(4) Right TouchPad button* Functions like the right button on an external mouse.
(5) TouchPad scroll zone* Allows you to scroll up or down.
(6) TouchPad on/off button Enables/disables the TouchPad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 08, 2009 | HP Pavilion dv9000z Notebook
I cant get any mouse to work on my dell laptop.
see the very first thing is that what u can try is that try and connect the same mouse that u had and that had worked and if works then the prob is with the mouse that u have right now and if that also doesnt work then the usb port on the laptop has gone bad and u need to replace the motherboard of the computer but before replacing the motherboard try and connect some other usb device on the same usb port.........
Jan 25, 2009 | KEIO PS2 Optical Scroll Mouse
Computer locked
there are combinations of function or "hot keys" for enabling or disabling these functions. The NuLk is a combo of the functin key and the NumLk key pressed simultaneously. The scroll lock is the one keeping your mouse from working properly. I'm not familiar with your particular unit to advise which keys are necessary to disable Scroll lock, but they should be marked. Also, some notebooks have a switch to disable the mousepad...Usually indicated by a light located above the pad itself. Good luck Harvester3
Aug 18, 2007 | Averatec 3200 Notebook
Sony VAIO  VGP-BMS33/B Logo
196 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
