Ide controller for dell inspiron 2500 laptop
This is a 2002 laptop, 7 years or more old, are the ide controllers for the hard drive on the motherboard on a attached printed corcuit board[pcb] or are they built into the 20gb hard drive which came with the laptop and should the cmos battery be 7.4 volts as new cause the cmos clock is not keeping time and when i checked cmos battery the voltage was 3.4 volts. With this ambios and intel 815em chipset i am told that the 20gb hard drive is the largest hard drive i can use with this motherboard, is this correct,please advise on these issues.
  • 1 more comment
  • Priyabrata Das
    Priyabrata Das May 11, 2010
    damn.....that's a really old laptop... try to buy a new one....after copying your essential files from your old one..
  • Semi-Driver
    Semi-Driver May 11, 2010
    Wow. In all your preamble, not one mention of make, model, OS ... nothing, nada, nil. What are we supposed to do with this?
  • Robert Hamilton
    Robert Hamilton May 11, 2010
    Hi, could you give the model number please? thank you.
    Brigadier General:
  • 10,406 Answers
Any 20GB disk-drive has built-in drive-electronics,
which interface with the IDE hardware on the motherboard of the laptop -- typically, laptops do *NOT* have "plug-in" adapters for such "basic" functions, unlike desktops, where you can change video/audio/network hardware via add-in cards.
You probably can use any disk-drive that is _smaller_ than 32GB -- disks larger than 32GB require newer motherboards, due to the larger capacity of those disks.
Posted on Jan 15, 2010
I have a problem in my cdrom(dell inspiron 1525) it is giving eroor code as 0148 while diagnostic.plzz send me a good solution other than buying a new cdrom
Sorry, the error code indicates IDE ERROR: status which means that your CD drive is bad or the circuit which controls it (the motherboard).
Aug 08, 2011 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
1st, my desktop (dell Dimension 5100) had been not used for several months. When turned on, the green error code lights 3, 4 and a flashing battery appeared, along with a beeping noise. I read up on the...
I assume your new computer has IDE controller on the motherboard.
Yes you can install your old hard drive into your new computer as a Slave hard drive.
If the old hard drive is installed on the 2nd IDE controller and it is the only device on the controller then the jumper and be master or slave, but connect the hard drive at the last connector on the IDE cable.
Oct 18, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
NEW HARD DRIVE DOES NOT WORK IN LEGACY LAPTOP
Make sure you have the drive set as "Master"
Can you tell me what error your getting?
Then I can further assist you.
Thanks
Apr 27, 2010 | Dell Inspiron 2500 Notebook
Hi I got a Dell Inspiron 6400 laptop. The current HHD is the seagate momentus 5400.3 120g. This is now damaged. Can I use the Seagate Momentus 5400.6, 320 G, 5400 RPM SATA2. Will my laptop support the 320g...
Hello: I see no problem using a bigger harddrive in the unit,the only concern I think you might have is to purchase a hard drive caddy for the interface, Especially if the current hard drive is an IDE Interface, You can purchase a IDE to Sata Interface caddy, to support the drive Interface if it's an IDE format. You might want to check with Dell for compatibility first before purchasing the Sata Drive.
Nov 30, 2009 | Dell Inspiron 6400 Notebook
Adding old hard disk. 20 GB Quantum Fireball Ict, in Dell 9200 PC
if it's old it's probably IDE also known as PATA. it looks like a wide ribbon. There should be a header on the motherboard that looks exactly like the plug on the back of the hard drive. It will be labeled IDE1 probably if you have it. Old motherboards used to have 2 IDE headers, modern ones have one or none. The ribbon will have three plugs--one for the mobo, and then two spaced closer together for the master and the slave. You need to hook it to the appropriate plug (master if it's the only device on the ribbon) and make sure the jumpers on the HD are set properly to make it self-identify as the master. Good luck!
Nov 09, 2009 | Dell Dimension 9200 PC Desktop
I have a Dell Inspriron B130 laptop computer. I
Dear,
This is a clear hard drive issue. Try reinstalling Operating System, If it fails again, probably you have to replace the hard drive
Oct 15, 2009 | Dell Inspiron B130 Notebook
INstalled hp dvd1270i in my dell 4700. I have power but it doesn't recognize the drive. Does it matter if the old drive was a ribbon cable and the new one is sata?
Do you have the DVD daisy chained to the motherboard with another drive? I have the same Dell and I have 2 hard drives IDE, and a DVD with a CD burner which are seperate so they are on the other IDE connection daisy chained. The IDE controller will allow 2 devices and there are 2 IDE controllers on the motherboard. eMail me at izzoaf@yahoo.com with more info and questions and I"ll try to help.
Sep 17, 2009 | Dell Dimension 4700 PC Desktop
Extremely slow transfer speeds from IDE hard drive to Sata
That causes that switching from IDE to SATA connection..youR IDE drive can be read slower than the sata due to speed compatibility. The new PC now proccess slower to old hard drive or IDE. so thats matter. i experience that also so i remove the drive after copying all the files it and i set aside for storage purpose only.
may this help,
melnavz
Feb 18, 2009 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
My hard drive took a **** and my dvd burner will not pop out
Hi a_stoeger, it is possible for you to get what you need. Or even better. Below is a list of links for your viewing. The best site is the first link.
Hard disk drives for the Inspiron 600M laptop. (Great site).
http://www.drivesolutions.com/cgi-bin/shop/ug2store.cgi?command=listitems&kind=dll&pos=0&type=itemid&itemid=dll9
CMS Products Easy-Plug Easy-Go Hard Drive - 60GB - 4200rpm – Ultra
This hard drive is designed for Dell Inspiron 500, 600m Series.
http://www.google.com/products?q=60GB+Ultra+ATA+Hard+Drive+for+Inspiron+600M+notebook&btnG=Search+Products&hl=en&show=dd
Brand New CD-RW/DVD Combo DRIVE for Dell INSPIRON: 300M,500M,510M,600M.
http://www.acer-laptop-battery.com/cdrwdvd-combo-drive-dell-precision-m20m60m70-p-466.html?zenid=12m5dirv47ffvjf6jc5pc85lp0
New combo drive. Fits the 600M
http://www.upgrademaster.com/dvdrw-cdrw-drives-c628/dell-dvdrw-cdrw-combo-drive-p26078.html
Brand New CD-RW/DVD Combo DRIVE for 600M 500M With One year Warranty
http://www.power2battery.com/dell-inspiron-600m-500m-cdrwdvd-combo-drive-p-697.html
If there is any life left in your notebook drive connecting it to another IDE drive could allow you to transfer the data to the PC.
This next link is for connecting your laptop drive to a PC drive.
http://www.paddlersite.com/2lato3deideh.html
Cost effective!
Good luck a_stoeger!
Mike
Jan 05, 2009 | Dell (04U621) for Latitude D600, Inspiron...
Computers & Internet Logo
98 people viewed this question
Alun Cox
David Payne
David Payne
