Question about Philips 23PF9945-37 23" Flat Panel LCD Monitor
Problem with colour
I have a 32pw 78 wide flat tv last couple weeks i have got blue down right screen left side has yellow can you tell me what could be wrong thxs
0 characters
1 Points
How can i play ps2 on lcd without having a black and white screen ? how can i connect the cables ?.....when i look at the back of my lcd i find three ports (red white yellow) when i use them the screen is...
1) The set of input (Yellow= Composite video, Red= Right channel audio, White= Left channel audio). This set of input is for composite video.
2) The set of input (Red= Red video signal, Green= Green video signal + sync, Blue= Blue signal, Red= Right channel audio, White = Left channel audio (the Red and White will be grouped close together). This set of input is used for Component video for HD signal.
You should try using composite video source (Yellow RCA jack) from DVD player and feed to the monitor and see if it works OK with all color showing that way we acn find out if it is the video source problem or the monitor video signal processing problem. Try the PS2 on the TV if it works OK also.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 20, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
Hi, I am Barbara Acer X193W LCD Monitor. I
If the screen is side ways, it is caused by unintentional pressing Ctrl-Alt plus a left or right arrow.
Restore by pressing Ctrl-Alt plus up arrow
If the screen is upside down
Caused by unintentional pressing Ctrl-Alt plus down arrow.
Aug 23, 2009 | Acer X193W BD 19" Wide 1440x900 LCD...
My monitor has a variety of colors going down the left side of the screen and across the top of the screen
increase colour quality 24 or 32 bit from display properties, if there are no options than u have to install display driver.
Aug 02, 2009 | Gateway 19" Widescreen Flat Panel TFT LCD...
My monitor's color is mixed with the color yellow
There is an option on the monitor to reset colour to factory default. Just bring up the on screen menu by pressing the left most button at the botton. Use the button next to this to highlight the colour settings which I think is the 5th or next to last option down. You will then see the option to reset colour and various other factory default settings. Happy computing
Jul 21, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Rear projection screen 152cm lg going yellow
I am guessing that this is an LCD projection set, Please post the make and model so I can confirm. In the mean time, if it is an LCD, there are 2 possiblities.
1) The lamp may require changing. Sometimes the inner surface deteriorates because of the heat.
2) The "light engine" requires replacement as the heat and light have started to burn the LCD surface. This burning starts to show up as a yellowing usually onm one side first and spreading to the other side.
May 07, 2008 | Computer Monitors
Blue screen
Well, your screen changed colors....due to defective AD board. Need to replaced a new AD board.
Apr 28, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
you will have a mains lead with an electric kettle type connection on one end which plugs into the rear of the screen and another similar lead for the pc.
the video lead from the screen will plug into a small dovetailed shaped connector coloured blue on the rear of the computer ( it can only fit one way round , as its broader on one side than the other )
the speaker leads will probably be small jack plugs one for left and one for right, and they plug into the rear of the computer, audio out / left / right.
Jan 05, 2008 | Mag Innovision InnoVision LT 765S 17" Flat...
Philips 23PF9945-37 23" Flat Panel LCD Monitor Logo
20 people viewed this question
Top Philips Computer Monitors Experts
 Mike M
Mike M
Lawrence Oravetz
olayoju victor
Are you a Philips Computer Monitor Expert? Answer questions, earn points and help others
