Loading music from pc to a sd memory card with photos for an IQ picture frame
Can not load music on Sd memory card to play in IQ picture frame with pictures
SOURCE: IQ Digital Picture Frame
Go back into your original file and rename your photos in the exact order you want them in. The frame show the pics in the order they are listed in the file. So name your first picture image 1 and so on, and the frame will show them in that order. Be sure to check the order while you still have the file on your computer (to save yourself the hassel of taking the memory card in and out a million times). Click "view" in the top toolbar. Then "arrange by name" to see the new order. That way you can be sure they are in the order you want.
Posted on Dec 18, 2007
SOURCE: Matsui 7" digital photo frame
I got one for xmas and pics download easily every time. I connect my camera to the laptop then load the shots I want onto the SD card on the camera, disconnect and remove the SD card from the camera then insert in the frame. I have had no problems with photo size or downloading time. I do have a problem when I remove images from the SD card however. The frame still displays images that I deleted and are not showing when I connect to the laptop!  Can anyone help?
Posted on Jan 07, 2008
SOURCE: Trutech 7 Digital Photo Frame.
Try a new unformatted SD card (now they are around $10/1GB).
Posted on Jan 12, 2008
SOURCE: I can't load photos onto my digital photo frame
The  A701 is  a bit cranky.  I've found that it prefers  USB  flash sticks of upto  2GB. It likes the flash stick formatting  before use.  And it prefers  jpg files  added  to the root directory of the flash stick -  so  no images in folders. Finally but probably least important, it's not much point uploading  2MB  jpgs as  the screen  is pretty much  72DPI  smaller size JPGS  lead to a faster loading. ( try  around 900x 600 dpi )
Posted on Jan 02, 2009
SOURCE: IQ Digital Photo Picture Frame - Need Engish Operating Manual
Posted on Oct 20, 2009
SOURCE: I have a Brookstone digital picture frame that stopped working
I have encountered this same error on the frame I bought 2 years ago. I saved the pictures to a backup and then reformatted the frame - this didn't work - does anyone have any other solutions???
Posted on Jun 05, 2010
0 characters
1 Points
Once rotated photos on my computer to put on sd card the frame rotates them back
When loading pictures from PC to SD card you need to rotate and save at that stage!
Jan 02, 2016 | Digital Picture Frames
Transfer pictures
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
Dec 13, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
I lost instructions to my Optimus 7" Digital Photo Fram
You can change out your pictures by having an XD or SD Memory cards if you have a card reader for your computer plug in the memory card put the photos on to it that u want on ur pic frame and plug it in to the xd/sd card slot on the left hand side of the photo frame and there u go. If you want ur pics off the internal memory u can transfer them from the frame to the card via the options button or menu button that is.
Nov 30, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
77 people viewed this question
Top Tao Digital Picture Frames Experts
matt martin
matt martin
Are you a Tao Digital Picture Frame Expert? Answer questions, earn points and help others
