What processor can i use to upgrade the hp dv5000 currently i have a intel t2050 processor
SOURCE: IBM ThinkPad T41, Upgrade my Intel Centrino Processor
make sure that the socket supports your new max Intel.
Posted on Feb 05, 2009
SOURCE: upgrading cpu and gpu on toshiba portege m400 -s933 laptop
Next time you get nasty with me on answers, I'm gonna nuke your pc so bad you wont NEED a new processor! Surface mount technology has NOT been around for 50 years to the general public. You are a friggin moron who thinks they know something! I've been involved for 30 plus years in the field PUTZ!
Posted on May 25, 2009
benwabnick
  • 2404 Answers
SOURCE: Upgrading processor on Acer Aspire 5720
What you need to do is to take the motherboard out of there. All the screws will have to com out of the bottom of the laptop.
Then go ahead and the keyboard cover will have to come off, the keyboard itself comes out, then there will be some screws underneath the keyboard that will be holding in the top cover Once those comes out you'll have to take off the screen there will be two screw on each side of the lcd that have to come off.
At this point if threre are any wires coming from the lcd screen, they will have to be disconnected so you can pull the lcd off of the top cover to remove it completely.
Now at this point go ahead there may be a few screws holding in the mothrerboard in place. They will be labeled with arrow so go ahead and remove those.
you can now remove the motherboard from the laptop. The cpu will be underneath the cup heatsink assembly which will require some screws to remove the heatsink so now it will expose the CPU.
The cpu is in a slot that has a flathead screw holding it in place in the socket. Go ahead and turn the screw, its not meant to come all the way out so move it to the left until it stops.
Finally you can put the new CPU in place and move the screw towared the right so it tightens put the heatsink and fan back and the fan back as well. Put the screws back into the motherboard to hold it ins place.
Put the top cover back on and the lcd and wires back to were they are and then check at this point to make sure you have video and if you do then go ahead put the rest of the screws back and then you have a new updated laptop.
Posted on Jun 26, 2009
SOURCE: Upgrading My hp530 laptop
It is working.
Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
The HP 530 notebook is working OK.
Posted on Mar 12, 2010
KingDWS
  • 1606 Answers
SOURCE: Can I upgrade my CPU to an Intel Core 2 duo 1.7
You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
And you are limted to 2gb of ram max on this model.
Posted on Apr 12, 2010
Testimonial: "Thanks for the quick response. I was afraid that might be the answer but I appreciate the confirmation."
Hard drive from dv5020us to dv5000
Made sure that both HHDD connections are the same Sata or IDE and the processor has to be the same Intel or AMD you should be able but will need to update some drivers.... tekgods
Oct 24, 2013 | HP Pavilion dv5020us Notebook
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
Unsure of processor compatibility with laptop motherboard
You did an awful lot of work to write this question. If you will go back to the HP site, you can find full specifications for your computer and what upgrade paths are available, straight from the horses mouth, so to say. If a upgrade path is listed or indicated, you can follow it. If there is no path, you can't follow it. Simple.
While there may be some processor upgradability, my advice is keep it stock. You have the stock parts - they are suppose to work together. The best and cheapest upgrade I will recommend is put in as much memory as your computer will take and you can afford. If you start changing stuff, you will have heat issues (which may be how you got to this place to start with.)
Thanks for your interest in FixYa.com
Mar 04, 2010 | Computers & Internet
Whats the intel socket set for a hp pavilion dv2550se
If you have the DV2550se laptop with the Intel T5250 processor. These intels sockets are the PPGA478.
These chips are based on the 65nm process.
The link below is to the intel Processor comparison chart for upgrades. It lists 21 additional processors that match the FSB and manufacturing process.
http://processorfinder.intel.com/List.aspx?ParentRadio=All&ProcFam=2643&SearchKey=
Jan 28, 2010 | HP Pavilion dv2550se PC Notebook
Intel Pentium II Processor Upgrade
No, this highest the P-II went to was either 400 or 450 Mhz. Upgrading a thinkpad CPU may be difficult. Considering prices on used laptops now, I wouldn't think it would be worthwhile, either.
Neil
Feb 09, 2009 | Intel Pentium III , 866 MHz...
Need the processor driver
Please try This Link:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=816&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go!
Feb 01, 2009 | Microsoft Windows XP Professional With...
Intel core duo T2050
That is normal for multi core processors.They work by processor load. Why are you concerned.If one core handles all the clock cycles the other is just waiting.your processor is working to 50%.
Aug 23, 2008 | Intel Core Duo T2600, 2.16 GHz Core Duo...
Re. aspire 7104 celeron processor can it upgraded to T2050 duo core
you need driver for your cpu why?
if your bios doesnt detect it correctly you need to update your bios, but in most cases there is no need to isntall a cpu driver.
Apr 25, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
193 people viewed this question
David Payne
David Payne
