Question about Brother DCP 115C All-In-One InkJet Printer
Have a brother DCP- 115C and had a paper jam, I removed the paper from the printer cleared the jam and now printer is telling me Unable to clean see Trouble shooting and routine maintenance in users manual.
  • 222 Answers
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
(for printers with numeric keypad):
Resetting purge counter on: MFC-620CN / MFC-420CN / MFC-410CN / MFC-210C and FAX-2440C:
1. Enter machine maintenance mode (on MFC-210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode.
2. Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3. Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4. Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5. Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6. Press the 9 key twice to return to the standby state.
Posted on Dec 11, 2009
DCP 185C ERROR 50
Sir/Madam
I Suggest You To Watch Clear Error 46 Unable to Clean on Brother Printers Without Number Pad To Fix Your Brother Printer Issue,In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
Jan 21, 2014 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean message
printer brother dcp 115c .unable to clean. what must i do
Jan 19, 2009 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean problem
turn the rpitner of then check there is not any paper jam.
also refix crtridge after clean it.
Jan 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
DCP 115C does not print
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely
the manual states for this problem
"The machine has a mechanical problem.
OR
A foreign obstacle such as a clip or ripped
paper is in the machine."
Aug 05, 2008 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean message in brother dcp-115c aio
I saw on this site codes for another MFC to clear memory and reset the cleaning unit count code to zero. It worked on two of my brother mfc 820cw units. The third mfc 5840cn had unable to print error message 46- nothing at Brother. they want you to take everything to a repair shop.they don't help at all. Then the error went to 4F when I tried toclear the memory.As Iunderstand that message- it means I have to replace the printer head. Have no clue where or what it is. But I can read a manual as well as anyone and follow directions to fix it! Can't be worse than it is now! Good luck
Jul 22, 2008 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean error on Brother DCP115C
Pls refer below to clear the "Unable to Clean" error:
1. Enter MAINTENANCE MODE: Press MENU, MONO START 4x on ARROW UP within 2-3 sec
2. Using the ARROW UP botton, press botton and wait for the ff #:
a. 8 then press SET
b. 0 then press SET
3. Using the MONO START, just press until the word "PURGE XXXXX" comes out
4. Using the ARROW UP botton, press botton and wait for the ff #:
a. 2 then press SET
b. 7 then press SET
c. 8 then press SET
d. 3 then press SET
e. Press Stop/Exit
(This is to reset the purge counter)
5. Using the ARROW UP botton, press botton and wait for the ff # to appear:
a. 0 then press SET
b. 1 then press SET (to reset unit)
c. 9 then press SET
d. 9 then press SET (to exit maintenance mode)
If after this procedure you still encounter problem, see your service center
Hope this will solve your problem "unable to clean".
epc.
Mar 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
1,252 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
