Question about Sendo Sonim XP1 JCB phone extreme performance brand
I have a problem vith my sonim xp1.I use to charge it with mini usb conected to my PC.Please help mee it's not charging enimore.vhat shood i doo?
Model: XP3.20 Quest pro. Brand new. Unpacked it at 13.00 hrs. Placed the sim-card and the battery. Plugged in the wall charger. No sign of charging whatsoever. Unplugged at 17.00 hrs frustrated the charger...
Have you been able to try another charger? Is it getting warm? If not, replace it. I would think that within 28 days if any part is wrong they replace the whole lot so probably best to go back to place you got it and get a brand new replacement.
Feb 03, 2011 | Sendo Sonim XP1 JCB phone extreme...
HELP my new sonim locked me out while I was trying to create password.. My IMEI is 35169603-111206-3 Missing lots of work calls Andre Miller
All you need to do is contact your phone provider for an unlock code to this issue. If your unable to contact them, you may download an approved list from the internet to use while attempting to unlock the cell phone again.
Jan 21, 2011 | Sendo Sonim XP1 JCB phone extreme...
On my phone i can hear the caller but thay can not hear me it is a sonim xp1
when you call someone and they don;t hear you,it means that the mouth piece which is located at the bottom of the phone and allows people to hear is faulty and will need to be replaced.
When you replace the mouth piece, people can now hear you.
Take care.
Aug 04, 2010 | Sendo Sonim XP1 JCB phone extreme...
How to unlock sonim xp1 mob phone.
Hello,the truth is that you can unlock the phone ,but you can't unlock all phone for free.The payment sites are very cheap you could try it out and see.You can the link below to unlock .
Note: unlock is not free, You will be charged to get your unlock code.
The only way by which you can get the unlock code for free is by calling your service provider and requesting for your unlock code.
If you service provider refuses to give it to you, then there is no other place where you can get a free unlock code.
Visit the links below if you are interested in buying the unlock code:
(hubpages.com/tag/cell+phone+unlocking/hot)
and
(mobileunlocked.com/mobile_unlocking.php)
Good luck.
May 07, 2010 | Sendo Sonim XP1 JCB phone extreme...
Sonim xpi jcb toughphone,the phone won't switch on,but when the battery is removed and replaced the phone comes on.However none of the buttons pressed gets a response,can,t enter pin and it won,t turn...
Remove battery,attach and switch on charger,for about 10mins or until charge mode displays,should flash.Insert battery, donot disconnect charger,leave for 2 hours,disconnect charger ,phone should switch on.
Jan 24, 2010 | Sendo Sonim XP1 JCB phone extreme...
Hi, the battery won't charge. We rang and spoke to someone about 2 weeks ago and they said it was probably a faulty battery and they were going to email us and send a new battery, We have heard nothing...
It could be the battery but it is also possible that charger is broken. Try with another charger and if it still doesn't work than the battery is the problem. If both of this things don't work for you than this could mean that jack on the phone is malfunctioning.
Jan 18, 2010 | Sendo Sonim XP1 JCB phone extreme...
No sign of phone charging
I finally have spoken to a very nice youn guy from Sonim Tech Support. He fixed my problem of the phone not turning on.
1. Take out the battery, plug in the mains charger and leave for a few minutes (they say 10 but it took my phone a couple of hours).
2. Eventually the charging symbol will come on the screen, either stady or flashing.
3. Immediately put the battery in the carcass (while it is still connected to the charger), and the charging symbol should stay on.
4. Leave the phone for a couple of hours, disconnect the charger, and the phone should turn on as normal.
This was explained to me, the reason for not turning on was that the software had crashed. This solved it.
Sep 01, 2009 | Sendo Sonim XP1 JCB phone extreme...
My suzuki gsxr 750 loses power with new batteries
hi there . frist i check battery voltage ie fullie charged shood be a bout 12.5 to 12.75 volts this is what a bike battery shood have when fullie charged .then start the bike up and check the battery voltage agen with the head light on high beam at idel it shood be sum were around 13 to 15 volts then bring the revs up to 5000 rpm and check the voltag agen shood be above 13 volts no higher then 15 volts if this is wat you getting at the battery you need to check haw manny amps it is charging ie need a ampe meter for this it shood be putting in at least 1.5 to 2 positive amps to the battery if not the reg-rec of stator cood be faulty or a bad earth . the problem is you need the right tools for this sort of job . and alot of bike shops dont have them . try cleaning the eath temanls top and bottom check all connectors . a lot of the time it is just a bad conection
May 31, 2009 | 1996 Suzuki GSX 750 F (Katana)
Motorola RAZR V3
Install Motorola Phone tools first,it contains all drivers for all Motorola phones,plug the cable and charge
Sep 16, 2008 | Motorola Mobility RAZR V3
Sendo Sonim XP1 JCB phone extreme performance brand Logo
884 people viewed this question
Top Sendo Cell Phones Experts
Marvin
Marvin
Are you a Sendo Cell Phone Expert? Answer questions, earn points and help others
