Question about Garden
How to assemble the saw.
I have stripped the saw for cleaning and the brake part with the pressure washers got me. i dont know in what sequence it must go in.How do i fit the pressure washers on the motor for the slip clutch/brake
Where can i get a assembly drawing of how to put everything back toghether?
Thanks
Markus
  • 2 more comments
  • jim gleason May 11, 2010
    what model do you have? You can access everything you need as far as drawings at www.husqvarnaretailer.com
  • usedtotruck2 May 11, 2010
    Availability of a drawing depends on who makes the saw. Need a brand, model # & serial #. Bar length is not important. And a "Pressure Washer" is a machine with a motorized pump that pressurizes water for removal of debris. Please clarify what you are calling a "Pressure Washer".
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello like loe said it is quite hard to help someone when you don't know the model or brand name.
  • dontbother10
    dontbother10 May 11, 2010
    Markus no guarantees we can help but we cannot attempt what you ask without a make and model for your saw. If Husky, Poulan or McCulloch a serial number may also be needed to properly answer your question. Lou
dontbother10
  • 2220 Answers
SOURCE: Chain brake Assembly
A drawing of a Poulan Wildthing can be found here:
http://www.ordertree.com/modelinfo/PWE/2375-Gas-Saw-Type-1/75.2375-Gas-Saw-Type-1.1.59.1.html
Click "
View the illustrated parts list [Go]"
There are multiple drawings, this one may not be the correct one. The detail isn't very good but this is the best illustration for your saw. The "Handle, Chassis, and Bar Assembly" shows what is available. GL
Lou
Posted on Sep 21, 2009
dontbother10
  • 2220 Answers
SOURCE: clutch brake assembly
I went to Poulan.com and looked at an IPL for a PP4620???, can you say worthless boys and girls? I provide it in case you need parts.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
This thread is dedicated to your saw. Join, post your need and someone wil snap a photo and post or PM it to you.
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/showthread.php?t=115309&highlight=poulan+4620
HTH Lou
Posted on Feb 22, 2010
dontbother10
  • 2220 Answers
SOURCE: cannot reassemble brake band assembly to clutch drum
The brake was engaged when removed. The Illustrated Parts List (IPL) here shows how the majority of components fit together. The brake needs to be released to clear the clutch drum.
Secure the clutch cover (it requires quite a bit of force), with a couple of blocks of wood, in a large vise or a C-clamp on a work surface.
Use a pair of pliers or a crescent and rotate the spoked part CW until it latches. This one is latched.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 17, 2010
dontbother10
  • 2220 Answers
SOURCE: the chain brake on my
You ask a 2 part question, I start with brake band repair/replacement.
A link to a 2004 Husqvarna 137/137E IPL (exploded parts list) follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2004/I04000/I0401903.pdf
See the Chain Brake illustration, item 13 for the band. Item 14 (see Bailey's description. Your local Husky dealer will save shipping fees and is likely about the same price.) is a complete clutch cover $22
Posted on Sep 13, 2010
  • 2239 Answers
SOURCE: husky mod. 51chainsaw. how do i
To re assemble the hand guard back onto the brake cover, place the hand guard as best you can onto the side cover, now use a conical punch to push throught the hand guard and cover, now useing the punch as a pivot pull the hand guard fully back until the brake loads, once loaded remove the puch, the hand guard should now easily align back onto the cover, insert the two puvot collers and re fit the allen screw.
Posted on Apr 10, 2011
Ford ranger 2003 short in truck
Inspect the fuse box assembly carefully looking for oily wetness from behind . If it is wet, its brake fluid that has permeated thru the pressure switch , into the wiring and saturated the fuse box assembly causing the short. The repair is to replace the brake master pressure switch with an updated part that comes with a new pigtail harness and a complete fuse box assembly from Ford that comes with all the fuses needed, just "plug and play". Also as an added precaution, you should isolate the wires that carried the brake fluid, strip off about an inch of insulation, solder the exposed area and re-tape exposed repair area.
Feb 22, 2014 | 2000 Ford Ranger SuperCab
Chain brake not working right
strip cover and check that all the dirt etc is cleaned out and the brake band is in the correct position If the brake band looks worn ie thin in places replace with new one. Dirt can also get in the pivot of the chain brake handle and cause it to jam, saw should be stripped and cleaned at the end of every days use and the bar turned over to even out the wear
Feb 08, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
The chain brake on my little 137 husqvarna saw is broken. The metal strip is snapped . Do I need to buy a complete new brake assembly or can I get only the metal strip and fit it into the perfectly good...
Sep 13, 2010 | Husqvarna Garden
I need a diagram of the rear brakes of a 1997 Intrepid Chrysler-where can I get one>
If the following is not enough then maybe try Alldata.com which generally has more information, but it will cost: REMOVAL & INSTALLATION Chrysler Concorde, New Yorker, LHS Dodge Intrepid Eagle Vision
  1. Remove the rear wheels and brake drums.
  2. Remove the dust cap from the rear hub and bearing assembly.
  3. Remove the cotter pin, nut retainer and wave washer. Discard the old cotter pin.
  4. Remove the rear hub and bearing assembly retainer nut and washer. Remove the rear hub and bearing assembly from the spindle.
  5. Remove the automatic adjuster spring from the adjuster lever.
  6. Rotate the automatic adjuster starwheel enough so both shoes move out far enough to be free of the wheel cylinder boots.
  7. Disconnect the parking brake cable from the actuating lever. Disconnect parking brake cable one side at a time.
  8. Remove the both lower brake shoe to anchor springs.
  9. Remove the 2 brake shoe hold-down springs from the brake shoes.
  10. Remove the brake shoes, upper shoe-to-shoe return spring, automatic adjuster and automatic adjuster lever from the backing plate as an assembly.
  11. Separate the brake shoes from the automatic adjuster mechanism.
  12. Remove the brake shoe automatic adjuster lever from the leading brake shoe. To install:
  13. Thoroughly clean and dry the backing plate. To prepare the backing plate, lubricate the bosses, anchor pin and parking brake actuating lever pivot surface lightly with lithium based grease.
  14. Remove, clean and dry all parts still on the old shoes. Lubricate the starwheel shaft threads with anti-seize lubricant.
  15. Assemble both brake shoes, the top shoe to shoe return spring, automatic adjuster and automatic adjuster lever before mounting on vehicle. Make sure the ends of the automatic adjusters are positioned above the extruded pins in the webbing of the brake shoes prior to installation.
  16. Install the brake shoe assembly onto the brake support plate and install the hold-down springs.
  17. Install the lower anchor springs and reconnect the parking brake cable to the park brake lever of the trailing brake shoe.
  18. Rotate the serrated adjuster nut to remove the free-play from the adjuster assembly.
  19. Install the automatic adjuster lever spring on the lead brake shoe assembly and the automatic adjuster lever.
  20. Install the rear hub and bearing assembly. Install washer and retainer nut and torque to 124 ft. lbs. (168 Nm).
  21. Install the wave washer, nut retainer and a new cotter pin onto the spindle. Install dust cap.
  22. Adjust brake shoes so not to interfere with brake drum installation. Install the rear brake drum. NOTE: After installing the brake drums, pump the brake pedal several times to partially adjust the brake shoes. To verify proper operation of the self-adjusting parking brake, be sure that both rear brakes are not dragging when the parking brake pedal is released.
  23. Install the rear wheels and lug nuts. Torque the lug nuts, in a star pattern sequence, to 95 ft. lbs. (129 Nm).
  24. Road test the vehicle. The automatic adjusters will continue brake adjustment during the road test of the vehicle.
Sep 03, 2010 | 1997 Dodge Intrepid
After about 5 min of use, the trigger no longer activiates the hose.
the triger has a small ball bearing and a spring in it,,,strip out the triger
dont loose the bits and clean then grease it using water proof grease so its free to slide then the jobs a good un? get yourself a drink and go back to power washing ,,but this time it stops when you tell it to?
Aug 08, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
How long does it take to fix front bearings on a 97 dodge caravan? and cost
About an hour a side...This is the whole job and pictures....
The hub and wheel bearing unit is serviced as a complete assembly. Replacement of the front drive hub and bearing assembly can be done without having to remove the steering knuckle from the vehicle. However, if the hub/bearing assembly is frozen to the steering knuckle, removal of the steering knuckle is required.
  1. Disconnect the negative battery cable.
  2. Remove the cotter pin from the end of the stub axle. Remove the nut lock and spring washer. With the brakes applied, loosen, but do NOT remove the axle nut and washer with the vehicle still on the ground or damage to the wheel bearing will result.
  3. Raise and safely support the vehicle. Remove the wheel.
  4. Remove the front brake caliper assembly from the steering knuckle assembly and support from the strut assembly using a strong piece of wire.
    1. Remove the front brake rotor from the hub/bearing assembly.
    2. Remove the retaining nut and washer from the halfshaft stub axle.
    3. Remove the ABS wheel speed sensor from the steering knuckle.
    4. Remove the 4 hub and bearing assembly mounting bolts from behind the steering knuckle.
    5. Remove the hub and bearing assembly from the steering knuckle.
  5. To install:
    1. Thoroughly clean the mating surfaces of the steering knuckle and the hub and bearing assembly of any foreign material or nicks so the surfaces are clean and smooth.
    2. Install the new hub and bearing assembly and tighten the mounting bolts in a crisscross pattern to 45 ft. lbs. (65 Nm). Be sure the hub and bearing assembly is seated squarely against the front steering knuckle.
    3. Install the disc brake rotor.
    4. Install the brake caliper assembly onto the steering knuckle.
    5. Install the axle washer and nut. Tighten but do not torque.
    6. Install the ABS wheel speed sensor.
    7. Install the wheel and lug nuts. Torque the lug nuts, in sequence, to 95 ft. lbs. (129 Nm).
    8. Lower the vehicle. Do NOT roll the vehicle until the axle nut has been properly torqued or damage to the front wheel bearings will result.
    9. With the vehicle's brakes applied, torque the axle nut to 180 ft. lbs. (244 Nm). Install the spring washer, nut lock and a new cotter pin. Wrap the cotter pin prongs tightly around the axle nut lock.
    10. Reconnect the negative battery cable. Check the wheel alignment.
The hub/bearing assembly is attached to the steering knuckle with four bolts
Removing a hub/bearing assembly
If the hub/bearing is "frozen" to the steering knuckle, separate the ball joint and lightly tap on the hub/bearing from behind
The hub/bearing assembly should free itself from the steering knuckle
About $60 a hub.
May 23, 2010 | 1997 Dodge Caravan
Bleed brakes on 96 chevy 1/2 ton
YOUR TRUCK HAS KELSEY HAYES FOUR WHEEL DRIVE ANTI LOCK BRAKES EBC 310. YOU CAN BLEED BRAKES MANUAL STARTING AT - RR- LR RF- LF. THIS IS BLEEDING SEQUENCE.BUT YOU NEED A TECH 1 OR 2 SCANNER BECAUSE IF YOU REPLACED THE BPVM OR BRAKE PRESSURE MODULATOR VALVE.BECAUSE AIR TRAPPED IN VALVE ASSEMBLY.THE TECH 1 OR 2 SCANNER YOU HAVE PUT IN THE FUNCTIONAL TEST BLEED AIR OUT OF VALVE ASSEMBLY.THEN YOU CAN BLEED BRAKES MANUAL.
Mar 27, 2010 | 1996 Chevrolet K1500
How to replace chain on McCulloch chain saw? How do you get the brake over the drive wheel to reaffix the outer cover and brake release?
The chain brake is engaged. support the cover firmly (as it will require a lot of pressure to pull the handle) and pull back towards the operator. When it is re-set, it will then fit properly to be assembled to the saw.
Nov 28, 2009 | McCulloch Garden
Not sure of sequence of steps to replace brake switch. faulty swithch has been taken out.
The brake light switch is made of plastic and has threads on it it is located on the brake pedal, look under the dash nd follow the arm of the brake pedale and you will see a single switch with two or three wires the wires simply pull off and there is a single nut that locks the switch into postion. while looking at the switch wtith a flashlight push the brake pedal down with your hand look to see if the switch loses contact with the metal frame if it does not then the switch is most likely stripped and will need to be replaced. you can buy at any parts store or buy at a ford dealer, they rage from $15.00 to $25.00 dollars if it does not have a lock nut holding it in plcae then screw the switch out after removing the wires and the wires are not on in any patictular order.
May 25, 2009 | 1999 Ford Explorer
Delta 36-075 miter saw. Motor ok, but blade will not spin
It sounds as though one or both of the items are stripped. They mesh to drive the blade so I would not take a chance on just replacing just one. Also when you look at this you might also want to look at replacing the bearings and brushes. Make sure you clean out the gear housing or you will have immediate problems again. Also check where you buy these parts for their recommendation on the grease that needs to be used.
Mar 14, 2009 | Delta Saws
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
