My ViewSonic monitor is having an issue with blurring lines. Anything on the left or middle of the screen blurs to the right in a faded color, extremely noticable when I open MS Paint and fill the left half of the canvas with a color, as it produces a very thick blur extending all the way right across the screen. This is most noticable on screens with a lot of white. What caused this and how do I fix this?
    Genius:
  • 1,121 Answers
This is a tipical flyback defect circuit, the lines can 1st appear on top/bottom of screen, then can increase to center. Send monitor to repair center, for check and repair. You can test with a tv test signal.
Posted on Dec 11, 2009
Screen goes black or pixelates
viewsonic va1703w screen is starting blur and it is changing colors Screen goes black or pixelates and after 15 to 20 mins by pressing the power on button of the monitor it is getting switched on, and again when restarted it is having the same problem.
Aug 18, 2013 | Dell Computers & Internet
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
JVC AV-56WP74 56 in. Rear projection blurred image
Check that the 3 output plugs are in the right sockets (Red, Blue, Green) There is usually a felt pen colored mark on a white tape on the plug in wires. The Board sockets are marked Red, Green, Blue.
Easyab
Jun 20, 2008 | JVC AV-56WP74 56" Rear Projection...
Image/screen shifting with mouse position
I realized my issue was that the screen was "slightly" zoomed in using the universal access panel in the system preferences. Turning it off, or zooming out completely solved the problem.
Feb 21, 2008 | Apple Cinema Display 23" HD Monitor
Monitor has shadows from left to right
Try changing the cable that connects the monitor to the computer, that might improve things slightly, but because you said that it works for the first 15 minutes I'm skeptical that the cable has anything to do with it.
The monitor is near the end of it's life. There's not much that can be done.
Jan 24, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
Short, 3/8", horizontal blurs
I posted this answer on another "white streak" question, I suspect this is right:
This issue presents itself in different ways in this monitor, in the form of smeary video, or color changing from the left to right, or as you indicate, a smear following text. I know this as I own this monitor, and have repaired this myself. There are three 1 mf capacitors, surface mounted on the control board inside the monitor that fail. They are in the RGB input lines, and when they fail they cause distortion of the RGB signals, causing what you see. They are the three caps you will find in a row, spaced maybe 14mm on the board between the VGA connector and the processor chip. I would replace all three, observing polarity markings. You can get by just fine using old-style thru-hole caps, just form and clip the leads and solder 'em down on the surface-mount pads. I highly recommend proper soldering tools for this job though, especially for the removal of the old parts, they don't want to come off unless you can heat both pads at the same time.
Jan 15, 2008 | ViewSonic VA800 17.4" Flat Panel LCD...
Philips monitor problem
Check that the pc to monitor vga lead is not loose at both ends, check your graphics drivers are upto date, although it could well be a monitor fault and replacment required, as don't think they are worth reparing these days
Nov 02, 2006 | Philips Business 104B Monitor
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
