Hi there! My dad has this big sony tv, model KP53v25. It casts this blue shadow to the upper left of everything. I tried to fix by messing with the in-menu convergence, but it didn't do much. It moved the shadow a little bit, but it's still there. It also seems like the entire picture needs to be moved down a little, and I don't see anything in the menu to change that. I know the tv is roughly 15 years old now, but it's what we have so...can anyone help?
  • Televison & ... Master
  • 19,396 Answers
Hi.
If it is a shadow in a corner, then it is unlikely a convergennce problem.
When the problem is convergence you get colors not matching and you may get an arched band at the top and bottom side of the screen.
A rear projection TV will project a picture on display using a lamp. The lamp light will pass inside a tube whose inside surface is covered with mirror. This device is called the light tunnel.
If you get a shadow on a corner of the screen , that is often because one of the mirrors in the TV light tunnel had fell down detaching from light tunnel internal surface.
Regards.
Posted on Dec 11, 2009
    Brigadier General:
  • 4,090 Answers
Only a tech can fix this now as it is the internal color engine that is on the blink
Please rate my help++++Thanks for using FIXYA
SOURCE:
I have a philips tv model no: 40PFL7505D/F7 serial no: DS1A1120151966 with a one thin vertical black line on the right side of the tv. Can someone please advise me on how to fix this problem.
I wonder why it's messed up so Phillips 42 flat screen plasma blinking red light seven times help please is that your problem ma'am or is it no picture and red blinking light over I have a 53rd Cosmo shuts off and blanks road bike to and seven times why main ford model problem do you have a problem with me I love you I love you I mean just kidding just kidding just kidding just kidding just kidding just kidding just kidding just kidding get a get a get a get a get a get a get a get a get a get a get a get a get a get a get a get a get a get a get a get a get a get a get a get a get a get it I just playing around to get points by the way that that that that I don't I don't I don't I dad dad dad dad dad dad I am not my dad dad dad dad dad dad dad dad dad dad dad dark shadow legwork on screen Phillips for 7PFL360 3-D LCD TV TV not responding to mow check out the latest age do you television report horizontal center one press menu to scroll to settings three scroll the screen for go to the horizontal center move the picture to the right hopefully the line will go away otherwise there is a problem with the pixels for the signal per person processor call 1800-222 - Sony or hit equals//e-service.Sony.com have a high limit credit card handy for out of warranty prepared sorry about that I feel bad for you guys i'm so sorry for you thank you for taking my advice and make sure it is helpful
Dec 20, 2016 | Philips Televison & Video
Picture is distorted from center on my 65
You do have a failure in the convergence circuit of your set. If you are good at soldering you can replace the IC's yourself. They are on the large circuit board on the left side of the set looking from the back, and attached to a large aluminum heat sink. If you don't feel comfortable doing that, I reccomend removing the board and sending it to PTS corp in Indiana. They are pretty reasonable repairing boards, and a lot less than buying a new one.
May 31, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Picture is distorted from center on my 65" Sony projection TV.
hi. this will be an easy fix for you if you are a good solder. you will need to replace the convergence chip that is located on the PC board(main). this chip is damaged and it has failed due to this damage that has occurred. click below for your new convergence chip(stk).
CLICK HERE
May 21, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Shadows (Red, Blue) on the pictures
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
This blog covers many makes and models with many issues solved, just with that one solution
Give it a try, it's free and simple :D
Had the same problem , fallowed the directions in that
blog....and it was fixed in 10 min :D
The Guy Ken, who posted it is a GOD !!!!!
Hope the blog helps you and anyone with this or similar
problems !
Jean
Feb 23, 2009 | Sony KP-51WS510 51" Rear Projection...
Image on tv casts a red shadow.
TRY THE MAGIC FOCUS BUTTON. IF THIS DOES NOT CORRECT THE PROBLEM YOU WILL NEED A SERVICER TO GO IN AND REPAIR CONNECTIONS OR REPLACE THE CONVERGENCE IC'S AND OR RESISTORS. AND READJUST CONVERGENCE IN THE SERVICE MODE.
Jan 07, 2009 | Sony KP-57WS500 57" Rear Projection...
Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Sep 25, 2008 | Samsung HCM4216W 42" Rear Projection...
Blue Convergence
Hello All Above,
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
Mar 11, 2008 | Samsung HCN653W 65" Rear Projection...
Sony kdf-e50a12u rear projection lcd bravia. red shadows
This is due to you having a projection tv, some projection tvs are really bad for game playing and especially if you have a hdtv. even in the p23 manual it says that you shouldnt use with a projection tv cause it can damage your tv's screen permanently. I personally still play mine but, thats likly the problem.
Aug 11, 2007 | Sony KP-61HS10 61" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
