Question about Toshiba TLP S30 Multimedia Projector
Toshiba TLP-S30 loses calibration/alignment with whiteboard.
  • 2,237 Answers
There are phisical adjustments for the projector itself. is it on a smartboard? hold down the 2 buttons on the pen tray until the 9 point callibration screen appears. the points react to stylus release, so put the stylus near the point and "draw" a line to the center of the point then release. do the same for the other 8. that should do it.
Posted on Dec 11, 2009
The Smartboard is losing the alignment, and the pointer can not appear exactly where I expect it to.
you have to recallibrate the board. on the pen tray, hold down the 2 buttons until the callibration screen appears. with one of the styluses, draw a line from somewhere just outside of the point to the center of the point and release. do that for the other 8. done.
Feb 03, 2010 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP s30 projector identification part
http://www.nextag.com/toshiba-tlp-s30/search-html
Mar 28, 2008 | Toshiba TLP S30 Multimedia Projector
Adjust size of display on interactive whiteboard we are using a projector and a smartboard and can't get the same display on the smartboard as we have on the computer monitor - we want a better fit. If we...
if you have no zooom and only a digital zoom this wont work so you need a longer vga cable and if you have mounted it you need longer wires and to take your projector further back.
Jan 15, 2010 | Toshiba TLP S30 Multimedia Projector
I have a Toshiba TLP-S30 and lately the color balance of the projected image is way off. I've tried adjusting the color balance via the menu, but no improvement. Could this problem be fixed with a new...
reset the settings to factory default. sometimes the lamp will burn at a lower temp at the end of it's life and emits a different color. might be the lamp or the ballast. if all else fails, replace the main board.
Oct 18, 2009 | Toshiba TLP S30 Multimedia Projector
Internal fan location in TLP S30, I get an error message about internal fan problem
one of the fans arent working. there should be at least 3- one for the lamp, one for the power supply, and at least one for the lcd panels. you should be able to see the one for the lamp and power supply from the outside. if both are spinning, it's the other one, which you might be able to see from the bottom.
Sep 22, 2009 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP XD-2000
There are two things it could be...
First, how far are you trying to run the cable for? When you run longer distance a humbucker might be needed. Or it means that the internal distribution output has bad vertical and horizontal connections.
Jul 21, 2009 | Toshiba TLP S30 Multimedia Projector
White areas in the image are yellow and the black are blue-green
you have a few issues. first is the yellow in white. the light filter on the blue lcd panel is fried due to excessive dust and heat. unfortunately, you may have to replace the whole optical engine. as for the flashing horizontal lines, the power supply isn't cooling down and the caps are drying out, causing fluctuations in voltage. so, replace the power supply.
Jul 04, 2009 | Toshiba TLP S30 Multimedia Projector
Unsupported Signal
Hi Circuitrider
Just change the resolution on your PC to match that of the Projector i.e. XGA Projector = 1024x768 resoltuion.
If the problem still persists , the Mainboard is at fault and will need either replacement or repair.
May 13, 2008 | Toshiba TLP S30 Multimedia Projector
Hey Guys
Auset
You can go to www.projectorcentral.com and go to Projector brands.
Simply click on on your brand and model and download the Users Manual and burn to CD if you wish.
Mar 22, 2008 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP S30 Multimedia Projector Logo
459 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Marius Chiriac
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
