Question about HP PSC 1210 All-In-One InkJet Printer
Pritner error The printer's check print cartridge light is flashing and 'E' appeared in the copies window. The cartridge in the printer was refilled and has been working. For no particular reason, the above problem pops up when I try to use this today.
  • Anonymous May 08, 2008
    added new ink cartridges black and tri color and I'm still getting the same error, flashing light and the E.
  • suetink May 10, 2008
    Same problem with cartridges; then when both replaced, printer started flashing the "E" saying no paper. Paper was in the tray. I tried loading paper every which way, tried different kinds of paper, but still get flashing "E" and message saying no paper... Can anyone help with this?
    Thanks much
    Sue
  • HP Master
  • 1,113 Answers
Cartridge will need to be replaced, not only does the ink in them run out but the electronics that control the head burn out/corrode
Posted on Jan 20, 2008
6ya staff
SOURCE:
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
Just changed cartridges to refills and clour and black lights flashinghowever we can still print ok. Why are the lights flashing?
The lights are flashing because you are using refilled cartridges. The printer "sees" those cartridges as empty, since it can not know that someone has refilled them. When you put in new cartridges, the lights will stop flashing.
Just ignore the lights and print!
Hope that helps!
May 19, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma MP198 error code 2 114 0
i got a same prob..i can't print,scan and copy and the refill warning always appeared..i hv refill the cartridge and i shut it down and try again and again..it's the cartridge prob or the printer prob..?
Feb 21, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Printer wont print
Turn the printer on. Remove the cartridges. Gently clean the electric contacts on the cartridges and the cartridge carrier. Put the cartridges back in. If the light is still flashing, and your printer won't print, one of your cartridges is faulty. I suggest you go to the refill shop and consult them which cartridges needs a replacement.
Does any message appears on your monitor when you try to print something? Usually, a message saying "problem with black/color cartridge" or something similar, that's why I am asking.
Dec 22, 2009 | HP DeskJet 930c InkJet Printer
ORANGE LIGHT IS BLINKING AND PRINTER WILL NOT PRINT
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | HP Laser Jet 1320 Printer
Replaced Toner, Does not register
replace toner cartridge with a bother brand
Jun 10, 2009 | Canon imageCLASS D760 All-In-One Laser...
Mx700 only printing in B&W
This is a software problem, do uninstall and re installation of the printer software on your computer and that should do it...
Dec 14, 2008 | Canon MX700 Office All-In-One InkJet...
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
HP psc check print cartridge light is flashing
The "E" means a cartridge problem.
Have you recently changed them?
If so, did yo use "refills" or another non-HP cartridges?
Jan 11, 2008 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1210 All-In-One InkJet Printer Logo
216 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
