Question about SanDisk Sansa e250 MP3 Player
Generic Mp4 Player "USB 2.0 (FS) ADFU Device"
Hi Pro's,
I had no problems setting up lst day, windows xp recognized
shown device set up successful and ready to use.
Sync music to it no problem,
Next time I plugged in, Windowsxp now only recognizes as a
USB Storage ..... New mp3 downloads shown as format error>
I tried another new mp4 player that is stuck with hour glass on screen only I didn't bother to try until problem with above.
That one set up fine as "USB 2.0 (FS) ADFU Device" as it is suppose to.
I Made note of driver location to use for other one not there,
make no since of course I'm no a tech.
I love my ipod.
Forget these generics.... lol.
Trying to fix 2 for a friend. I thought would be easy, as ipod repair.... ...
NOT....
I hope I explained well enough.
I know I would never make it on twitter short words lol
Thanks anyone,
Kim
Syd_
  • 47 Answers
SOURCE: Not enough memory space for music db
Your M240 may have encountered a corruption in its Music Database, and may be corrected by formatting and updating the firmware. Try this: Manually switch the player to MSC mode and format through "Disk Management". Here are the steps: Step 1: Locate the "Hold" switch on the side of the M240 and enable it (you should see an "orange-colored" surface when it's enabled) Step 2: Plug the M240 to your computer (recommended Operating System is Windows XP and above) and check Windows Explorer if the player is detected as a "Removable Drive" Step 3: Open "Disk Management" by right-clicking on the "My Computer" icon, then selecting "Manage" Step 4: Your "Disk Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" Step 5: On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa M240. The lower section also contains the drive # pertaining to your M240. Right-click on either drive letters pertaining to the M240 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. Step 6: In general, Disk Management is more the effective tool for formatting your M240 and assuming the format processing completed without any errors, proceed to updating the firmware of your player. Step 7: Use this link to download the Sansa Firmware updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Save this file to your Desktop and run it while your M240 is still plugged in to your PC. Follow the on-screen prompts. Step 8: "Safely remove" your M240 from your PC and -- with a fresh battery -- power on your player. It should boot up normally. I hope this works. The M240 is a great player
Posted on Apr 24, 2007
SOURCE: Sansa M230 not seen in Explorer or Windows Media Player
We had the same problem with Windows XP. We found some help on the Sandisk web site. On the device go to the Settings menu, then USB. We changed from AutoDetect to MSC mode and everything is working again. Our computer saw all of the songs on our computer fine. Some of the old songs on the Sansa didn't show up on the detect list in Windows Media Player, but they were still on the device.
Posted on May 17, 2008
  • 4 Answers
SOURCE: Computer doesn't recognize MP3 player -
I had the same problem, all you have to do is first turn on the Mp3.Then go to settings. Then go down to USB mode. It will probably say, auto detect.But instead scroll down to MSC. If that doesn't work try MTP.
Posted on Jul 15, 2008
  • 758 Answers
What I would recommend you to do is to make sure that your device is under MTP mode instead of MSC...to do that go under menu,setting, usb and then there should the two mode listed there...then you want to plug your device in the back of your computer..not in the front..tghat is very important....once you do that..open up your windows media player...click on your start thee sync panel..if your device is recognize properly it will be showing there on the right side..and if its not listed properly, it will say connect a device..if thats the case..click on your start menu right click on computer and then click on propetties, click under hardware and then device manager..your device should be showing there...check under disk drives to see if your device is showing there and if it doesnt you want to right click and hit uninstall...we dont want your device to be under disk drive ..we want it to be under windows portable device...once you uninstall it...go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Posted on Jul 18, 2008
SOURCE: Found New Hardware MTP Device. Pop-Up
Try changing mp3 firmware to MSC mode.
MTP is a protocol developed by Microsoft that just sucks and makes one million of help requests like yours.
Posted on Aug 10, 2008
Hi, my pc don't read the mp34 audio player =( help!!!
Why is my mp3 and mp4 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see mp3 and mp4 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the mp3 and mp4 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: mp3 and mp4 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 and mp4 Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for mp3 and mp4 Players when used with Windows OS.
The mp3 and mp4 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
May 05, 2011 | Digital Audio NAP256 MP3 Player
When i installed the media player into my computer. i get a little screen saying usb device not recognized. one of usb devices attachedto this computer has malfunction,and windows does not recognize it....
Hi, smpk4083 mp3 player not recognized by the computer
Why is my smpk4083 mp3 player not being detected by my computer when I connect it?
4. Power issue.
- Run the hotfix.
For MAC users, see smpk4083 mp3 player not recognized by a MAC OS
STEP 1 - Connect the smpk4083 mp3 player to the PC
NOTE: smpk4083 mp3 Players can connect to your computer in MSC or MTP mode. Exceptions are smpk4083 mp3 player Connect and smpk4083 mp3 Express which only use MTP mode. MTP mode is the recommended and default method for smpk4083 mp3 Players when used with Windows OS.
The smpk4083 mp3 player will show up on Device Manager's right pane as:
Hope it helped.
Have a nice day,.
Feb 22, 2011 | Sylvania Audio Players & Recorders
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
4. Power issue.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
STEP 1 - Connect the Sansa player to the PC
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
I have just bought a new sansa clip. i have successfully uploaded music to the the player and i can hear it well. now when i try to access the player through the computer i cannot access the music and...
Hi, are you sure the computer is recognizing your player?...if not....
4. Power issue.
- Run the hotfix.
Hope it helped ..
Have a nice day..
Feb 19, 2011 | SanDisk Sansa Clip MP3 Player
My GO gear Mp3 player wont be detected on any computer. even if you install the hardware, it wont still detect.
if your player don't detect . also don't detect with Philips Device Manager
try to download this driver for it usb 2.0 ADFU Driver .
i worked with 7 and in system device manager show "uknown usb device" but in XP show this "usb 2.0 ADFU Drive" and also the Xp itself install it . if your windows dosent have this so go on to download it manualy . then use philips device manager to repair it . i do it myself and it worked
Dec 13, 2010 | Philips GOGEAR SA6045 MP3 Player
I need SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048) software.....
You can download the driver from the manufactuer's web site at http://www.sansa.com
Mar 14, 2010 | SanDisk Sansa m250 MP3 Player
Vega mp4 software does not work with windows xp only 98
I think your device only work with USB 1 and windows 98 can not recognize USB2. But windows Xp can recognize usb2 ports.
For solve yhis problem in windows XP:
Go to Device Manager. Find the USB section. One of the USB entries
has the word "Enhanced" in it. Select that entry. Do "properties"
on it. At the bottom of the Properties for the Enhanced entry,
there is a "Device Usage" box. It has values like
Use this device (enable)
Do not use this device (disable)
Change the setting to "disable".
Mar 08, 2010 | Computers & Internet
Mp4 locked displaying hourglass
nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnothinh helps uu man
Aug 02, 2009 | Philips SA3125\02 MP3 Player
Mp4 ipod not detect driver
free download firmware Ipod ixus nano 2
Jun 10, 2008 | Laser MVP-1G MP3 Player
SanDisk Sansa e250 MP3 Player Logo
1,502 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
