Question about LG LRSC26920TT Side by Side Refrigerator
LED control Hi, Could you help me please? I want to switch LED Control Panel from Fahrenheit to Celsius. Thanks Ludwig
  • lpauco Jan 20, 2008
    Sorry, doesn't work.
  • 241 Answers
To change temperature display from Fahrenheit to Celsius press and hold
“FREEZER” and “REFRIGERATOR” buttons simultaneously for more than 5
seconds. Do the same to convert back to Celsius.
Posted on Jan 20, 2008
6ya staff
SOURCE:
Oven control won't let me raise temp. above 287, is there a way to reset control panel
Yes, you are in Centigrade (Celsius) mode. Check your owner's manual for instructions on how to switch between Centigrade and Fahrenheit.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 09, 2014 | Kitchen Ranges
Temp probe indicator stays on
sounds like your probe connection may be shorted. Can you inspect the probe itself, and perhaps do a test for continuity with an ohm meter? Also, you might be able to disable the probe in the menu settings, and run it on manual, just for a test.
Do you still have the user's manual for this unit?
Feb 13, 2008 | Thermador C272 Electric Double Oven
How do you change from Celsius to Fahrenheit on remote?
Go to settings/menu on the remote, find the Celsius/Fahrenheit mode, change it and done.
Sep 09, 2014 | HQRP Universal A/C Remote Control...
Changing the external temperature gauge from Fahrenheit to Celsius
If your temperature reads in climate control reads in degrees Celsius "C" instead of Fahrenheit "F", follow these steps to change to Fahrenheit.
  • Turn the ignition on.
  • With the climate control turned on, push and hold the recirculation button in. While holding the button in, push and hold the off button in for 3 seconds or until you hear a beep.
The display should then change to "F". Follow these same steps to change your read-out to Celsius , if preferred.
Sep 21, 2012 | 2005 Land Rover LR3
The LED control panel quit reading temp and now has a range between 19 and 31. What does this mean and how do I convert it back to temperature? The brand is Comfort Aire Model #RAD101-5-B Thanks for any...
That is Celsius, rather than Fahrenheit. To return it it Fahrenheit press the temperature up and down arrows at the same time and hold for 3 seconds. It should return to Fahrenheit.
Hope this helped you and thanks for choosing FixYa.
Aug 02, 2011 | Comfort-Aire RAD-101 Air Conditioner
MY OVEN IS VIKING OVEN CAN YOU PLEASE TELL ME HOW TO CHANGE FARENHEIT FROM CELCIUS
Hi and welcome to FixYa, I am Kelly.
Here is how you change it:
Degree Format
The oven has been preset to the Fahrenheit temperature scale.
With this feature, users can switch to the Celsius temperature
scale.
To change degree format to Celsius:
1. Press "SETTINGS." Settings menu will appear in display.
2. Press the up or down arrows until "DEGREES:
FAHRENHEIT" appears in the display.
3. Press "ENTER" to change degree format. Current value
will flash.
4. Use arrow keys to select "CELSIUS."
5. Press "ENTER" again to set degree format.
6. To exit the Settings menu, press "SETTINGS."
You will need to press the up or down button after pressing settings until you see Celsius appear then press ENTER and the Celsius flashes then use the arrow key to select Fahrenheit (still flashing) and once again press enter (saves) and it stops flashing. then press settings to exit the settings menu.
Thanks for choosing FixYa,
Kelly
Mar 22, 2011 | Microwave Ovens
How to set temp in the freezer box
dear sir/madam
please find out temperature control switch on control panel then make it on ideal setting. for freezer 0 Fahrenheit (-18 celsius) for storing food and -10 fahrenheit (-23 celsius) is recommend when freezing food. please set on ideal setting.
hope answer the question
thank you
please vote!
Aug 13, 2010 | Traulsen 24.2 cu. ft. / 685 liter...
I have a Ritetemp 6022 and can not get it to switch from Celsius to Fahrenheit. What do the instructions mean by separate the control unit from the wall mounted terminals?
It means to remove the little blue (mine are blue) squares on the two prong things( they have numbers next to them). With the blue things on the two prong numbered things on top of the unit it turns on the function of Celsius, 24 hr clock and other things. I had this same problem but I took the blue things off and reset my unit and it went to 12 hr clock and Fahrenheit. For me the Fahrenheit was the two prong thing labeled with the number 3 next to it. That's what the instructions mean by separating the control unit (blue thing is the control unit) from the wall mounted terminal (2 prong gold things with numbers.)
Jan 04, 2010 | Heating & Cooling
Change from celsius to fahrenheit
You can switch the temperature mode between Fahrenheit to Celsius as follows:
While depressing the AUTO button, depress the OFF button for 3 seconds or more. The display will change from Fahrenheit to Celsius, or from Celsius to Fahrenheit."
Jun 02, 2009 | 2003 Kia Sorento
Switch from Celsius to Fahrenheit Temperature setting
Press cancel and bake buttons simultaneously for 3-5 seconds until C appears then use up/down buttons to change to Fahrenheit. Hope this helps!
Feb 10, 2008 | Magic Chef 31000 Gas Kitchen Range
LG LRSC26920TT Side by Side Refrigerator Logo
473 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
deecee73
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
