Question about Motorola Mobility RAZR V3
Not detected by my system installation problem
My acer aspire one d150 netbook webcam is missing . went to device manager and imaging display is missing . can anyone help with this problem?
Camera is not detected, there are several possibilities:
The first possibility
There was an error installing the driver. AOD150, manufactured by three types of cameras, chicony, liteon, suyin. Example: I installed the camera driver, suyin to AOD150. At the time of installation, a message appears, hardware not found / not detected / not recognize. This means, suyin not the right driver.
Solution
1. Open link driver AOD150
2. Operating System = Microsoft Windows XP Home Edition x32
3. Download software = Hardware Vendor Detection Utility
4. Double-click = HWVendorDetection.exe. We will find the right camera hardware.
5.
Download and install the Liteon driver
The second possibility
If the hardware vendor detection utility, does not detect camera
Solution 1
(assuming, normal hardware)
1. Possible corrupt operating system.
2. Reinstall the operating system, by doing format drive C.
3. Move all data from drive C to D/E/F.
4. Download drivers AOD150, and other applications, save it on drive D/E/F
5. Insert the Windows CD bootable. Perform boot from CD.
6. Press enter - F8 - New Installation - format the C drive, etc.
7. After the OS install is complete, install all drivers (chipset, LAN, VGA, sound, camera, etc)
Solution 2 (assuming, damage hardware)
Contact Acer Support
I hope this information useful, thank you.
Nov 24, 2011 | Acer Computers & Internet
My acer 5738 model laptop wireless network adapter not detected this message above my screen what i do? i install all drivers soft. in my system, and switched on the wifi button on my system, but this...
Hello
Re-installation of drivers is recommended for detection of network adapter, if you dont have updated drivers, then download from ACER web site.
The button should be on during installation of drivers.
Hope this helps.
Jan 18, 2011 | Acer Aspire 5500 5570-2609 Laptop
Hw i install this software
There is a cd installer inside of the box along with your webcam. First install the a4tech cd installer and after installing plug your a4tech webcam into your computer usb port.The system will detecting a new hardware just click next or accept or ok to install the detected hardware. If the system requesting for a system restart just restart your computer. Have a good day!
Dec 03, 2010 | A4tech PK-635 Webcam
I have problem in asus A8V-vm motherboard in that hard disk is not detected in BIOS but Win-XP is working properly and when I tries to install new windows XP it shows an error that hard disk cannot be...
Asus A8V-VM Motherboard coming with SATA RAID option, thats why you could not see the detected HDD in system BIOS. But you can see the the detected HDD in RAID BIOS. You can enter to RAID BIOS that will pop up after system BIOS. If you are using old version of WinXP it will not detect the RAID controller of you motherboard. Thats why you cannot able to install WinXP. While you booting from WinXP CD press F6 key when the WinXP installer prompted for third party driver. Copy the RAID driver provider in driver CD to a Floppy Disk (INF file) and insert it, hit enter to continue the installation. If you are using WinXP Service pack 2 or higher you do not need this step it will automatically detect the HDD.
Nov 25, 2010 | ASUS A8V-VM Motherboard
Sansa Fuze player will not connect to the computer
The Sansa Fuze information support is on next site:
http://kb.sandisk.com/app/answers/detail/a_id/3249/
Sansa Fuze can connect in either MTP or MSC mode.
MTP is Media Transfer Protocol when a software program like Windows
Media Player 10 or higher is installed.
MSC is Mass Storage Class when the player is detected as an external flash drive in "My Computer".
The connection mode can be set to one of the following USB modes:
auto detect:
the player will connect in MTP or MSC mode. It depends on the drivers that are installed for the USB ports for the operating system and extra media software, if the data on the player can be detected. In auto detect
mode, MTP mode detection is only possible when having Windows Media Player 10 or higher installed.
mtp:
detection on operating system Windows XP SP2 or higher, in Windows Media Player 10 or higher.
msc:
detection on operating system Windows in the explorer in "My Computer" and on MAC operating system.
Look in the manual on page 35 = page 38 in the pdf file, how to switch the USB mode under System Settings in the player:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Mar 20, 2010 | SanDisk Sansa Fuze MP3 Player
How do i replace the natural vacuum leak detection pump on a 2005 dodge dakota?
Vehicles equipped with NGC engine control modules use an NVLD pump and system. Vehicles equipped with JTEC engine control modules use a leak detection pump. Refer to Leak Detection Pump (LDP) for additional information.
The Natural Vacuum Leak Detection (NVLD) system is the next generation evaporative leak detection system that will first be used on vehicles equipped with the Next Generation Controller (NGC). This new system replaces the leak detection pump as the method of evaporative system leak detection. This is to detect a leak equivalent to a 0.020 (0.5 mm) hole. This system has the capability to detect holes of this size very dependably.
Removal & Installation
  1. Raise and support vehicle.
  2. Remove left-rear tire.
  3. Remove plastic shield (4) in front of left-rear tire. Access to both the EVAP canister (1) and NVLD pump (6) is from the area in front of the removed tire.
  4. Disconnect electrical connector at NVLD pump.
  5. Remove vapor line at NVLD pump. Pry outward on tab (3) and rotate pump (6) clockwise about 70 for removal.
  6. Remove NVLD pump O-ring (5) from EVAP canister (1).
To Install:
  1. Install new NVLD pump O-ring (5) to EVAP canister (1).
  2. Position NVLD pump (6) into EVAP canister (1).
  3. Rotate pump (6) until tab aligns with notch in EVAP canister (1).
  4. Carefully install vapor/vacuum lines to NVLD pump.
    WARNING The vapor/vacuum lines and hoses must be firmly connected. Check the vapor/vacuum lines at the NVLD pump, filter and EVAP canister purge solenoid for damage or leaks. If a leak is present, a Diagnostic Trouble Code (DTC) may be set.
  5. Connect electrical connector to pump.
  6. Install plastic shield in front of left-rear tire.
  7. Install left-rear tire.
    Fig.
    Fig.
Have a nice day (remember rated this help).
Mar 05, 2010 | 2004 Dodge Dakota
If the harddisk conected in your system are not dected
"ASSUMING YOU ARE USING A SATA HDD"
check the bios settings.....
if your hard disk detection is enabled or not...
if yes...(yet your system is not detecting your hard drive)
then....go the manufacturer's site and download the respective sata driver of your hdd (particular model number)...
burn it into a cd...
insert the cd into a usb cd rom/writer.....
then try to install windows.... let the system boots from the cd
at the time when it says "press f2 to install driver"
press f2...
then browse to the location i.i. usb cd - rom/writer and install the driver...
now your system will detect your hdd...
if this info is useful
don' t forget to say thanks...
Dec 16, 2009 | Computers & Internet
Where cain i gate audio output device installed for my laptop
First installations of Vista some times fail to detect the hardware on older systems, like my Dell Inspiron 9100 laptop. However, after running Windows Update several times automatically detects the missing drivers and installs them automatically.
Try that, if that is your case. Other than that, try uninstalling the device using Device Manager, and immediately reboot the system. Vista will detect the missing hardware and will reinstall it from its list of known drivers. As your last resort, try going to your system's manufacturer's web site and go to the Support page. Most manufacturers have a Drivers Download page.
Oct 04, 2009 | Microsoft Windows Vista Ultimate Edition
System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
otherwise use dm (disk manager) for detection and partition.
Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
ActiveSync is not detecting Nokia N81
Hi, sorry MS activesync will not detect Nokia devices - Actvesync will only discover devices with the Windows Mobile/PocketPC operating system
Mar 08, 2008 | O2 Xda IIs Pocket PC
Motorola Mobility RAZR V3 Logo
20 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
