Question about Hotpoint Ariston WD440G Front Load All-in-One Washer / Dryer
Hotpoint WD440 creases clothes badly & takes ages to dry
  • 57 Answers
This sounds like excess steam in the drum. Check that the drain filter is clean as washer driers rely on cold water being taken in to cool the condenser tank during the drying cycle. If the filter is clear, the tank may be blocked with fluff. You have to open the machine a look for a big plastic tank, usually down the right hand side.
Posted on Dec 11, 2009
We have an Ultima washing machine and creases the cloths very badly any suggestions please
The amount of creasing you will get is directly related to the speed you select for the final spin dry cycle and the spin after the first wash cycle which occurs prior to the rinse cycle. The higher the speed and the longer it goes for the more the clothes will crease.
Experiment with different spin speeds on your machine for clothing that is subject to the creasing problem. Also do not put too many items in the machine for a wash as many people do as this will contribute to creasing. Always under load your machine for every wash cycle.
Spin drying is a compromise between creasing and maximum water removal. If you want less creasing you will need to select a more gentle spin dry speed but you will also have the clothes coming out of the machine with a higher water content and they will take a bit longer to dry. The spin time on the program may also be shorter.
In my own machines I use a gentle wash and spin cycle for all clothing that I don't want heavily creased. Running it on a wash cycle with a high and longer spin speed when the machine is spinning the clothes after the initial wash, and then again after the final rinse, will thoroughly crease the clothes every time.
Also bear in mind that different fabrics that are suitable for machine washing will perform differently and some are just too subject to creasing even if you use the most gentle wash, rinse and spin cycle. Hence you can take 2 different 100% cotton fabrics out of a machine and hang them to dry and one will be almost crease free and the other will be thoroughly creased. With these fabrics that are just very subject to wash creasing, it is better to hand wash and rinse them. Then after rinsing drip dry them or put them in the machine and spin them for 1 -2 minutes maximum just to get some of the water out and hang dry them.
Dec 28, 2015 | Hotpoint Washing Machines
Hotpoint WD440 washer/dryer wont control.when plugged in 4 lights flash and it goes to pump out . no switch has any effect. the lights flashing are the on/off ,drying high heat.reduced creases and time...
The NTC for the dryer is situated on top of the dryer heater box, fault can often be caused by a simple broken wire, they are very weak at this point.
its the sensor on the dryer
if you take off the top, its mounted on top of the dryer box, usually has a white plug with 2 black wires attached
Dec 13, 2011 | Hotpoint Ariston WD440G Front Load...
My Hotpoint Aquarius WD440 smells of hot rubber when it is on the M (drying) programme and the clothes come out smelling of rubber. Can you tell me why this is happening. Everything is working fine...
Hotp[oint Aquarius WD440 washer /dryer - Has a distinct smell from clothes when washed like stagnant water is lying somewhere in the machine, It has all benn stripped down but cannot find anything wrong. Whats the solution????
Aug 11, 2011 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wd440 drum sticking when rotate by hand
The drum on my hoover washing machine is sticking / grinding, can anyone advise what it may be? Thanks
Oct 14, 2009 | Washing Machines
My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd440 heating but not drying
yes, the dryer is pants im afraid. weve had ours going on 4 years & it has broke down every 6-10months - seriously! the dryer will leave clothes hot & steamy but when hung up for 1/4hr they r dry! _ Hotpoint advised us that he machine is esigned his way - but dont believe a word from their corporate b***hit mouths!
Aug 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd440 flashing dryer heat button and onoff button !
I had to have a tech come out for the same problem two weeks ago. They had to clean the lint collector which you cannot get to on your own. He said now that this has been done everytime I use the machine, take the clothes out and then run a rinse spin cycle.
Aug 04, 2008 | Hotpoint Aquarius WD63 Front Load...
Not drying
Is it still under warranty? I've read that these machines are better left at the retailer...
Dec 08, 2007 | Hotpoint Aquarius WD640 Front Load...
WD440 programme m
This sounds like a faulty pcb and/or inlet valve. see links for prices.
meatballs77 - If you have warranty (the machine is less than 1 year old which yours is) or paid for extended cover then call hotpoint to replace... Hotpoint should be able to fix this - this should be free. call 0870 4422 510
Rememer parts are free up to five years - but there is a £90 callout fee after the first year.(unless you extend the full warranty)
Nov 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ariston WD440G Front Load All-in-One Washer / Dryer Logo
207 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
