Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Hi my digicam states the error "memory card error - card locked!" but my card isn't locked. i tried using other sd cards but it worked fine. this card i am facing problems with is a sdhc class 4 32gb. is the camera nt compatible with sdhc? is there anyway i can get pass this?
    President:
  • 1,566 Answers
Take out your memory card from the camera and then inspect a small or tiny switch. This is the card lock. You need to move it the other way around to enable write back on the memory card.
Hope this helps you out.
Posted on Dec 21, 2009
    Brigadier General:
  • 4,090 Answers
I think the capacity of the card is too high for this camera. Use a lower value card
Please rate my help++++Thanks for using FIXYA
Posted on Dec 11, 2009
Says Card Error
Make sure your camera can take San Disk. It probably takes a certian card or the SD card might be upside down. Some brand and models stay this fault and the problem with the SD is that it does not accept a memory card higher than 1GB. This info isn't in the user guide. Have you tried an external usb card reader?
Pull the card out and re-insert. the most likely problem is the card was not seated properly in the slot.
Keep us updated.
May 17, 2011 | Vivitar ViviCam 5386 Digital Camera
WHAT IS THE CAPACITY OF EXTENDED MEMORY OF DIGITAL CAMERA IXUS 95IS
There is no card limit mentioned but as far as I know it support 32GB SD card. But in case of video capacity it supported only 4gb in a single clip.
Mar 14, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
Have brand new PNY OPTIMA SD HC 8gb Have a HP camera Photosmart R927 Camera reads card is locked. How do I unlock the card?
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Jul 06, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
Hi: I have a lumix/Panasonic DMC-FS3. I keep getting a message "Memory Card Error. Please check the card." Nothing has happened to the card. What could cause that?
Has the memory card ever worked in this camera? If yes, try downloading all the pictures to your computer then format the memory card using the camera setip menu. If this is a new camera, Make sure the camera can use the SD HC type memory cards. Some older cameras cannot read the SDHC but are fine with the SD cards.
Nov 21, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
SD630 camera states error memory card? New Card 2GB SD Card. Then it states card locked removed card and still says card locked. Will not let me go into format on tools. please answer.Do I need to just...
On the side of the SD card there is a little switch for locking the memory card to prevent erasure or writing. Make sure it is not locked. After that try a smaller size card. After that junk it.
Nov 18, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Z3 will not accept a 2g card
The Dimage Z3 accept SD cards up to 1GB (Minolta says 512 Mb, and sold it with 16Mb). This camera is 4MP , and uses less memory on card, therefore a 512MB card will be enough for it.
SanDisk Flash memory card - 512 MB SD Memory ...
from $13 - 20 stores
PNY Flash memory card - 512 MB SD Memory Card ...
from $3 - 2 stores
SanDisk SD Industrial Flash memory card - 512 ... from $14
Here 1 Gb, try at your risk, but they normally work:
1GB micro SD memory card for Konica Minolta ...
£6.90 - www.mobile-laden.co.uk
1GB Flash Memory Upgrade Card for Konica ... £3.44 - Memory Express
Here review: Steves Digicams - Minolta DiMAGE Z3 -
Mar 31, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
Memory card sd
Appreciate the direct "Ask Me".
It would seem that you would have to do it all over again, that is download the pictures again to the SD memory card. But before doing this, you would need to format the SD card using the digicam rather than the PC.
In some cases, it maybe that the picture files (downloaded from the computer) does not match the image property requirements of the digicam so that even if the image files are stored in the SD memory card, the camera is unable to list/view them
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 22, 2008 | Konica Minolta DiMAGE G500 Digital Camera
Nikon Coolpix L11 Memory Card Error
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 05, 2008 | Nikon Coolpix L11 Digital Camera
Memory card error
Check the slot and see if the pins inside are fine, no breakages, free from dust etc. Try turning the camera on and off (completely remove batteries etc).
Mar 03, 2008 | Canon PowerShot A530 Digital Camera
Wont read sd card..screen shows card locked..card ok
There is a little slide switch on the side of the memory card. Good luck!
Jan 02, 2008 | Aiptek IS-DV2 Camcorder
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
105 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
