Question about ASUS Computers & Internet
When mother board is proper connected,then restart the board.also i check my ram,amd processor,smps,cabinet,pls any solution to your self....
  • cbigirish May 11, 2010
    can u change the ram?
  • 37 Answers
Problem is your processor temperature check in bios, temperature setting
Posted on Dec 12, 2009
My Computer working properly but some time suddenly monitor turn off (not standby) that time restart / power off button not working.only way to restart/off computer unplug power cable. after restart same...
Hi friends ,
It is *********** board problem,Because the over heating. Go to bios and set the FAN control disable.
If same problem
Change the CPU FAN .
If the problem same .
You will think, the censer of the mother board, has damaged and that's why,censer of the mother board think that CPU is cross the temperature limit. It is the main reason.You need another mother board,sorry to say you.
Hope it will help you.
Dec 20, 2010 | Intel D915GAV Motherboard
I brought a new Intel H55Tc Mother board, Core i3 Processor, 2GB DDR3 Ram. Now my system fan and smps fans spindling is not continue. But My SMPS is working well with other mother board.
Dear vijay, Please check your power ic of mother board there is problem. When you change it then your cpu and processor fan will be working.
Thanks. Rakesh.
Nov 26, 2010 | Intel H55TC Motherboard Core i5 650...
Get one long beep and a pulse beep on startup im using a duron 700 mhz processor and 256mb ram, 400 watt psu and a 80g Wd harddrive, cant find any info on beep codes
Open cpu cover and find motherboard.
Then reattch power connector from smps to motherboard.
Pull cmos cell from motherboard for 10 minutes then refix it.
Clean dust from all parts.
Remove PCI cards from motherboard if any.
Open processor fan and processor reattch both.
Refix RAM memory.
Make sure mother board not ground with cabinet cover.
If still same issue then check with another RAM.
Let me know if you need further assistance.
Thanks for using FixYa.
Nov 26, 2009 | Gigabyte GA-7DXC Motherboard
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Pls help me how to solve the asus K8V-Mx mother board
you could check if the pins of the processor aren't bent or broken...(even one single pin will make the processor malfunction and in your case it might not boot up) or you could have wronk ram modules so check the motherboard supportedmodules and check the modules you currently own.
Oct 30, 2008 | ASUS K8V-MX Motherboard
Booting problem
remove the ram & reinstall it again
Sep 01, 2008 | Intel D102GGC2 Motherboard
Can i replace the processor without changing the mother board ? because i am facing internet speed problem,
I am HCL Branded Computer of AMD Athlon XP 2000+ 1.67GHz RAM of 128MB with a via motherboard D___ and i newly install 80 GB Hard Disk, and a DVD LG Writer.
MY Question is__?
  1. I want to updated my Processor without unistalling mother board.
  2. my internet speed is very slow? pls tell me how to slove this problem.
I will be thankfull if your team will help me to slove my PC Problem.
Aug 24, 2008 | AMD Athlon XP 2000+, 1.67 GHz Retail...
No signal to monitor when booting.
(1) Remove memory from mother board and start the system if you happen to listen long beep then RAM is not working properly.
(2) Clean RAM conducting area on mother board with clean cotton cloth, put one peice of RAM and test and check the othe peice also, if working you could any sign display . Before doing all these check mother board any LED is glowing if so your SMPS is working after you turn on UPS.
(3) Check for all proper connection for all cables. Have you connected video cable of monitor to mother board VGA (it will not work because it is disabled as soon as you installed XFX GeForce 8800 GT), your viedo output only will come through XFX GeForce 8800 GT VGA port.
(4) If propelm persits Deassmble complete the system and reassmble & do n't connect HDD, DVD, floppy. Cehck with bare mother baord, processor, RAM (put one picese at a time) by connecting viedo cable of monitor
Apr 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus Premium Vista M2n32-Sli
Dear Riddler2002,
First thing u have to check the SMPS if it is not working properly then it will restart automatically not working properly it means that the SMPS not giving the excact power supply to mother board now the question is how can u check the SMPS working fine or not do one thing borrow a SMPS through u r friend connect that SMPS to u system if it working with u r friends SMPS then u have to change u r SMPS if still u r getting same problem then u have to check u r system RAM if RAM not work Properly then it will get this type of problem so Change the RAM and connect another RAM to u r system if the RAM is working fine then it will work properly.
Regards,
Bittu_8
Feb 13, 2008 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Computers & Internet Logo
50 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
